Question about Breville BJE510 900 Watts Juicer
Doesnt turn on
Was working perfect! and them turn off I try to turn on again and nothing happen
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
I need instructions for the EHCJ-SE7 easy health cyclone centifugal juicer
Tom,
Thank you so much for that! I was on the verge of tearing the thing apart! Your fix worked perfectly after only five to ten minutes, I stuck a bit of WD40 on the ball bearings as well to try and prevent it happening again.
Cheers,
Nathan
Jan 11, 2011 | Juicers
Hello, and thank you for your time. The juicer was given to me 2 months ago and it's brand new. As of today, some how l can not get it to work. l turned the nob to on, but nothing happens. l opened the...
you have to twist the top round so that the switch is pressed in place so the power can be turned on, from new it takes a few times to get it to click in place this is the safety device so it cannot be turned on by mistake.
Aug 04, 2017 | Hamilton Beach Big Mouth Pro 67600 820.27...
Jak lalanne not working
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
Jan 31, 2009 | Jack Lalanne Power Juicer 250 Watts
Darn thing STILL won't turn on
There is a little knob on pulp collector that pushes in a switch, probably to assure the unit is assembled before operation. Mine broke off. I opened bottom of unit and used electrical tape to permanently engage the switch. The Juicer now works. I consider it poor construction that such an important part of the operation of the unit is able to break off and poor customer relations that there is no help for this on their web site. I have used it only a handful of times and the unit has mostly been in storage and has not been abused.
Jun 11, 2008 | Jack Lalanne Power Juicer 250 Watts
Beaumark juice extractor not working when i assembled it?
Yu have to have the juicer on and properly postioned, it has a little magnet that activates the machine, if it is not on it will not turn on.
Mar 25, 2008 | Champion G5NG853S Household Juice...
Motor not working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
Apr 16, 2007 | Champion G5NG853S Household Juice...
Breville BJE510 900 Watts Juicer Logo
43 people viewed this question
Top Breville Juicers Experts
Greg Cann
Greg Cann
Colin Stickland
Colin Stickland
eyecam
Are you a Breville Juicer Expert? Answer questions, earn points and help others
