Question about Tommy Bahama Clothing Accessories
How does the eyeglass strap fit over the bows titmus155 frame
Strap is black with white. And brown stripes.Hagerstown plastic end caps that do not bend or move and opening is smaller then bow end.
Kimi
  • 277 Answers
SOURCE: Calvin Klein K7111 brown watch strap
try here: http://www.a1watchbands.com/ for example: http://www.a1watchbands.com/product_details.php?search=&id=712 or try on ebay, for example: http://search.stores.ebay.ie/calvin-klein-strap_Watch-Parts-Accessories_W0QQcatrefZC6QQsacatZ10324
Posted on Aug 17, 2006
escapement
  • 2334 Answers
SOURCE: Emporio Armani AR0532 Sports Watch with rubber/plastic strap
Here is a link to Emporio Armani Watches (paste it into your browser):
store.emporioarmaniwatches.com
/products/H45820.jsp
- Cached
Click on your model, then click on Customer Care tab. Here you can send an email or even contact online or by phone and get your strap sorted.
Don't forget to rate, please.
Posted on Jan 05, 2009
  • 30 Answers
SOURCE: Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Posted on Apr 12, 2009
  • 512 Answers
SOURCE: Power cord replacement (3 prong to 4 prong)
Your new cord has 4 wires. Black, red, white , green.
The dryer has 3 lugs to connect to. Connect the white and green to the center lug, connect the red to left lug and the black to the right lug. You are all set to use dryer.
Posted on Jun 07, 2010
mcdevito75
  • 1970 Answers
SOURCE: watch strap a little big
mcdevito75 here, Maybe a link or 2 can be reoved from the metal band, or an adjustment at the clasp can be done. Look for a small watch repair shop in your area, they can help.
Posted on Jul 09, 2010
How do I install the 4 prong electrical cable to the dryer?
I would attach the black wire to the black & yellow, white to white, red to blue & brown. The green wire is your ground wire and needs to be attached to the cabinet. On the connection where your white wire is located see if there is a copper strap that goes from the terminal block to the cabinet. If there is, you will need to remove that strap and attach the green wire to where the strap was attached to the cabinet. Hope this helps!
Sep 16, 2014 | Dryers
Tip
How to change your dryer from 3 wire to a 4 wire power cord. (short and simple)
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
on May 23, 2009 | GE DBSR453EBWW Electric Dryer
Jun 06, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a 30 amp conversion cord with 4 wires and 3 terminals. What wire goes where?
Oct 04, 2009 | Hotpoint TDC32 Electric Dryer
How to install a 4 wire cord on a 3 wire dryer
This is a common question we receive and a common mistake most every general contractor makes that we work with. With a 3-wire system your neutral terminal will have a copper clad or aluminum strap or green wire connected between it and the frame. You need to remove this when changing to a 4-wire cord.
Terminate the wires from your new 4-wire cord as black to black terminal, white to white terminal, red to red terminal and green to ground screw on frame. This is the other end of that strap or green wire you need to remove from the white (neutral) terminal.
When changing to a 4-wire cord it is very important to remove the strap or wire that connects between the white terminal and the dryer’s frame. If you do not remove this, your neutral or grounded conductor will allow electricity to flow through your dryer’s frame and shock you each time you touch your dryer.
Jul 15, 2009 | GE DCSR483EA Electric Dryer
4 prong power cord to a 3 prong monunt I'm trying to replace a 3prong cord with a 4 prong but there is an extra wire, what do I do with it?
May 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
How do I access the rear inlet fitting to change the fuel filter on a 1997 F350 crew cab with the 460 and dual tanks?
okay let me clarify the fuel filter if its on the frame will have a strap attaching it to the frame usually remove with a 10mm socket and an extension and rachet.on the ends of the filter you will either have a flare fitting(usually 14&16mm) wrench or a black cover with a white clip push hose toward filter pull out clip wiggle off.if its too hard for you to get to remove the shield other wise if your a contortionist it should be easy
Apr 05, 2009 | 1997 Ford F350 Crew Cab
WV-57H Watch - how do you replace the strap? I have a new strap for this model and can't work out how to take the old one off and fit the replacement. Thanks
If you look at the watch from the side, you'll see that there's a two-part metal piece on the underside of the watch on each side.  The metal piece is a spring-loaded pin going through the strap which is holding on a larger metal piece.  You need to get another small pin (or an eyeglass screwdriver might work) so you can poke in the end of that spring loaded metal piece, which will allow you to slip off the larger metal bracer.  Then you can poke the spring-loaded pin entirely out of the strap and it will be freed entirely.
To help you visualize what you are doing, the spring-loaded pin operates similarly to a toilet-paper roll - you need to compress the pin so you can slip off the larger metal bit, then take out the pin, which will free the strap.
Oct 30, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Chrysler Part No. P56038933AB Radio Wire Color code
1982 to 2001 wiring harness color code Chrysler.
12V constant pink or pink/white stripe
12V accessory red/white stripe
Antenna/Amp turn on white
12V Illumination black/yellow stripe
Left front + dark green
Left front - brown/red stripe
Right front + purple
Right front - blue/red stripe
Left rear + brown/blue stripe
Left rear - brown/yellow stripe
Right rear + blue/ orange stripe
Right rear - blue/white stripe
there is no ground wire in the harness, the metal braided strap is the ground.
use a ring terminal,speed clip, and screw to attach the ground wire from new radio
when replacing infinity radios and speakers, there are 4 wires instead of 2 at the speaker plug. the large gauge blue and black wires are the power supply for the amp, the other 2 are signal wires from the deck and will match up to the wire color codes above. simply cap off the power and ground and use the other 2 for speaker leads.
One thing i hate to see is someone who just hacks off the plugs behind the radio because they are too cheap/lazy/dumb to buy a wire harness adapter for the nice new aftermarket deck they just bought. ive seen everything from masking tape to house wire nuts used to connect wires, and they never last.
there is only 1 reliable permanent way to connect wires together - SOLDER AND SHRINK WRAP!!! whether you're connecting wiring for a radio, fog lights,repairing a cut wire, etc solder those wires, you'll be glad you did when you never have a problem with that circuit again.
This is a listing for part #'s for dash kits wire harness adapters
all part numbers are metra unless otherwise noted
dash kit 99-6700, 99-6701 and 99-6500 will work for most cars
wire harness adapter 70-1817
reverse harness( to replace factory plug that have been cut off) 71-1817
speaker adapter plugs 72-6510, non amped 72-6513 when equiped w infinity system and bypassing fact amps
no antenna adapters are required until you hit 2002 model year.
beginning in 2005 chrysler switched to a high speed LAN system in all its cars and trucks. there is no longer a switched ignition lead in the harness.
Good Luck
Leadispenser
Aug 25, 2008 | Kenwood KDC-MP235 CD Player
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Clothing Accessories Logo
29 people viewed this question
Top Tommy Bahama Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Tommy Bahama Clothing Accessory Expert? Answer questions, earn points and help others
