Question about Hasbro Baby Alive Care For Me Doll
The battery area is corroded how do I clean this area in my doll looks like something got the battery area wet and it worked a second or two so I feel like it is repairable
Is parts available
Are 3D printer parts are available in online? Anyone can help?
Now-a-days 3D printers are available everywhere.Many people are using 3d printers But the problem is if printers are broken or any parts broken then you have to get those parts and the fact is those type of parts are not available always.You want a onilne shop for 3d printers parts.Then i can suggest you a best shop.Here.
Shop Easy 3D Printing
Apr 21, 2016 | Office Equipment & Supplies
REPLACED BATTERIES AND STILL DOES NOT WORK
There are a couple of reasons the pony may not work but more information would help. Did the pony word before you replaced the batteries? Some times if you get a new pony (new to you), the batteries in it are old and have corroded. Because the compartment is under the pony, you should probably check and see if the relays and contacts are in good, clean order or if there is corrosion on them. Coke will remove corrosion as will white vinegar. Use a Q-tip. If the contacts are all clean, then you need to check the wiring for a short. You may have to take the fur off to make sure that nothing is broken or touching something metal. Make sure the batteries are installed in the correct order and direction.
May 30, 2014 | Hasbro Furreal Friends Butterscotch Pony
FurReal Lulu kitty batteries corroded and rusted battery compartment. Can compartment be repaired/replaced?
You have to clean the contacts that touch the battery with a metal screwdriver, rub them until the metal shines.
Dec 21, 2013 | Tiger Electronics Toys
Christmas Magic Musical Train
Are/was the battery terminals corroded ? May want to pull the batteries out and clean the contacts. The side for the other functions may be corroded.
Dec 09, 2013 | Toy State Toys
Gear shift broken at transmission
Lot of parts avail in salvage yard & aftermarket trans
wholesalers, the trans shops get things from.
Oct 24, 2012 | 1995 Cadillac Eldorado
Furreal walk in' puppie won't walk
Sounds like either the batteries were not placed correctly or something got wet. Confirm the old batteries did not corrode leaving gunk on the ends of the connections. If they are clean, confirm you are putting them in the right positions. That's usually the issue. If not, you need to call Hasbro's Customer Service through this page
http://www.hasbro.com/customer-service/contacts/
Dec 31, 2011 | Hasbro Toys
Is a parts list available?
Try to check to the product company if they had it's parts available or check from the surplus store if they have some of the parts are available.
Sep 16, 2011 | Dell 2400MP DLP Projector
I am trying to find out what attachments are available for the kenmore KSM035
There are no longer attachments available for this model. See here for available parts:
http://www.searspartsdirect.com/partsdirect/part-model/Salton-Parts/Mixer-Parts/Model-KSM035/0915/0212320/50019525/00001?blt=06&prst=0&shdMod=KSM035
Would need to source from a secondary distributor or find used accessories.
Mar 09, 2011 | Kenmore KSM035 Stand Mixer
Camera will not turn ON at all but batteries are new
With digital camera pretty well taking over from the film cameras a lot of film cameras just sit and the batteries become corroded which leaves a nasty white power in the battery compartment. Your camera takes two CR123A batteries these need to be in the correct orientation or it just won't work.
Look down into the battery compartment and make sure the contacts are clean and without corrosion. I've used lens cleaner on a cotton swab to get down in there and clean it off, don't get it dripping wet just moisten the swab a bit at a time. When there is a badly corroded point then a small bit of sand paper taped to the end of a pencil has worked for me in cleaning up the bad terminal.
Hopefully you don't need to go through the cleaning process and it's just that you have the batteries in incorrectly.
Dec 20, 2010 | Nikon N80 35mm SLR Camera
Need to change engine
All engine parts available at buyautoparts which provides free shipping and parts at discount prices. All parts available with OEM number. Find all parts here. http://www.buyautoparts.com/auto-parts/engine_parts.htm
Oct 30, 2010 | 2000 Hyundai Accent
Hasbro Baby Alive Care For Me Doll Logo
41 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
