Question about Canon PIXMA MP240 All-In-One InkJet Printer
Printer maintenance code 2140,0
The black ink is empty and I wont have one until saturday. So the black ink button is flashing.
It wont let me scan! it just gives me this code printer maintenance code 2140,0. help please :(
SOURCE: MX700 Will not scan with an empty ink cartidge?!
I just came up with the same problem. But if you keep pressing the right most button (the red one) for 5 seconds the message "replace ink cartridge" disappears and then you can use it as a scanner.
Posted on Mar 22, 2009
SOURCE: my canon pixma 190 printer is not working
In printer utility settings, you have to modify the ink cartridge settings and specify that printer should use only black ink cartridge. Click apply. Then press "stop\reset" button for 5-7 sec. and then release
it.
Then it will work!
Posted on May 15, 2010
SOURCE: I am out of ink on my printer and it won't let me scan
The answer I got from Canon tech support is to hold down the Stop/Reset button for 5 seconds and that should clear the "Out of ink" message. I tried it and this did indeed clear the message and allowed me to use the scanner. My multifunction is the MP600.
Posted on Aug 12, 2011
  • 1335 Answers
SOURCE: I am trying to scan
The empty ink message (error) stops all other functions on the printer. You must replace the empty cartridge before operations will continue.
Posted on Apr 20, 2011
Hi, My Canon MP210 printer is displaying E3 code. The colour light and alarm lights are illuminated constantly and black one is flashing. When opening the "lid", the cartridges do not align to...
I have workaround for the empty tank issue:
- buy or borrow another not empty tank
- place it in
- start the printer
- it recognises the "new" tank
- turn off the printer
- put back the old, empty, but refilled tank
- turn on the printer
- print something
- it will pop up a dialogue window saying
"The ink level of the black/color tank cannot be
determined. The ink level determining function will be
disabled for the black/color tank.
If you want to continue printing without this function
press the Start button on the printer."
- Press the Start button on the printer and ignore the
button 'Cancel Printing' appearing on the dialogue window.
- The dialog window disappears.
You can print your refilled tank as many times you want from this time.
When you go to 'Printers /Canon /Properties /Maintenance / Printer Status / Ink Information' it says that the ink level measuring function has been disabled for: black [40] / color[41]. You can ignore this this message, the printer will work perfectly without this stupid function.
Mar 18, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
Don't know how to change the ink cartlige
Hi
thank you for your query
Make sure the printer is on but not printing. Raise the printer cover, then press down the Maintenance button for six seconds until the print heads move to the center. Pull up the empty ink cartridge clamp all the way. The cartridge rises up from its holder and should be disposed. Unwrap the ink cartridges and remove ONLY the yellow tape seal from the black and color ink cartridge. If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer. To install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it. Install the ink cartridge and press the Maintenance button to begin charging the ink delivery system. Charging takes about a minute and is complete when the power light stops flashing and the error light goes out
Sep 24, 2010 | Epson Stylus C40UX InkJet Printer
My black ink went empty about 3 weeks ago. I replaced it today with a new cartilage but it still won't print. I performed a cleaning from the printer maintenance tab and still nothing. What do I need to do...
This reset procedure might help you.
1. Turn on the printer
2. Press the MENU key
3.
Press SCAN button
4.
Press the COPY button
5. Press the SCAN button then wait until it enters the service mode.
6.
Select NVRAM ACCESS further OK
7.
Select SET ABS-M LEVEL and set value equal to zero
8.
Select SET ABS-R LEVEL (if any) and is set to zero.
9.
Turn off the printer
Aug 09, 2010 | Canon PIXMA MP130 All-In-One InkJet...
My MFC-3240C Brother Printer reads: Unable to Clean. What can I do
Hi you can try
This works with most Brother printers
Procedure how to reset the error 46 error (unable to clean). This can be done on every Brother inkjet machine with a numeric keypad.
- Machine off
- Switch on the machine while holding down the “menu” button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press “99” to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don’t replace this ink box
Also can try.
Reset code.
Press menu then*2864 within 2 seconds (maint should be on the display and all the lights should be flashing, if not try again) press 80
then keep pressing black/mono start button until screen displays ‘purge count’
press 2783 to reset purge count
press stop/exit key
press 99
machine should return to normal
May 10, 2010 | Brother MFC-3240C All-In-One InkJet...
Clean uneable 46 brother dcp 130c printer
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
All the best Pineworks
Apr 28, 2010 | Brother DCP 130C All-In-One InkJet Printer
Unable to clean
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Mar 30, 2010 | Brother MFC-5840CN All-In-One InkJet...
Getting error message CLEAN UNABLE 46
Hi you can try
- Machine off
- press 80
Also can try.
Reset code.
press stop/exit key
press 99
Mar 07, 2010 | Brother DCP-135C Flatbed Digital MFC...
Refilled my black ink but my color ink is empty so it wont print
Apparently I just had the same problem and I managed to fix it! Click on the OK button on the printer to ignore the low ink level error, then you'll be able to print and scan.
Jun 01, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Printer Ink
I had the same problem. The message that came up for me asked to press the resume button. That button is the orange flashing button on the printer. You just need to hold it down until it starts printing. This will disable the ink level display. Hope this helps.
Apr 03, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA MP240 All-In-One InkJet Printer Logo
1,931 people viewed this question
old marine
old marine
