Question about Revell Rc Helicopter Proto Cx Flybar Stabilizer
The battery for the pro to cx won't charge
Battery light doesn't glow
Batteries keep going flat
No it does not, there is no connection.
If the alternator was not charging, your charge light should glow to tell you that. If the charge light is NOT glowing while driving, then you simply have a dying battery which cannot hold a charge for long.
The oil light not glowing when the ignition is turned on shows only that the globe has failed.
Jan 25, 2014 | 1997 Mitsubishi Montero
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
1992 Mazda mpv . Won't hold charge . Engine won't
The first thing to do is have the battery tested, just because you charged it doesn't mean it will stay charged if the cells are sulfated up or shorted.
Oct 02, 2012 | Cars & Trucks
Hi, I have a problem with ti-nspire cx cas, it doesn't charge via a usb cable.
Are you really talking about a TINspire CX or a TI NSpire. The TINspire CX (CAS or Not) comes with a rechargeable battery and an adapter/Charger. You plug the charger in an electric outlet and let it party charge. If the calculator battery fails to recharge then it must be defective. Any third party mini USB charger will recharge the battery.
The TINspire with touchpad (CAS or not) can use regular batteries or the optional rechargeable battery.
It is not necessary to connect the calculator to a computer to have it recharged.
As far as the calculator being recognized by the computer, you must install the communication software (TI computer Link Software for the older TINspire) or the TI Nspire teacher or student software for the CX. When you run the TINspire teacher or student software and then connect the calculator, you will have the opportunity to select it.
Aug 16, 2012 | Texas Instruments TI-Nspire Graphic...
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
THE CHARGING LIGHT DOESN'T COME ON. I CHARGE IT DAILY BUT WENT ON A TRIP FOR 5 DAYS AND WHEN I RETURNED THE LIGHT WON'T COME ON...RED OR BLUE.
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
Good luck from Headsets Direct!
May 23, 2011 | Plantronics Voyager PRO Bluetooth Headset
Purchased the Disney Tangled Glimmer and Glow Lantern. Trying to replace the 3 AAA batteries that it came with - but doesn't work w/ others (tried 2 different brands of batteries - both new) won't...
I had the same problem initially with this toy. I tried to replace the factory batteries with regular AAA alkaline batteries with no luck. I went to a specialty battery shop to try to find the carbon zinc replacement batteries also with no luck. When I got home I remembered that I had a basket full of rechargeable batteries of varying sizes so I thought that I would sift through them to see what I had. I found three of the Rayovac 15 minute rechargeable NiMH 2000 m A h AAA batteries and I charged them up just to see if they would work in the toy- THEY DID!!! I would imagine that any battery like this would work whether it was rechargeable or not- and they're probably a little bit cheaper too. I hope you have good luck making your lanterns sing and glow again too!
May 18, 2011 | Creative Design Disney Tangled Glimmer n...
My '88 F250 4x4 Diesel Won't turn over, Makes a "click" noise when key is turned. Amps are showing low (around 9-10) on the interior gauge... Batteries are at full charge. I've...
probably one or both or your batteries are low or shot, check both of them. Hope this helps-Jim If water in them is low, refill with distilled water, and then charge them. If it still doesn't start, you may need a replacement.
May 13, 2011 | 1988 Ford F 250
Revell Rc Helicopter  Proto Cx Flybar Stabilizer Logo
15 people viewed this question
Top Revell Toys Experts
rhodesworks
Mai Lor
Jim Snideman
Jim Snideman
Level 1 Expert
Are you a Revell Toy Expert? Answer questions, earn points and help others
