Question about Testors Aztek A320 Workhorse Airbrush Kit - TESA3205
Almost no air will come out of brush, very hard to blow through line
Tried to use this (this has never been used prior to this) and was unable to get it to spray. Then I noticed that even though my regulator is set @ 20 psi it was building up to 50, with very little airflow coming out of the brush. Tried to blow through the hose and it is very difficult. There is a small white piece inserted in the hose where it connects to the air sours that has 2 smallish holes on the side. Where should I look next?
  • 700 Answers
Do solve problem by elimination:
1 disconnect pressure regulator from supply, start compressor and check for air flow, if flow is good, switch off
2. connect pressure regulator and start compressor, if it is equipped with automatic stop/start check cut off by closing valve in full, if it is without automatic stop/start then open slowly valve and check for air flow, if it increases - no problem there either, switch off
3. connect your hose to the outlet and switch compressor on, you should have similar pressure on the end of the hose as it was after regulator. if pressure is much lower - check for blockage in the hose, maybe gasket or something in the tube, cheap and nasty hoses have tendency to "k i n k" (this common english word describing twist in hose preventing liquid or gas flow is regarded as profanity by fixya - stupidity is without borders...) and puncture, clean or replace the hose, i use on some of my airbrushes these little lines from surgery (blood transfusion, oxygen, aquarium air, they are perfect! and - much cheaper - mostly for free than special airbrush lines).
4. check flow on airbrush, on fully open valve should be not much less than it was coming from regulator, if there is little or no flow, increase flow on the piece, it have usually depending on the type needle regulator on the valve.
hope this short instruction will help you, enjoy your art and if you find it useful, feel free to vote for it...
Posted on Dec 22, 2014
I have a 2005 Ford F-350 and it only blows thru defrost vents cold.Tried all vent flaps and sre free of abstructions what could it be.....
The air flow is directed by vacum. If you have a 4X4 with ESOF hubs, then I would inspect the vacum lines to the hubs for any signs of cracking etc. If it's a 2WD then it's time to start looking at the vacum lines under the hood. Ford likes to use hard plastic lines that get brittle and crack.
Sep 28, 2011 | Cars & Trucks
P 0411
DTC P0411 is most often caused by a bad Secondary Air Injection pump or a bad Secondary Air Injection solenoid valve . Disconnect the air pump hose at the solenoid valve, start the engine and see if there is air being pumped out. If not, the pump is bad.
If there is air being pumped out, unplug the vacuum line at the solenoid valve and remove the valve. Blow through the valve. You should not be able to. Now apply vacuum to the valve and blow through it. Now you should be able to. If not the valve is bad.
Make sure the vacuum line is fully seated, against the stop, on the solenoid valve. In some cases, the vacuum hose leading to the solenoid valve for the Secondary Air system may not be fully seated on the Combi-valve tube.
I tried to give you an image but am unable. I hope this helps anyhow. Good luck.
Feb 05, 2011 | 2000 Volkswagen Jetta TDI
My 2008 carolla starts good runs a second or two, then stops
TOOLS NEENED ......
FLATE BLADE SCREW DRIVER/STAR SCREW DRIVER/10MM/ QUARTER IN DRIVE RATCHET WITH 5 INCH EXTENTION/CARB. CLEANER OR INTAKE CLEANER/LAXTEX GLOVES./ TOOTH BRUSH
SPECIAL TOOLS REQUIRED ( AIR COMPRESSOR) WITH BLOW GUN
WEAR SAFETY GLASSES WHEN PERFORMING THIS TASK!!!!
START BY CHECKING ALL VAC. LINES/HOSES
MAKING SURE ALL IS CONNECTED.
IF ALL LINES LOOK AS IF THERE FITTED OK.
NEXT REMOVE AIR INDUCTION SYSTEM , THIS IS THE PARTS START
AT AIR FILTER BOX AND IS FITTED TO THROTTLE BODY.
REMOVE THIS PART( THERE WILL BE A WIRE GOING TO THIS PART(MASS AIR FLOW SENSOR) CARFULE NOT TO DAMAGE, UNCLIP WIRE GOING TO SENSOR.
NEXT LOOK IN SIDE THROTTLE BODY NOTICE THERE IS A BUTTERFLY TYPE PLATE.
YOU WILL NEED TO PROP. THIS PLATE OPEN , THIS IS DONE BY USING YOUR FINGER(CAREFUL NOT TO HURT YOUR SELF)
YOU CAN USE A SCREW DRIVER TO HOLD OPEN BUTTERFLY
MAKE SURE YOU DONT USE A POCKET SCREW DRIVER , YOU NOT WANT IT TO FALL IN THE INTAKE SYSTEM.
