Question about Casio Office Equipment & Supplies
HOW DO I GET THE SUM TOTAL TO PRINT
I CAN'T GET THE TOTAL TO PRINT AT THE END OF MY CALCULATIONS IT JUST REPEATS THE LAST ENTRY HELP
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
Hi, I have WD 1TB Elements SE. When I checked the usage space on the partition after I plug in the drive, it shows a total capacity as 1,000,200,990,720 bytes (931 GB) and it shows 921,753,505,792 bytes...
If you have a 32bit system, it is expected to have miscalculations, a 32 bits can only go up to 4Gb for calculations (that is, 2^32 = 4'294'967'296 bytes) a 64bit system can make calculations to 2^64 bytes this is also why you couldn't copy a file larger than 4Gb in a 32bit operating system...
So, if you are running a 32bit OS, you should expect a discrepancy for the total space of the Hard Drive and the amount it shows (that's the 93Gb you are missing as total capacity).
Another reason why it can show you incorrect calculations are damaged sectors on the hard drive it-self. These will present themselves either as occupied memory or missing memory.
So, you should expect some miss calculations and you can expect some damaged sectors on the hard disk (a external drive spins on and off too often, eventually damaging sectors... its a problem of physical drives).
In the end, your disk might be fragmented, so run a disk analysis and a defragmentation on the disk so it can recalculate.
A note: A disk is like a shelve, you put things where there is space, if you remove things, that space will be open, and if you want to put something there it has to be the exact size or small enough to fit there. This effect, when things are small enough leaves blank spaces unusable, consuming space on the hard drive and making the access of files slower, this is fragmentation. In order to expand your disk life expectancy you should run defragmentations...
To run a defragmentation, go to START, write "Disk Defragmenter", choose your disk and run and analysis and defragmentation.
Jun 24, 2011 | Western Digital Wd Elements Se 1tb...
Can't find a manual online. What does 5/4 mean, and how do I turn it off? Same for E. My biggest problem is that when I add up numbers with the print function on (for depositing large batches of...
The manual for the Canon P1-DHV is online at http://www.usa.canon.com/app/pdf/calculator/P1-DHV_G_USA_HWB.pdf>.
When the display shows "5/4", the calculator is doing 5/4 rounding which means: 5 or above round up, 4 or below round down. To control rounding press the "5/4" key.
When the display shows "E" the calculator could not complete a calculation. It can be because of dividing by 0, or because the total exceeded 1 trillion, or because the operator entered calculations faster than the calculator could complete them. Press the CI/C key to clear it.
I can't explain why you are not getting a total on the tape. Try the following example from the manual exactly as shown, and let me know if your tape shows the total.
  1. Clear the calculator (press [CI/C])
  2. Choose 5/4 rounding (press [5/4] until "5/4" displays)
  3. Choose add mode (press [DEC] until "A" displays)
  4. Choose cost-sell-margin mode (press [B-T] until "B" displays)
  5. Turn printer on (press [PRINT] until "PRINT" displays)
  6. To calculate: $12.55 + $15.75 - $5.30
  7. Key in: 1255 [+] 1575 [-] 530 [=]
  8. Tape shows: [0. C] ... [12.55 +] ... [15.75 -] ... [5.30 =] ... [23.00 *]
Apr 07, 2011 | Office Equipment & Supplies
What do the following keys signify? Or do? GT MU MRC AC, CE ON/C 00 +/-
Hi, here are some of the answers to your questions.
GT:- Grand Total: It shows the cumulative total of your calculations
MU:- Mark Up: It is used to calculate the CROSS PROFIT MARGIN in business environment.
MRC:- If pressed once, it shows the number stored in the memory. If pressed twice it clears the memory.
AC:- All Clear: It clears everything
CE:- Clear Entry: Clears the last entry of calculations.
ON/C: If the calculator is off, it turns it on. If the calculator is on it clears all entries.
If you have any more questions you can visit this site: http://www.aurora-ltd.co.uk/OpInst/FunctionsGuide.htm it has almost everything covering the calculator buttons.
Lujaina96
Feb 12, 2011 | Office Equipment & Supplies
Where do I go to find an on-line manual for TI 5045 Sv Texas Instruments calculator?
