Question about WYSE Computers & Internet
Wyse D10Dp reset
How to reset to factory default on a WYSE thin client 1125se
The simplest and most often used method is using Wyse Simple Imager in a PXE setting. This is how most large enterprises deploy images to Wyse terminals.
If this is not an option, there are some other options available. Please refer to this website for some home-brew solutions:
http://www.freewysemonkeys.com/modules.php?name=News&file=article&sid=55
Oct 03, 2012 | WYSE Winterm 1125SE Network Terminal
Wyse terminal does not boot
It should seem to be a hardware side problem.
Jun 04, 2008 | WYSE Winterm 3150SE Network Terminal
Connection reset by peer
is this a citrix environment? have you just applied a rollup pack to your terminals?
You need to speak to Wyse!
Apr 27, 2009 | WYSE S10 (90210501) Network Terminal
How can i reset S30 wyse box
Try a G-key reset.
Failing that use WSI and an S30 image from the wyse Website.
WDM also has the option to to re-image the client.
You may also be able to get into the control panel of the terminal, and download an FTP image and set the terminal to upgrade from the image when uploaded to your ftp site. From the control panel, you can initate the upgrade manually
Mar 24, 2009 | WYSE Winterm S30 Thin Client - Thin Client...
The wyse 50 terminal does not work properly
Wyse 50/60/150/160 monitors were my specialty!
From what you were explaining it seems to me that you have a bad internal battery and it needs to be changed and a factory reset/ calibration needs to be performed.
I can repair wyse terminals at my facility if you like. The repair cost is not that high and we can also perform the regular repair and adjustments on all wyse monitors if needed.
Please contact me if you have any questions.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Mar 18, 2009 | WYSE 50 Terminal
How can i reset the bios password of my wyse vx0 machine?
wyse model no vx0 bios pssward remove videos
Jan 09, 2009 | Computers & Internet
Reconfigure winterm
try holding down the 'g' key when booting -this just worked for me.
Aug 11, 2008 | WYSE Winterm 3150SE Network Terminal
Hard Reset
Youch, thats a pickle!!
Basically, because the terminal is in loopback mode when in the OS, you would need to find an up to date .i2d file, and for the S10, then try and re-image it with Wyse Simple Imager. This will use PXE and DHCP option tags to grab the device, and push an image to it.
Make sure PXE is first in the boot order in the BIOS, people often forget this!!
All the software you need (apart from the i2d file) is available from the Wyse website. When it comes to the i2d file, you will need to contact Wyse directly to get hold of this.
http://www.wyse.com/serviceandsupport/support/downloads.asp
Jun 04, 2008 | WYSE S10 (90210501) Network Terminal
Computers & Internet Logo
87 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