YOU MAY NOTICE THAT THERE IS A SMALL HOLE NEAR BUTTERFLY
TAKE CARB./INTAKE CLEANER AND SPRAY IN THROTTLE BODY/BUTTERFLY/SMALL HOLE.
TAKE SOFT TOOTH BRUSH AND LIGHTLY BRUSH AROUND BUTTER FLY AND AROUND MATING SURFACE OF BUTTERFLY, USE CLOTH TO CLEAN CARBON ( TRY TO GET THIS CLEAN AS YOU CAN , USE CARB. CLEANER.INTAKE CLEANER THREE OR MORE TIME.( ALSO SPRAY IN WELL VENTALATED AREA.
AFTER CLEANING REALLY WELL !!!!!
TAKE AIR LINE WITH BLOW GUN AND BLOW OUT THROTTLE BODY, MAKING SURE YOU GET ALL OF THE CLEANER/CARBON OUT.
ALSO BLOW IN SMALL HOLE( NOT DIRECTLY ON HOLE BUT NEAR HOLE.
NEXT STEP. IS TO PUT AIR INDUCTION HOSE BACK ON , MAKING SURE YOU PUT HOSE OVER THROTTLE BODY AND SECURING WITH FASTENER AS WELL AS OTHER END GOING TO AIR FILTER BOX.
RECONNECT ALL VAC. LINE/HOSE TO THERE ORIGNAL LOCATION
RECONNECT WIRE GOING TO MASS AIR FLOW
NOW TRY STARTING VEHICLE , MAY TAKE A FEW TIMES TO CLEAR
ALL THAT CLEANER THAT YOU SPRAY IN INTAKE.
IF RUN , YOU MADE A FIX!!!
IF STILL HAVE A PROBLEM MAY HAVE PROBLEMS WITH MASS AIR FLOW SENSOR.
GOOD LUCK!
Apr 24, 2010 | 2008 Toyota Corolla
How do professionials clean ventless propane heaters?
A can of air, vacuum and a long thin brush. Blow out any debris in burners and at the pilot assembly while running the vac. Brush all parts you can get too. Unscrew the pilot line from gas valve and blow in tube with can of air. Fire up heater and check for CO.
Jan 24, 2010 | Desa International GWP20T GLOWARM Wall...
2.2L 2000 s10, AC blows hard at idle but when rpms go up air blowing out goes down., not sure why
Two ideas--either the alternator loses efficiency at speed causing voltage loss (may be bad brushes) or the engine is losing vacuum at higher RPM's causing an air flow control valve to change position.
Oct 12, 2009 | 2000 Chevrolet S-10
Not blowing cool air on my Ruud, 18 years old, outside unit.
If you have ice on the Line you are iced up. If coil is iced no air can get thru. Now First. Turn of ac and turn fan to on posotion. That will thaw unit. Let it run 45 minutes. That should do it. If the fan is not running you amy have a bad fan relay. One of the reason iced up unit is dirty evap, coil inside. Try to thaw it out first. You can clean the coil with a stool brush. Does not damage the coils. Good luck
Jun 07, 2009 | Ruud UBHC Air Conditioner
Air in fuel line?
get a container with fuel(about 4 liters will do). put a hose from the Primer to the fuel container and another hose from the injection pump return line to the container. if it works fine then the air leak is between the tank and the primer.
Jun 03, 2009 | 1987 Mitsubishi Passenger
No Disc
It could be some dirt & dust on laser lens. Did you try to clean it?
Oct 10, 2007 | Philips HTS3450 System
RC3000 cannot return to the base smoothly
Mine was doing the same thing.  Turned out to be dust that had gathered inside preventing the electric eyes (ir sensors) from work well.  Carefully using some lock ring pliers turn the three grey fasteners 90 degrees counter clockwise.  Then lift off the yellow top cover.  Using an air hose or soft brush clean the sensors sticking up from the circuit board.  Be careful not to bend the out ones has they are not hard mounted.  Then also clean the inside of the IR windows on the yellow top cover.  While your at it take the time to blow out all the dust from the unit.  You should remove the inner screen prior to using compressed air so you can blow out the vac fan itself.  About every six months I do this or when it starts to act weird.  You should blow of all sensors on the base unit also.
Keith
Jun 28, 2007 | Karcher RC3000 Bagless Robotic Vacuum
Testors Aztek A320 Workhorse Airbrush Kit - TESA3205 Logo
628 people viewed this question
Top Testors Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Testors Air Tool and Compressor Expert? Answer questions, earn points and help others
