Question about Pioneer DVD-V555 DVD Player
What format DVD do I use for burning movies?
DVD +R DL or DVD -R DL for this machine?
0 characters
1 Points
Will the lg bd-390 play burned dvd-or+r,s or rw-dvd's?
The LG BD390 should read DVD+/-r if they are finalized. he same is true of DVD-rw discs. However, a lot depends on the burner and software you use for the burn. This unit will only support video mode, VR mode and AVHCD formats. It will also support DVD+R DL discs.
A lot depends on the movie and audio file codecs that you use to burn the disc. For a complete list of discs that are supported, see the manual. It's available here: .
I hope this helps. Please add a comment with the software and hardware that you are using to convert and burn your video for additional help.
Mar 28, 2013 | DVD & Blu-Ray Players
After I purchase a DVD Movie from iTunes I try to burn the movie onto a dvd and the download onto dvd seems to complete but it will not plat when I put into my Samsung V5650. Any suggestins?
yes you must read the instruc manual for to see which format your DVD read only. download your instr.manual www. or www.
In that way you must download the format o.k or use in internet converter for your properly format DVD.
God bless you
Jul 12, 2012 | Samsung DVD-V5650
Why Philips dvd player won't play all dvd movies?
This is not a fault. Some movie burned formats might not support the player.
May 23, 2012 | Insignia IS-DVD1001 DVD Recorder/VCR
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
I downloaded a movie on my computer. I burnt the disc and when I put it in the dvd player it says cannot play disc. I have a sony DVD Player. Any thoughts?
The exact model of DVD player matters. Not all models can play a Computer burned disc.
There are several types of DVD
A factory type DVD in DVD format
A burned movie in MPEG format
a burned disc in DivX format.
Try burning the disc with a DVD Creator program, not just 'Burn to DVD'. It's not the same thing.
Mar 19, 2010 | JVC XV-N320 DVD Player
I download free movies to hard drive, than I burn them, and my dvd player says no playback available or a big red x shows on tv screen, what am I doing wrong/
You probably have burnt the dvd disc using a video format that is not compatible with your player.
A lot of DVD players will not play .AVI or DIVx files that are commonly downloaded.
Your DVD player manual should list the formats it will play.
Convert downloaded movies to a compatible format before burning to disc.
There are several conversion programmes available via the web - at a cost of approx $50.00.
AVS4U works ok.
Oct 13, 2009 | Kenwood DV-6050 Multi-disc DVD Player
Mine is Sony DVD player..I insert a disc and it says "CAN NOT PLAY THE DISC" and then the player shuts off. The other DVD works fine.
Check the manuel some DVD Players do not support DVD RW or -R +R formats.When Ifirst put my burned movie in I got the message that the player cant play that format Just ignore that and advance the Video to where the movie is starting then all my burned movies played fine. My Pioneer BD 51 FD does support DVD RW +R -R formats so be sure that you can play burned DVD RW +R -R on your Sony player. I was in Wal Mart the other day and they had some DVD players on sale but on the box it said that they do not play DVD RW +R or -R Burned DVD's so be careful if you do buy another one I went to best buy and found mine. Check first it will save a lot of hassle later. This software works great but it may not play in your DVD Sony Player there is a list here of compatible DVD Players
your disc is scratched or a pirated one
thank you for using fixya,rate my answer,
Oct 02, 2009 | Sony DVD & Blu-Ray Players
I have wasted 4 hours with 1 of your so called (experts) i want answers not excuses
Don't know if I can help or not, but this what I do.
I've downloaded the DIVx player and converter software (free) to my computer. I can download mpeg, avi movies, etc, and convert them to DIVx format if I need to. The DIVx player has a 'burn' feature that is fast and burns them in a DIVx format. My old DVD Recorder will not play DIVx format but my 'cheap' Phillips will. I just keep it hooked up to my old DVD recorder through the front RCA input jacks. When I want to play a DIVx movie and watch it on the TV, I use the cheap Phillips player. I have to change the input on my old DVD Recorder to 'Front Input. I usually record the movie on a DVD R in my DVD Recorder while I'm watching it if I want to keep a copy to play later on the DVD Recorder. Most of the time, I burn the movies to RW DVD and erase them later.
I don't remember the web site for the DIVx players and converters, but you should be able to find it with a search.
Hope this helps.
Jan 16, 2009 | DVD & Blu-Ray Players
Copied dvds will not play on other dvd players
Are you using DVD+R or DVD-R to burn the movies to? DVD+R is what you want to burn movies to for best quality and DVD-Rs are for like pictures and documents etc (even though you can also burn those to a DVD+R). Secondly, most movies that burn are played back in MP3 format, make sure your dvd playing is capable of playing MP3s.
What exactally do you mean by you bought 2 different types of blank videos?
Dec 18, 2008 | GoVideo Go Video DVD/VCR Combo
Unable to play back
Shouldn't matter what the OS (operating system) is. What you need to do is to make sure you convert the movie to proper format which would allow you to view on DVD player after burning. Usually you need a seperate software. Your DVD player should say what formats are compatible. Usually listed on unit or in manual. Avi is a great format but when you burned it to DVD your computer probably created a Data Disk. Which would make it unreadable by DVD player. Check to make sure you are able to convert to format that's readable by your player.Good Luck
Nov 09, 2008 | Toshiba DVD & Blu-Ray Players
Pioneer DVD-V555 DVD Player Logo
32 people viewed this question
Top Pioneer DVD & Blu-Ray Players Experts
Steve Sweetleaf
Steve Sweetleaf
Lawrence Oravetz
Are you a Pioneer DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
