Question about Triumph 400T Treadmill
Treadmill will not start
I plug it in but it will not start
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Exercise & Fitness
Can you advise please
reset the machine make this: God bless you
    • 3
    • 4
    • 2
Nov 28, 2013 | Precor 935 Premium Series Treadmill
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Nov 13, 2013 | Cadence Exercise & Fitness
My treadmill wont re-boot
follow this steps and fix it. God bless you
    • 3
    • 4
    • 2
Nov 11, 2013 | Epic A30T Treadmill
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Nov 03, 2013 | Proform 695 LT Treadmill
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
Fitstride t920 treadmill faults
Reset the machine follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
· 2
· 3
Oct 07, 2013 | Exercise & Fitness
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
  • 2
  • 3
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
I plugged in my Pro-Form 730cs treadmill and it won't start.
My i FIT treadmill won't turn on. Is there a reset button somewhere?
Aug 28, 2009 | Proform Quick Burn Pro Treadmill with 12...
Triumph 400T Treadmill Logo
80 people viewed this question
Top Triumph Exercise & Fitness Experts
Mike
Mike
Electro Med Services...
Tom Chichester
Are you a Triumph Exercise and Fitnes Expert? Answer questions, earn points and help others
