Question about Western Digital Caviar SE WD800JD SATA Hard Drive
CHANGE WD 400BD HD TO WD 800JD HD
IS IT OK TO UPGRADE COMPUTER WITH WD 800JD HD
  • Western Digital Master
  • 9,587 Answers
You can add the drive as an additional drive just by setting the drive jumper to slave with master installed and it will give you another drive letter. https://eshop.macsales.com/Tech/manuals/idehdsettings/WD72.pdf
Posted on Aug 16, 2017
Gatewat CX2724 original HD died (Hitachi 100GB @5400RPM) I just installed a brand new WD 250GB @7200RPM. Since I didn't have the original recovery disk I'm trying to install a full version Windows XP...
if you have a new hard drive you will have to install the windows operating system from an external source such as a cd drive
go to bios --boot settings and change from 1st boot hard drive to 1st boot cd
install the win os and then you can install the rest
when finished go back to bios and -boot and change back to 1st boot hard drive
Apr 24, 2017 | Gateway CX2724 Notebook
I ripped Bluray movies using "ANY DVD HD" to my hardrive then playing them through "WD TV Live HD Media Player" (using HDMI cable to Sony Bravia HD L.C.D.TV) some movies work good but others play the video...
Either check around in Any DVD HD or the BluRay menu to set audio output to PCM, which doesn't require any decoding to play back properly or you will have to convert them separately.
Nov 30, 2009 | Western Digital TV HD Media Player USB...
Cannot sync from Western Digital Passport 320gb HD
try and format using your vista or xp tools,right click on the hard drive go to format and format it as a ntfs drive.
May 28, 2009 | Western Digital 500GB My Book Pro-External...
Wd and Seagate usb hard drives attached to computer Will not boot when WD usb hd on Seagate makes no difference
Check the drive letter assignment for the disks, and make sure it is not the C: driver.
I am assuming you can boot and then plug the disk, right?
So use the Disk Manager to check the driver letter, and change it if it is conflicting with another disk.
Jules
Apr 22, 2009 | Western Digital My Book Essential Edition...
XP freezes on startup from Firewire external HD
This sounds silly but its true...the m-audio 410 doesn't work with windows, especially not with vista. It works on mac but barely. I've been screwing with one for 3-4 yrs now and have gone through a few that died and never had one with 0 problems, always too many to count. It works on macs but barely. it still has tons of problems on the latest and greatest. Bottom line - m-audio is crying because they're totally incompetent at making cards... or they don't give a rats a** about anyone not spending over $500.
Feb 03, 2009 | M-Audio FireWire 410 External Sound System
Installed more ram and now can't find the hard drive
Pull out the new RAM chips and install the old one or ones and see if it boots ok. I had this same problem. This can also be caused by no using matched sets of RAM chips. In my case I added one and used the factory one as well, caused the same issue as you have.
May 19, 2017 | Western Digital Caviar SE 80 GB Hard Drive
HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
Jan 22, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Maximum IDE HD size for HP d530 SFF (Bios 786B2 v1.11 07/10/2003)
no its not a hdd problem, its a mobo problem max u can use is 160 with that pc, what u can try is a bios upgrade and hopefull it helps
go here for the updates:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
choose ur os like xp or vista
than download the updates
Jan 02, 2009 | HP Compaq d530 SFF PC Desktop
Motherboard is not seeing the HD
generally its not a good idea to run both ide and sata drive at the same time.
if you are lucky in your bios it will have a emulate sata as pata/ide drives.
turn this on and be sure to select the ide drive with the OS on it as the master drive so it boots first.
also if you are doing this you will also need to change the jumpers on the sata drive as well to make it a slave and not a master otherwise you will have two master drives and it won't boot.
good luck
smeags
Jan 09, 2008 | Intel D865GBF Motherboard
Western Digital Caviar SE WD800JD SATA Hard Drive Logo
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
