Question about Kupa Super UP-200 Nail Drill
Not ruuning overload light on
Not running
What are possible cause fr oil ruuning out ehause when engine is running?
over full with oil, or has the mower been flipped on its side at an incline like going side ways on a ditch bank that can cause it too
Jul 30, 2015 | Garden
I jump the battery let it run take off the cables and try to start dies wont start dies while ruunning
Have you had the battery tested, and have you checked alternator output on the car ?
Mar 05, 2014 | 1999 Lincoln Continental
The DRL sign was lit on my My Honda CRV wat dos it mean?
Daytime Ruunning Lights. It's automatically on, in the daytime.
Nov 02, 2010 | Honda CR-V Cars & Trucks
Royal CIA12 crosscut shredder overload light came on.
Unplug immediately and wait 20 mins to see if motor will "cool-down"...when plugged back in hopefully the Overload light will be OFF....unless you have it completely jammed up in which case try running it in reverse if the overload light is OFF.
If the overload light wont go out you may need pcb...contact Royal at 1-800-524-0799 for further parts assistance.
Nov 24, 2009 | Royal Office Equipment & Supplies
No ruuning lights no dash light
Check your fuse for your tail lamps. GM runs the dash, park, side marker tail and clearance lamps through the same fuse. This way, if the fuse does blow, you know you have no lights, except head lights. Please read your owner's manual for your vehicle. It should tell you this.
Apr 30, 2009 | 1997 Chevrolet Lumina
Hotpoint 8496p fride not working
I had a similar problem with a top freezer and it was discovered that the fan had actually slipped down on motor shaft and was stuck against the freezer wall. Check to see if there is enough clearance for the fan to actually spin.
Jul 22, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Kupa Super UP-200 Nail Drill Logo
107 people viewed this question
Top Kupa Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Kupa Health and Beauty Expert? Answer questions, earn points and help others
