Question about Proform XP 580 Trainer Treadmill
Won't stay on
Machine turns off immediately after starting, resets after a few seconds, but will not stay running
Reset change oil light on a 2001 Saturn l300
I don't know the year of the vehicle so I'll give you 2 possible ways to reset it.
2004-2005
Turn the ignition to run (one position before starting engine).
Immediately after Step 1 press and release the gas pedal 3 times within 5 seconds. If the Change Engine Oil light is flashing, the system is reset. The light will flash for up to 30 seconds or until the ignition is turned off. If the light comes on again and stays on for 30 seconds at the next engine start, it did not reset. You will need to reset the system again.
Turn the ignition off and then start the engine to verify the indicator has been reset.
Turn the key to run, but don't start the car. Open up the underhood fuse box (move the coolant line out of the clips for easier access). In the fuse box is a button labeled "OIL-R". Hold it down for five seconds. The "change oil soon" light should flash for about 30 seconds or so. That means it's reset.
Sep 09, 2016 | Saturn L300 Cars & Trucks
1999 lincoln navigator turns over won't start dash board lights stay on with key out.
sounds like antitheft system is acting up..needs reprogramed maybe..pull the negative cable with the key on....kills everything..then shut the key off..reconnect the negative.. turn the key to run position for a few seconds(resets all factory presets) see if it will start..
Feb 10, 2013 | 1999 Lincoln Navigator
Ipod touch won't stay on
First, there are possibility that your iPod just out of battery, not enough to boot.
You might want to turn on and immediately connects to computer or if possible, to the direct charger.
If it turned on, wait for while and then go iTune and restore.
If not, you can at least locate the local apple store and let them take look at it.
They might ask $ for repair but it shouldn't be so expensive.
you might try resetting your iPod (hold down SELECT+MENU for a few seconds) or restoring your iPod back to factory settings in iTunes just to make sure that it's not some type of software glitch?
hope this helps
Sep 24, 2012 | Apple iPod touch
Mower will start but won't stay running as it cuts off in a few seconds
how do i replace the primer bulb on my yard machine thanks 21 in cut 6.50hp 190cc
Oct 01, 2011 | Toro Lawn Mower With Toro Power Tools
I just put a new steering column in my 200 saturn sl2 because my ignition lock was messed up. Now when whe try to start the car, it will start up but immediately shut off and then the security light...
Hello: Will try to give you instructions: Attempt to start car, leave key on (security light flashing) let set for 10 minutes, After 10 minutes security light out. Turn key off for ten seconds, turn key on, let set for 10 minutes, turn key off for 10 seconds. turn key back on let set 10 minutes, turn key off for ten seconds, the engine should now start and stay running.
Jan 14, 2011 | Saturn SL2 Cars & Trucks
Machine won't start
This unit has a safety feature. You must close the door within 3 seconds of pushing start. So push start then immediately close the door wait for a few minutes and it should be running.
Apr 20, 2010 | KitchenAid Architect® KUDC03IT Built-in...
Dryer won't stay running. It will start, run 10-15 seconds, then shut off. I can restart it immediately but get the same results.
i would check the door switch. it may be worn just enough that the vibration of the dryer opens the circuit for just a moment. then check for other loose connections. the fact that you can restart immediately usually indicates a momentary break in the circuit. a temperature switch usually takes a short time to reset. while it's still running, try rattling various switches or smack the door to see if it shuts off. (just a couple of simple ideas to start with).
good luck....jay
May 21, 2009 | Maytag Dryers
Started lawn mower first time of the season and it ran straight for a good 25 monutes with no problems. i turned it off to move it to the front yard andnow wwon't stay running. will only run for 5 to
Immediate thought is that something got ingested into the needle feeding the carb. Might have to remove the carb and clean it out thoroughly to maintain fuel flow through the engine. Generally if it runs a few seconds and shuts down then it is running off the initial burst of fuel and then starving out for any more from there.
May 12, 2009 | Craftsman Garden
Car takes a few seconds to start & shuts off immediately
how old is your battery? because if it is weak the idle air control solenoid will not sit in the right location thus the vehicle will stall and wont stay running .replacing a weak battery will fix this problem .
Feb 14, 2009 | 2003 Dodge Durango
Proform XP 580 Trainer Treadmill Logo
42 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