TI-5045 SV
ii
English.............................................................. 1
Fran?ais ............................................................ 6
Espa?ol ............................................................. 11
Portugu?s ........................................................... 16
Examples, exemples, ejemplos, exemplos .............................. 21
ILLUSTRATIONS ¦ FIGURES ¦ ILUSTRACIONES¦ ILUSTRA??ES
Removable tab
Languette
Leng?eta extracci?n
Alavanca usada para o rolo
Ink roller
Rouleau encreur
Tamp?n de tinta
Cartucho de tinta
English
Your Texas Instruments calculator has a built-in printer for producing a permanent record printout of
your calculations with negative numbers printed in red. A big, easy-to-read display also enables you to
check entries or perform quick calculations without printing.
GETTING STARTED
OFF ON PRT IC GT
POWER
1. Connect the calculator to a proper power outlet (110-120V or 220-240V
where available).
2. The calculator is turned on by setting the POWER switch to the PRT
position.
Inserting the paper (see illustrations 1, 2, 3, and 4 on page ii).
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding it back in the
direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the
calculator.
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the
calculator.
5. Press & until the paper is in the printing position.
Replacing the ink roller (see illustrations 5 and 6 on page ii)
1. Turn the calculator off and tear off the excess paper.
2. Remove the printer cover by pressing down on both sides of the front edge and sliding back in the
3. Remove the old ink roller by lifting it with the removal tab.
4. Insert the new ink roller into the compartment and press down gently until it snaps into place. Close
the printer compartment.
Note: The old ink rollers should not be refilled. Replacement rollers can be obtained from your local
retailer. The warranty does not cover ink roller replacement.
SELECTION SWITCH SETTINGS
OFF ON PRT IC GT
POWER ROUND
: 5/4 9 + F 0 2 3
DECIMAL
TAX
SET CALC
Set the POWER, ROUND, DECIMAL and TAX switches as required.
Note: The TAX switch is spring-loaded to return to CALC when it is moved to SET and released.
The switch settings are summarized in the following table:
SWITCH SETTING FUNCTION
POWER ON
PRT
IC
GT
No printout is provided; however, the display can be printed by pressing
4.
The printer provides a printout of your calculations but does not count them.
The printer is on and an item count of additions and subtractions to or from
the register is printed when sub-totaled or totaled.
The GT position controls whether or not the totals from the independent add
register are accumulated in the grand total register.
ROUND Rounds the result of a calculation to the selected number of decimal places.
5/4
9
Truncates the result to the selected number of decimal places.
Rounds the result up or down according to its value. For example, when the
DECIMAL switch is set to 2, the result is rounded up if the third decimal
position is 5 or more and rounded down if it is 4 or less.
Rounds the result up to the selected number of decimal places.
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: :
DECIMAL: 2, TAX: CALC
Ex. 220 P 6
Setup: PRINTER: PRT, ROUND: 5/4
Press Display Printout Press Display Printout
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.66 6¦ =
36¦66 ?
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.67 6¦ =
36¦67 ?
DECIMAL + Add mode: All results are given with two decimal places. For addition and
subtraction only, a decimal point is automatically placed to the left of the last
two digits entered, unless the number already includes a decimal point.
F Floating mode: Any results are displayed and printed with the maximum
0 2 3 4 Fixed decimal mode: Sets the number of decimals to 0, 2, 3, or 4.
TAX SET
CALC
Lets you enter a tax rate to perform tax calculations.
Stores the tax rate. Pressing ! or " after a tax rate has been entered,
adds/subtracts the stored tax rate to/from the value in the display.
Ex. VAT = 17.5 %
100 + VAT
Ex. VAT = 17.5 %
235 - VAT
Setup: PRINTER: PRT, DECIMAL: F, ROUND: 5/4, TAX: CALC
Move and hold the TAX switch to SET. Press 217 L 5 and release the TAX switch. It
automatically returns to CALC. 17.5% is printed.
2 0. 0¦ C
100! 117.5 100¦
17¦5 @
117¦5 ?
2 0. 0¦ C
235" 200. 235¦
N35¦ @
200¦ ?
Note: The most common setup is POWER: PRT, ROUND: 5/4, DECIMAL: 2, TAX: CALC. Use these
positions for the examples unless other settings are given.
KEY DESCRIPTIONS
Basic keys
I Clear Entry: Clears an entry, enabling you to enter another number in its place. Note
that this key does not clear the add register.
2 Clear Key: Clears the add register, any pending operations, and the display. 0.C is
printed. Does not clear the memory.
