Question about Avanti Microwave Ovens
It is new......doesn't work each time...
When I push start button to start to program it doesn't work.you do not hear any beeps
Power but doesn't work
most of the time when button of that type goes out it usually is broke
the push pad button pushed so many times breaks the wire loose from the back side of the button
Sep 03, 2012 | Panasonic Microwave Ovens
Microwave lights up doesn't turn on
The part of the oven called the "magnetron" (this part is what creates/generates the microwave energy that heats the food or liquid) is burned out, the cost to repair is more this part is more than the cost to replace with the cost of Microwaves so depressed by the stagnant economy.
Jan 31, 2012 | GE Spacemaker 1.7 Cu. Ft. Over-the-Range...
How to switch off Demo Mode in JT 379 Micro? Please, help!
Open the door and then push the start button for 5 seconds till you hear a beep.
Jan 29, 2012 | Whirlpool Microwave Ovens
Electricity is on because the colon is showing. But we can't set anything, clock, power, etc. . Cannot program anything. Beeper is beeping for two short beeps around every half hour--.
Hello. Try this. Push the clock button. Then enter the time in hours and minutes, THEN push the clock button a second time. Joe
Please give my answer 4 thumbs up since it is on target and also free to you. Thanks. Joe
Oct 05, 2010 | Danby DMW753 Microwave Oven
POSSESSED MICROWAVE!
wow.......... an exorcism may be in order.......Sadly your microwave circuitry is malfunctioning which is a costly repair. I would seriously consider trashing that possessed unit and purchasing a new one. the new ones are greener too, use quite a bit less electricity
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Galanz (french for ''****'') microwave is sporadically beeping
maybe, just maybe, there is an error code showing....and, most microwaves beep when a button is pushed too...LIVE WITH IT!
Jul 06, 2009 | Microwave Ovens
Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Apr 08, 2009 | Emerson Black Microwave Oven
Sylvania p70d20al-d5 microwave keeps beeping
I have the same problem with my microwave, the clock disappears and it says "enter" and "amt", I figured out it's the "beverage" button that is sticking. When I want to use it I just press "beverage" and then "reset" and just press them over and over until it stops. Usually it's on the first try, sometimes I have to press them a few times. Just don't do what I'm about to type though, I decided to get my razor knife and cut the button out carefully, I only cut the contacts on each side of the button, now no buttons work, I should have left it the way it was, at least I could use it that way.
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave keypad is locked
Touch and hold START more
than 4 seconds. "L" will
disappear and you hear two
beeps. At this time the oven is
ready.
Jul 29, 2008 | Goldstar MV-1615 Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Avanti Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you an Avanti Microwave Oven Expert? Answer questions, earn points and help others
