Question about LG 32LD350 32 in. LCD TV
Wired headset is connected - LG 32LD350 32 in. LCD TV
How are the speakers wired on a Motorola S9 HD bluetooth headset?
Regrettably we don't have wiring diagrams.
Mark
Motorola Support
Jun 23, 2015 | Motorola Radio Communications
Plantronics CS55 headset.
Greetings,
I also use a headset at work from the same company (Plantronics), If the battery is faulty it will not power and you can't use it.
The wiring has gone bad. Try re-connecting all wires.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Plantronics CS55 Wireless Headset
Logitech headset usb wiring diagram?
Is this what you are looking for?
Jul 10, 2012 | Logitech USB HEADSET H390
My left cup has stopped working in my sennheiser pc 350 headset and I would like to know how to get it working again.
when one of the cups stop working it is a loose wire and you have to identify the wire cut and restore the connectivity ..Usually the cut is near the entry in the headset ..or in side on the mini-speaker ..
You will have to open them up and see where the wire is interrupted
Dec 31, 2010 | Sennheiser Pc 350 Headset Premium Gaming...
My 4pr909 headset wont connect to my phone
not enough information here ot asertain the complete problem for resolution.
Please provide info for the headset connection and phone.
if the headset connect is to large it will not fit to the phone. If the headset has broken wires in the insulation it will not yield sound. Ground and left and rigtht signal from the phone must have a complete circuit in order to completer the sound transfer to the headset. Also if there is a mute function on the headset sound will not transfer.
Aug 05, 2009 | Radio Communications
Broken wire on headset
Friend you need to use a electronic tester and a slodering iron. just solder the cut wires and test if it has connectivity
May 28, 2009 | Logitech (174040) Consumer Headset
My left side of this headset is not working
those wires are very fradgile and chaces are they have snapped inside the jacket
it happens mostly when you pull on the wire instead of the jack or the wire gets caught or stretched --is your jack fully inside the connecter? wiggle the wire and if it sound than it is the wire
Apr 22, 2009 | Logitech Premium (980445) Headset
Shure SM2 Headset/Mic wiring
Headset connection: Blue wire to Pin 2, White wire to Pin 1, Yellow wire to Pin 3. Connect Pins 1 & 2.
Microphone connection: Black wire to Pin 3. Red wire to Pin 2. Ground wire to Pin 1.
I am using a male/female 7-pin XLR connector assembly to black box. I am using two 3-pin XLR connectors, one for SM2 microphone function, one for SM2 headset function.
Jan 02, 2009 | Shure SM2 Professional Headset
Unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Oct 28, 2008 | Jabra T5330 Wireless Headset
LG 32LD350 32 in. LCD TV Logo
16 people viewed this question