( Right Shift: Deletes the right-most digit entered from an entry before an operation key is
pressed. Shifts the remaining digits one place to the right.
L Decimal Point: Enters a decimal point.
4 Date/Non-Add: Prints a date (such as 12¦10¦96) or a number for reference purposes.
Does not affect calculations. This entry is printed on the left side of the printout, the date
or number preceded by the # sign.
& Paper Advance: Advances the printing paper.
Addition and subtraction keys
9 Add: Adds a number to the add register. Displays the cumulated result.
: Subtotal: Gives the intermediate total from the add register. Using this key does not
affect the contents of the add register.
. Subtract: Subtracts a number from the add register. Displays the cumulated result.
E Total: Gives the total from the add register, and then clears the register.
Multiplication, division, percent and margin keys
? Multiply: Multiplies the number in the display by the next value entered.
' Divide: Divides the number in the display by the next value entered.
3 Equals: Completes any pending multiplication or division operation.
> Percent: Calculates percentages, ratios, add-ons (e.g. of VAT), or discounts.
# Gross Profit Margin: Calculates the selling price of an item when its cost and gross
profit (or loss) margin are known; also used to obtain a price excluding VAT.
Ex.
Cost: 594
Profit margin: 40%
Press:2 594 # 40 3
Answer:
Selling price: 990
Gross profit: 396
Ex.
Selling price including VAT: 252
VAT %: 20%
Press: 252 # 20 . 3
Answer:
Selling price excluding VAT: 210
VAT: 42
/ Grand Total: Gives the grand total of the operations previously performed and stored in the
Grand Total register. Every time a total is obtained with E it is cumulated into this register
(printout shows G+) which is only cleared when / is pressed twice. During long
calculations, if / is not used, this re
Jan 16, 2011 | Office Equipment & Supplies
How to get all balance sheet entries tally to excel
This is a very handy process when you're totaling or subtotaling columns. On the cell that you want the 'total' in type '=sum(column letter row number),(column letter row number). The first 'column letter row number' is where you want the first cell to be started in the total factor and the second 'column letter row number) is the last cell you want added in the total factor. The help (?) section is good at explaining formulas. Hope this helps, keep this process handy if you use Excel much because it'll be helpfull each time you subtotal or total columns.
Bob
Sep 23, 2009 | Computers & Internet
How to sum series
Click on the Mode button twice until you see “SD”. Select 1. This puts the calculator in Statistics Mode. image001.gif Enter the first number, 1.
image001.gif Hit the M+. (n= 1 will appear in the window)
image001.gif Enter the second number, 1.
image001.gif Hit the M+ key. (n=2 will appear in the window)
image001.gif . . . . .
image001.gif Enter the last number, 7.
image001.gif Hit the M+ key. (n=7 will appear in the window)
image001.gif Hit shift, 2. (This invokes the S-Var option.)
image001.gif Hit 1 for the sample mean. Hit Enter.
image001.gif Hit 3 for the sample standard deviation that we will use in class. Hit Enter. here you can also ffind the sum of all numbers
Jan 21, 2009 | Casio FX-300MS Calculator
Hi i have the canon p170-DH and i cant subtract. example: 4-4= -8 not 0
Hi....by looking at the date you posted this question, you may have already found the answer, but just in case you haven't......the procedure for adding and subtracting on these calculators is completely opposite of a regular calculator. On a regular calculator, you would input 4 - 4 = 0. On these type of calculators, a number's positive or negative status is keyed in AFTER the number, instead of before it. Therefore, you input 4 + 4 - (notice you DO NOT input = at the end, but if you are in print mode, you will need to hit your total key, which looks like an asterisk, where the = would normally be, in order for the final value of your calculations to print on the paper tape.
Multiplication and division equations are done exactly as they are on a regular calculator....4 x 4 = 16.
Hope this helps. If you have your owners manual, it should also give you some examples of how to perform calculations with your calculator.
Dec 11, 2008 | Canon P170-DH Calculator
Excel 2003 formula
detail about growth formula in ms excel
Jan 23, 2008 | Computers & Internet
Access 2003
Hi smiths, Try adding a Label to the report in Design View. In the Properties, select the control source for this field. Insert one for your vertical and horizontal calculations as needed. Hope this helps. Regards DeltaC
Sep 10, 2007 | Microsoft Office Standard for PC
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
