Question about Homelite ZR10926 16 Chain Saw
Chain turns then craps out, run hot
I have a new home lite 16 in chainsaw. When you squeeze throttle to cut the chain turns a few turns then craps out. It idles o.k.
    Genius:
  • 1,341 Answers
I assume it's a petrol driven probaby 2 stroke? if yes then you need a service on the carb & air filter if the engine is going back ok on idle speed.if it does not & goes off when you release the throttle then you may need to check the compression chamber which might have been damaged by not adding stroke oil in the petrol mixture.Hope this helps and is a 2 stroke engine...
Posted on Jun 15, 2009
I have a huscavarna 435 chainsaw and after running a few minutes the chain locks up
You may have the chain tensioner set a little too tight.
Additional things to check:
  • The sprocket on the end of the guide bar is greased, and turning smoothly.
  • The chain brake is working correctly (not dragging or only partially disengaging).
  • The guide bar is straight, not bent or twisted, burr free, and the groove the chain travels in hasn't been squeezed together.
  • The chain tension is set correctly.
  • The chain oiler is functioning correctly (and you have a sufficient amount and correct type of bar oil).
  • Chain is in good condition, and the correct one for the saw. Make sure all of the links flex smoothly.
  • Chain is sharp. A dull chain will put more pressure on the guide bar because the cutting teeth aren't digging into the wood efficiently (and usually a person pushes harder on the saw when the chain is getting dull).
Chain side tensioning
http://husqvarna.custhelp.com/app/answers/detail/a_id/590/kw/chain%20tensioning%20screw/related/1
Mar 21, 2016 | Husqvarna Chainsaw Model 435 16" inch bar
When go to cut engine is runnig but chain stops when touch the tree
Hi Pam:
Using chain saws takes a bit of getting used to, and it can be DANGEROUS.
- The chain must be sharp to be able to cut properly, and a sharp chain "bites" into the wood.
- Before you touch the chain into the wood, you have to speed up the engine. This takes some getting used to.
- Try this technique: With the chain about an inch above where you want to cut, squeeze the throttle about half way so the chain is spinning. Touch the chain to the wood and increase the engine speed as the chain starts to cut. The harder you cut, the more power you need to apply.
After a while it gets to be second nature.
Work Safe, and get an experienced friend to help with some "hands on" coaching.
Cheers.
Nov 26, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a craftsman 16" 36cc chain saw. Engine
First thing is make sure chain brake is not engaged is so equipped. Next make sure that chain tensensioner is not to tight to allow chain to rotate. I wouuld remove bar and chain from saw and spray both several times with WD-40 and work chain link by link until they all move freely.Clean and lube guide channel on bar and make sure that bar is not dented or badly rusted.If all else fails replace bar and chain. Good luck and thank you.
Mar 14, 2011 | Craftsman Garden
I have an old McCullough chain saw 12 or 14 inch chain length. What is the oil to gas ratio I need to use? 50:1? 40:1? What do you recommend? I can't see any serial number or identifying numbers so the...
Run 40:1 using fresh fuel and a modern synthetic saw oil--mix it in it's own can and be sure to shake the can thoroughly each time just before refilling the tank. Don't mix up more than a gallon unless your business is sawing. You may need to deal with a plugged fuel filter if it won't start. The oiler button was intended to supplement the pumped bar oil when cutting thick/difficult wood. Normally, it is not needed. To start, set the choke full on until you hear a pop, then back the choke off about half way before the next pull (don't forget to set the fast idle button near the throttle--squeeze the throttle, push the button and hold while releasing the throttle). As soon as you squeeze the throttle again, that will release the fast idle, so make sure the engine is warmed up and the choke off before hitting the throttle. This engine will drive a 16" bar and chain, so upgrade when the original parts wear out. Hope some of this helps!
Oct 19, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Throttle Adjustment Hi/Lo idle Calibration
it could be the air to fule mix wrong but if it runs ok i would take a good look at the chain teeth if there even a little bit blunt take a file to the chain and tuch them up,,,,a blunt chain is very power sucking,,pluss you need to pull the chain through the wood,, a sharp chain dont need to be pulled it will cut well just under its own whaite
Jul 01, 2010 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Chainsaw is smoking excessively when in use
White smoke is usually associated with burning antifreeze in an automobile engine, but in this case, trying to cut wet wood might be suspect. The chain must be properly sharpened and the teeth cut toward you on the bottom run of chain. When the chain is properly adjusted, it should not droop from the lower edge of the bar, but no so tight that you can't turn it by hand. Forcing a poor cutting chain into the kerf will overheat the chain and cause it to become loose quickly. Hope this helps!
May 29, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
My home lite runs high when its idling and cuts out when its cutting a tree
Check the fuel filter, air cleaner, and muffler for plugging. Does the engine have fresh fuel mix? The idle speed screw may need to be adjusted CCW somewhat until the chain ceases to move at idle. Have the H and L jet screws been adjusted? If so, turn both screws CW to stops (lightly), then both turned CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and turn H CW until the engine speeds up, yet continues to 4-stroke. Proper setting is when the engine 4-strokes, yet immediately 2-strokes when cutting. Let idle, and adjust L until the engine runs fairly smoothly, but will allow the engine to 'follow the throttle'. Hope this helps!
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
Chain not engaged when the chainsaw is running and brake is off
If the brake is not engaged the only thing it could be is the clutch, or the bar. If the bar is burnt or bent from the chain failing off then you will have this problem. But this sounds more like a clutch problem
Apr 29, 2009 | Garden
16" gas chain saw loses power and stalls
you will need to clean the carb and put new gaskets in it. Make sure it has clean thin oil. Dont over due it on the oil
Mar 31, 2009 | Garden
Homelite ZR10926 16 Chain Saw Logo
242 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
