Question about Safe International Electronic Digital Steel Safe Gun Box Home Office
Forgot the keypad combination of the steel craft safe
Want to change combination.
How to open safe. Forgot combination. Where is batteries to change? Found keys marked for safe but where is lock?
There will be a clip on blanking plate which prises off, generally found on the door between the safe opening knob and the keypad, flip the cover off behind it is the key lock/slot.
Jan 16, 2017 | Home Security
My combination will not open my canon safari 24 gun safe
The Canon safe, if not modified, comes with a digital pushbutton keypad that activates the interior release mechanism. Without exact details (clicks?..buzzes?..beeps?..totally dead?) an answer is hit or miss.
Adding to the obvious..a good battery, no visible damage, forgot the combination, wrong button sequence...
1. the keypad only sends the open signal for the correct combination after keypad is pressed.
2. if it accepts the combination (no error beep), is the signal accepted to unlock.
3. is the interior mechanism trying to unlock.
If you can determine which stage is failing..it will determine if there's a fix.
If all three are working, you hear a little click after..the door/lever may have pressure on it.
If any one of the three cannot be confirmed..no entry with the pad!
Oct 07, 2016 | Home Security
How do change the combination on Brinks Home security saft Model 5074 serial #120.0401A
How do I change the electronic keypad combination on a Brinks Model 5074? This isn't quantum physics, but I sure can't figure it out. Can anyone provide the proper sequence to reset the combination? Thank you.
Sep 01, 2010 | Sentry Fireproof Safe
Changing Combination of Bunker Hill digital floor safe
there is a button on the inside of the safe. press it and enter new combination on keypad. Easy enough
Aug 06, 2009 | Check Point Network Adapter
Want to change 6 key combination on safe to different one
I can't seem to find a product manual for you, but i may be a step closer. Winchester safe's are made by Granite Co.
Here is a site that may be able to help you, they are in Texas, and should be able to provide you with the information you require to change the code.
http://winchestersafes.com/
May 08, 2009 | Computers & Internet
Safe International Electronic Digital Steel Safe Gun Box Home Office Logo
49 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
