Question about Toshiba 50HP66 50 in. Plasma Television
Turn of on it's own
My Toshiba 50HP66 50 turn of on it's own, I'v reset all setting to default.
and my side control panel does not workink with the proper buttons. to turn the tv back on I have to press to volume control on the side panel and after a couple hours, everything comes back to normal.
I'v Toshiba and they have to replace the controler board and video board.
It is an hardware problem
Posted on Nov 12, 2007
Fridge keeps powering on and off
Your controller board is about to die. Call an appliance repair center and see if the board is user replaceable. Be prepared for sticker shock, the part is going to be expensive, unless it is under warranty.
Mar 19, 2014 | Electrolux EI26SS55GS Stainless Steel ...
Tip
Set firefox as ur default browser
Windows 7 and Vista
  1. Click on the Windows logo to open the Start menu, then select Control Panel. The Control Panel window will open.
  2. Click on the link labeled Programs. The Programs panel will open.
  3. Click on the link labeled Set your default programs. The Set your default programs panel will open.
  4. In the Programs list on the left side of the window, click Firefox.
  5. In the right side of the window, click Set this program as default.
Windows XP
  1. Click the Start button, then click on the Control Panel icon to open the Windows Control Panel.
  2. Click the Add or Remove Programs icon to open the Add or Remove Programs applet.
  3. On the left side of the window, click the Set Program Access and Defaults icon.
  4. Click on the Custom radio button to expand the Custom category.
  5. Underneath Choose a default Web browser click the radio button next to Mozilla Firefox.
  6. Click OK at the bottom of the window.
if it helps u...pls vote
on Oct 03, 2010 | Computers & Internet
Restore Sony KDL32L5000 to factory defaults
• Check the input selection by pressing the INPUT button. You may be watching the wrong input.
• If you cannot hear sound from the TV, you may have accidentally pressed the MUTING button on your
remote control; press the MUTING button again or press VOL + to deactivate muting.
• If the remote control is not functioning properly, the batteries may be installed incorrectly or may be low or
an object or light may be interfering with the remote control.
• To reset the TV to factory default settings:
1 Turn on the TV.
2 Press and hold down the V button on the remote, press the POWER button on the TV set. (The TV
will turn itself off, then back on again.)
3 Release the V button when the TV is turn on.
WARNING: The factory reset will clear all of your customized settings including the Parental Lock setting.
When the Password is lost or cannot remember, enter the master password: 4357. This password clears your
previous password and allows you to enter a new password.
Jul 08, 2012 | Sony KDL32L5000 32 in. LCD HDTV
Remote control brocken and dont know how to turn on tv without it
hi,
just press the power button or channel up button or down button on the pannel of your tv.
ok
Mar 07, 2011 | Toshiba 37C3030D 37 in. LCD Television
Trying to reset the settings for my toshiba model27a45
Hello
It is easy to reset your Toshiba set to factory defaults. Enter each options, ie, picutre, sound etc, and press "Reset" button on your remote control to reset each options to factory settings. The default factory settings for Video is DVD. Ok.
Jan 07, 2011 | Toshiba 27A45 27" TV
Does the RCA TV Model G27400WK, Serial No.234550152 have a reset button and where would it be located?
try these steps
On occasion, an RCA television may need to have certain options reset in order to restore default settings. Software resets, such as resetting the Picture Control, the Parental Control lock and the Wake-Up Timer, can easily be restored to the default settings by accessing the settings menu via the remote control. A Hard Reset is recommended if there are hardware problems with the TV, such as a loss of picture or if the TV isn't turning on properly.
if that doesn't work try these steps
  • Unplug the TV's power cord from the electrical outlet.
  • Wait 5 minutes.
  • Plug the TV's electrical cord back into the electrical outlet. If this does not resolve the problem contact RCA Customer Support or a local technician store
  • Jan 04, 2011 | Televison & Video
    Turn tv off wont turn back on ! Model#32AV502R TOSHIBA
    Notes from user manual: http://www.tacp.toshiba.com/tacpassets-images/models/37av502r/docs/37av502r_om_e.pdf
    Unplug the TV for about an hour to see if it will reset itself, if not, try:
    TV stops responding to controls:
    If the TV stops responding to the controls on the remote
    control or TV control panel and you cannot turn off the
    TV, press and hold the POWER button on the TV control
    panel for 5 or more seconds to reset the TV.
    Reset Factory Defaults
    To reset all settings and channels to their factory
    default values:
    Press and open the Setup menu.
    Highlight Installation and press . A new set of
    Installation menu icons will appear.
    Open the System Status menu, highlight System
    Information
    , and press .
    Press tu to scroll through the menu bar to select
    Factory Defaults.
    Enter your PIN code (or 0000 if no PIN code has been set).
    Highlight Yes and press . The TV will turn off
    automatically after a few seconds. After the TV turns off,
    unplug the TV power cord and then plug it in again to
    complete the reset process.
    To cancel the reset:
    Highlight No and press .
    Otherwise you may jhave bigger problem inside the TV.
    If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
    Please see my basic troubleshooting guide here:
    http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
    http://s807.photobucket.com/home/budm/allalbums
    http://en.wikipedia.org/wiki/Capacitor_plague
    Parts: www.shopjimmy.com
    Please post back what you find.
    Jul 23, 2010 | Toshiba 32AV502R LCD TV
    How to unlock child?
    i think but im not sure but its worth a shot. turn the tv on then press and hold the power and action button on the set for 5 or 6 seconds this should reset the television and run a diagnostics test proceedure
    Regards
    Xeeshan
    Nov 22, 2009 | Sanyo DP32746 32 in. LCD Television
    How to reset the default value for the toshiba sd 6100 dvd player
    If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
    Jan 25, 2009 | Toshiba SD6100 DVD Player
    PocketPC e570, Is there an opportunity to set it back to factory default?
    you could set back the e570 factory default very easily. On the left side of the pda you could find a small button, called RESET button. You have to do these following steps: The pda have to be turned off, then press the power button while pressing and holding the reset switch with the stylus, release the power button and when a screen appears, release the reset switch. But be careful, when you reset your pda all data will be lost and make sure that all storage cards are removed!!!
    Sep 11, 2005 | Toshiba Genio e550
    Toshiba 50HP66 50 in. Plasma Television Logo
    147 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
