Question about Refrigerators
Kelvinator ulg50bd drain pan?
How do i drain the base pan of a kelvinator kd12mm1
Kelvinator believes you should be able to remove it and dump contents into a drain. In real life you may have to sponge up contents, then remove and clean the empty pan.
Jul 03, 2017 | Kelvinator Refrigerators
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
I have a Kelvinator impressions series 390 fridge(no freezer) it keeps icing up and then thawing all over the floor. I have it set just left of "Mid". Can you help,it is driving me crazy!!!
There should be a drain tube that allows the freezer to drain into a pan under the freezer. Over time, the drain tube can become plugged with dust and food debris. Try clearing the tube and it may just take care of itself.
Feb 27, 2011 | Fisher and Paykel Refrigerators
I have water dripping from the front of my airconditioner model R51K/BGE Electrolux Kelvinator
Check air filter, cooling coil and also drain pan for dust blocking. Clean it.
If
Dec 02, 2010 | Heating & Cooling
THE FRIDGE IS LEAKING WATER FROM THE INSIDE AND RUNNING OUT THE FRONT OF THE FRIDGE
Hello
There is a drip pan under the evaporator coil. This pan is to catch the condensation dripping off the coil. Then the water goes down a drain hose to a re-evap pan. That all being said. What's the problem you have? The first thing I look for is to make sure the hose is still connected to the drip pan. The next and most ofter is the problem is a clog in the drain hose or where the hose connects to the drain pan. We use compressed gas to blow out the clogs.
I would also check the pan for cracks or holes. This should take care of your problem. Also make sure the door and gasket is sealing to keep air and moisture from getting in and making the condensation problem worse.
I hope this helps you. Please leave feedback.
Thank you.
Aug 24, 2010 | Kelvinator Refrigerators
Hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
How do i drain a drip tray in a kelvinator opal fridge
you should not have to drain the pan,water should evaporate,check for leaks from water lines
Jan 10, 2010 | Refrigerators
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
