Question about MGA Entertainment Bratz Secret Stylin' Safe
Bratz secret stylin safe
Need the directions to set password
Tip
Lock and Unlock most TV's
http://www.ecoustics.com/tl/17973/
Polaroid:
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
0000, 1078, 1111, 3808, 5050, 8202.
Mitsubishi LCD TV:
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view
a V-Chip locked program, view the locked TV, cancel
the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked
TV without entering your passcode. When your
password is requested, press the number 9 and QV
buttons on the remote TV control at the same time.
This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process
deletes your old passcode and prompts you to enter a
new passcode.
AOC: 0,0,0,0
LG: 7,7,7,7
PHILIPS: 0,7,1,1
SONY: 4,3,5,7
VIZIO: 0000, 2489, 5351, 8202, 8205, 8206
Emerson/Sylvania/Funia: 0000
NOTES from Emerson/Sylvania/Funai:
1.Make sure to enter the exact same new password in the
"Confirm Password" space as one in the space. If they are
different, the space is cleared for reentering.
2. Your password will be erased and return to the default(0000) when a power failure occurs or this TV has been
unplugged for more than 10 seconds. If you forget the password,
unplug the power cord for more than 10 seconds to
restore the password to 0000.
Sharp TV:
Sharp LCD TV Clearing the secret number using the remote buttons and the TV's buttons.
If you forgot the secret number, clear the secret number using the following procedure:
1) Press MENU, and the MENU screen displays.
2) Press Left/Right arrow buttons to select 'SETUP'
3) Press UP/DOWN arrow buttons to select 'EZ setup', 'CH setup', 'Parental CTRL' or RESET, and the SECRETNUMBER INPUTSCREEN DISPLAYS.
Press and Hold both CH UP and VOL+ ON THE TV SIMULTANEOUSLY until the message appears on the screen. The SCECRET NUMBER IS ****.
on Aug 17, 2010 | Televison & Video
How to retrieve Cisco router password without losing configuration?
You can't, otherwise there would be no point in having a password would there!
Dec 24, 2016 | Cisco Computers & Internet
Cannot open my secret safe by justice
Reference: Paisley Electronic Push Code Safe
Item # 5661462
Purchased at Justice. May be one of the following design/colors: 1. Pink and black 2. neon green 3. tye-dye (all in zebra pattern, I believe)
To gain access to safe without code proceed with the following simple instructions:
Use a screw driver to access batteries on the bottom of the safe. Remove all three AA batteries.
WAIT AT LEAST TEN SECONDS before reinserting betteries to functional position. Replace screw. Key in default passcode "0000#" Safe will now be unlocked and upon opening you can reset passcode. Hold down the "*" and when voice prompted to "key in passcode" enter new 4 digit code followed by the # sign... HOLD "*" until completed code with "#" You will hear the voice command, "enter passcode" after each digit entered. [Press & hold "*" (1234) press "#" release "*"] Close safe and new passcode should be set and work properly. If not, enter default "0000#" and try to reset once again.
Feb 03, 2014 | Toys
I gave mine to a friend to use on Skype but it says the webcam cant be detected.
Have your friend go to the Be-Bratz web cam instructions web page, and follow the directions to download and install the drivers and set up the camera.
Here are the directions from the web site:
Installing Driver Software
  1. Click the Download Webcam Software button and save the file to your computer.
  2. Double click on the file PC_Camera_1043W_070328.exe to start the installation.
  3. Follow the steps in the installation wizard.
  4. Once the software is installed you should be able to use your Webcam.
Note: If the camera does not work or the PC cannot detect it, please refer to the troubleshooting section in your Be-Bratz.comâ„¢ Webcam manual.
Here is the link to the software: Download the webcam software
Dec 30, 2010 | MGA Entertainment Be-Bratz Webcam
Please give me .....TV SHARP Password???
.sharp X Flat Slim TV model number 21G-FX35 i lost my password please tell me its master password
Nov 27, 2010 | Sharp 27C-240 27" TV
Loud
There is a power management mechanism on the side opposite of the power switch that looks like a circle with a **** in it. To set this to the optimum setting, plug the trimmers in and cut it on. Next, your going to use a flat head screwdriver to turn the knob clockwise until it clatters continuously. Next, you turn the know back in the other direction slowly until the clattering stops altogether. Now, the "noise" should be gone and your trimmers are set to perform as they did when you first bought them.
Aug 10, 2009 | Andis Styliner SLII Hair Trimmer
Nutool sf20 safe
I need an instruction Manual for a Nutool sf20 safe
Jul 15, 2009 | Computers & Internet
Need to change password but dont remember the one that came with it
you need to call up the bratz tv inernet site and say password for bratz tv it might give it to you
Jun 07, 2009 | MGA Entertainment Bratz TV
MGA Entertainment Bratz Secret Stylin' Safe Logo
21 people viewed this question
Top MGA Entertainment Toys Experts
Andrew Taylor
Andrew Taylor
Are you a MGA Entertainment Toy Expert? Answer questions, earn points and help others
