Question about HP PSC 1610 All-In-One InkJet Printer
Lexmark Z11 printer only prints half the letters have changed cartridge cleaned the printer to the best of my knowldedge still the same problem
Change the font used for writing. Try to change the font or type of writing.
Posted on Jun 17, 2009
I need to get instructions on how to properly line up the print heads after installing a new cartridge on my printer, a Lexmark Z11 color printer. Thanks.
In XP - Maybe in Vista and 7 too.
Start
Control Panel
Printer and Fax
Highlight your printer (Z11)
RIGHT click it
Select Properties
Print test page
Follow directions
Dec 22, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Put in new cartridge and unit will not print. Goes through all of the motions but doesn't print. Printed many pages before "low on ink" message. Why does it not print now?
It may be caused by some issues. Check:
* Did you remove the plastic from the connections from the cartridge as the instructions indicates?
* Is the cartridge connector from the printer ok?
* Is the cartridge correctly installed?
* It's a new cartridge? I mean, NEW. Not refilled one or a cartridge that expired two years ago.
* Try running one or two "Clean printer head" procedure to see if ink flows.
Good luck !
Sep 04, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Can't print in color
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Z11 Printe Cartridge Stuck
first push cartridge inside and then try push out side and then keep the cartridge at right place and push it inside after pushing in make sure some green light blinking and start printing it
Feb 25, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Reinstall printer
You can download your driver here:
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Z11+Color+Jetprinter
If you have Vista:
Please note: At this time, Lexmark does not have a driver for this printer which is supported by Windows Vista.
However, people have reported success using the Windows 2000 driver on Vista.
Feb 11, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark z11
Your printer thinks you are using a color cartridge. If have the lexmark printer manager software, go to "install new cartirdge" and tell it that you are using a black cartridge. Otherwise, install a printer driver, reinstall the printer, and set it up again.
Driver link (if needed):
Dec 24, 2007 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
HP PSC 1610 All-In-One InkJet Printer Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
