Question about Conair Deluxe Rechargeable Beard & Mustache Trimmer
The battery doesn't seem to work.
How can I change the battery?
Radio doesn't work on batteries
same problem here, but with my radio shack scanner. When I disconnect the cord, however, the low battery indicator symbol comes on for a bit so radio seems to be taking in juice. May try a better brand of battery or some rechargeables.
Apr 30, 2013 | C. Crane SWP AMFM Radio
Sharp GA219SA doesn't work
If the remote works for sometime once the battery is put into , it means that the circuit is erratic as the frency seems to change from the set value. This can be a fault in the processor IC in the remote, a fault in the crystal or associated capacitors. Check also the IR driver transistor which can be leaking and so changes the output.
Oct 24, 2011 | Sharp GA219SA Remote Control
My TI-84 calculator isn't working. When I press the "ON" button, sometimes it would respond, but most of the time it doesn't. The screen just remains blank. I've changed my batteries...
try taking out the triple A batteries and leaving the calculator to sit with them out for a minute or so, replace them and check if it's fixed. If that doesn't work you can do the same, but take out the small button back up battery as well. If you're still not having luck you should call ti cares (800-842-2737) they're usually helpful.
Aug 09, 2011 | Texas Instruments TI-84 Plus Calculator
My mouse keeps on skipping clicks, I don't know why. The wireless connection seems to be in order and everything else seems fine.
Did you try changing the batteries? If so, try unplugging the mouse receiver and plugging it back in. If that doesn't do anything, how long have you used the mouse? My mouse skips clicks because of my normal use over the years. Might just be the wear and tear to the little clicker button, but try changing batteries.
Jun 22, 2011 | Dynex Wireless Optical Mouse
Battery seems to not charge anymore
you can contact Acer via their website and they will direct you to a local provider or they will send you a replacement.
Jul 15, 2009 | Acer Aspire 5920 AS5920 Notebook
Conair Deluxe Rechargeable Beard & Mustache Trimmer Logo
37 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
