Question about Barnes & Noble BNTV250 NOOK Tablet
How can i open nook to replace battery
I need to replace battery. It charges but it won't retain power overnight
I have charged my Nook HD but it won't turn on. What can the problem be?
Do you have the charging graphic as in this image Nina?
How to Reset Nook HD
If yes, send it back. If not, your charger is faulty. Try charging with a computer USB.
Jan 21, 2016 | NOOK HD 7 Tablet
Will not take a charge a
Barnes & Noble Nook HD
Jan 01, 2016 | Barnes & Noble Nook HD
Will not turn on
Nook tablet won't charge
Jan 16, 2015 | Tablets & eReaders
If my nook doesn't turn on after fully charging it, does this mean I need a new battery?
If you are within 1 year of purchase, you should contact 800-the-book with your serial number or registered email (for the B&N account associated with the device) and arrange replacement of the unit. They very easy about returns, although you may need to settle for an alternate color to expedite replacement.
Oct 12, 2014 | Barnes & Noble nook color eBook Reader
How to replace battery
Nook 1's battery can only be replaced by a professional, and the others can't be replaced at all. If it's still in warranty and can't be charged they'll give you a new Nook, otherwise you're outta luck.
Aug 11, 2014 | Barnes & Noble Nook Tablet
Why my nook tablet will not turn on ?
If the screen is off and won't turn on, make sure the battery has a charge. Plug in your device for 30 minutes before trying anything else. If it is on or if the battery has a charge you may need to "hard reset" the Nook. Although this is very uncommon, it may happen. Below are a few solutions that may help.
  • Hold down the power button for 10-15 seconds. The Nook should power off and you can turn it back on again. Everything should work normally.
  • If that does not work you will need to hold down the power button and the "N" button for 10 or more seconds. Again, this should force your device to power off and you can start it up normally.
  • Take out the N2A Card and try the same steps again. Your Nook should boot up into Nook mode. You'll have to restart it again with the N2A Card in to boot up in Android mode.
One of the tasks above will usually correct this issue unless you have a hardware problem with the Nook. Our cards cannot cause hardware problems unless they are forcefully inserted wrong. If you determine you do have a hardware problem you will need to take the Nook back to the retailer if it is still under warranty. The Nook usually comes with a one-year (non-accidental) warranty through Barnes & Noble. Some retailers, like Best Buy, exchange them in the store under warranty.
Don't forget to hold onto your N2A Card until they return your Nook!
If you still have any kind of issue thenhttp://www.tablethelpline.com/nook-support/ you can take Nook Help from experts by calling nook customer service number.
May 16, 2014 | Barnes & Noble nook color eBook Reader
My nook will not turn on
Without further explanation, pictures or details of what you tried, it's hard to tell what exactly is wrong with your Nook. However, assuming that the battery is still good you will need to "reboot" your Nook.
Unlike other tablets, there is no reset button, but you can try this.
While pressing the Nook button (upside down u on the front of the tablet), press the power button on the side. You will need to hold it for couple of seconds.
Jan 16, 2014 | Barnes & Noble Nook HD
Nook tablet will not turn on
Yes, press and hold the power button, for up to 30 seconds, or until the "N" logo appears on the screen.
If it does not, suggestions are that the battery is dead or not charging because the power cord itself is broken or frayed inside the cable and you will need to replace with either a B&N cable or a Micro USB cable.
It could also be the wall charger unit is no longer functioning, and this must be replaced.
I have so far replaced one wall charger and three USB cables, so this is a unnecessary common event with Nook
May 03, 2013 | Barnes & Noble Nook Tablet
Barnes & Noble BNTV250 NOOK Tablet Logo
Top Barnes & Noble Tablets & eReaders Experts
John mullen
john smith
David Payne
David Payne
Are you a Barnes & Noble Tablet and eReader Expert? Answer questions, earn points and help others
