Change TV frequency
How do I reset the TV frequency back to the correct setting? I was trying to retune the TV for SBS (which I still cannot get) and somehow I have changed the set frequency. Now I have no picture. The set-top box remote does not work now so I cannot select the MENU from that. I may have been using this one when I changed the frequency..I am not sure. Tv is Phillips Match111Line Model 32PW8808/79R.
  • 29 Answers
SOURCE: I cannot get a signal on my Phillips 50
if you haven't unplugged the unit for 30 seconds, try that. otherwise, if that doesn't help, probably a board needs to be replaced. call phillips for service.
Posted on Mar 17, 2008
  • 17 Answers
SOURCE: lg lcd tv remote code
Posted on Apr 09, 2008
SOURCE: set top box and remote control
My remote wasn't working until I programmed it to work with itself ... (how odd it wasn't done already).
"CBL" button and ""OK/SEL" held down simulataneously for 3 seconds ... then "001" for the Scientific Atlanta. If the unit turns off, you're in business.
Posted on Apr 22, 2008
SOURCE: Picture Mode reverts always to Dynamic after several minutes
The set was a store demo, and the options were set so they could not be adjusted. On instruction from Samsung I pressed MENU and VOLUME buttons on the side of the set and hold for 7 seconds The display reverts to Standard from Dynamic. The Remote Options button showed Store Demo, but now shows Standard. All memory functions seem to function now. Thanks for your help.
Posted on Jan 17, 2009
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
My tv is only tuning to one chanel-sbs chanel and nothing else! Dont know how to fix it ive tried all i can
hi select dtvmenu go to first installation retune tv hope it works
May 04, 2015 | Televison & Video
Initially looking for logik spport logik tv support. cannot now tune in tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
How to reset Windows SBS administrator password?
Reset Windows SBS administrator password seems to be a tough thing. But don't need to be panic. There are two effective methods for you to reset Windows SBS admin password. The first method may be a little easier than the second one.
Method one: Reset Windows SBS 2011 Password with Windows Password Genius
1. Download iSunshare Windows Password Genius, launch it and insert USB or DVD/CD into your accessible computer.
2. Create a Windows SBS 2011(Windows Small Business Server) password reset disk by USB or DVD/CD. Select right removable device and click "Begin burning" button
3. Insert the USB or DVD/CD into your locked Windows SBS, set Windows SBS boot from USB or DVD/CD.
4. Choose Windows SBS 2011 and user account, Click "Reset password", then "Reboot" computer after successfully reset password to blank
Method two: Reset Windows SBS 2011 Password with Start Disk
1. Restart your Windows SBS 2011 with the installation CD or any USB/DVD you can boot from and get access to the HDD drive.
2. Booted from SBS 2011 media, select Next
3. Select Repair your computer
4. Select your partitions and installed Windows version and click Next
5. Select command prompt
6. Change directory to the access the system 32 directory. Then your original C:drive is changed to D: or E: depending on the number of drive and partitions you have on that system.
7. Rename Utilman.exe to Utilman.old and copy cmd.exe to Utilman.exe, exit and reboot
After the reboot select the Ease of access icon
8. You will get a command prompt and use net user admin user password to change the password
At the user logon screen, press a combination of Windows KEY+U, then the CMD.exe will appear. Type net user "Username""new password"
After you changed the password, exit the command prompt and login in with the new password. Don't forget to change the Utilman.old back to Utilman.exe. It could be that you will need to reboot with your media to change the Utilman back.
Aug 09, 2013 | Microsoft Windows Small Business Server...
TV will not change or show channels
You don't say whether you have had it working at that location before. When you move a TV between houses, it is necessary to retune your channels. Would recommend returning to first time installation.
If you haven't moved it recently there are other reasons why this might happen. 1) There is damage to your aerial caused by weather, 2) A power surge or loss of power to the memory battery on your video board has wiped the frequency information from the memory [the memory battery is like a watch battery that keeps a small amount of power going through the system to it can keep your settings when unplugged], 3) The internal tuner board for your TV has packed in.
If '1' is the case, obviously you need your aerial fixed; if '2' is the case you need to retune again [you'll know if the battery is dead if you have to retune every time you turn on the TV]; if '3' is the case you either need a replacement AV board or someone to solder a replacement tuner board to it.
Jun 17, 2013 | Philips Phillips 40 in. LCD HDTV
How do i tune my digital tv again for some reason sbs channels and some other channels have disappeared from my set
Find the factory default setting on the menu. Select it and then retune your set. That should restore all the channels. By the way make certain the aerial and all leads are good. And bear in mind you need a good quality aerial for digital signals, such as the one below.
Jun 23, 2010 | Televison & Video
My samsung television has no signal now that the change over has happend how do i retune it to get the channels back
enter the menu and look for installtion then choose first time install and it will reset the tv back to factory settings and retune it
Nov 06, 2009 | Televison & Video
How to tune nec 4853
go to to the website for that tv and get the technical support department they will guide you or send you a new one
Aug 15, 2009 | Televison & Video
No digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
