Question about Health & Beauty
Reactivate hearing aid saver
Hearing aid save how to remove pillow and reactivate
Is pregnancy a reason or cause of snoring?
Definitely in most of the cases pregnancy is the major reason of temporary snoring or we can say snoring for short period of time in women.
Several reason of snoring during pregnancy like
  • Cause of snoring is associated with pregnancy hormones, while relaxing the muscles in the mouth and the mucous membrane in the nose increase, resulting in vibrations that cause snoring sounds.
  • One more cause for snoring associated with pregnancy arises because the amount of blood in the pregnant woman rises naturally, which can lead to swollen nasal membranes.
  • Gaining weight, which is a natural byproduct of carrying fetus, which also contributes to the suddenly emerging snoring problem.
For more detail explore Asonor
Dec 28, 2015 | Health & Beauty
Does this dishwasher Kenmore 13543 raise the water temp so the soap cleans correctly? We have hard water and even the best soap leaves a white film even adding rinse aide in my old BROKEN machine.
there is not much you can do with hard water as it is the minerals in the water that cause the problem
it is cheaper to let the washer heat the water as it only heats what it wants
Hard water comes from bores as most town water is put through osmosis filters that remove the minerals and produce the soft water
If you have a bore supply the seriously consider fitting a osmosis filter before the house as it will fix all sorts of problems found in the shower, hot water system , septic/sewerage and general health of the people in the house.
The initial cost will be outweighed by the cost savings from detergents and heating
Apr 07, 2015 | Dishwashers
About Siemens hearing aids?
you want to know about this aid please visit Siemens hearing aids
Oct 18, 2014 | Health & Beauty
Problem with hearing aids
Try another set of batteries, Annmichelle. Sometimes "new" batteries are dead, too. I doubt very much that your tool has killed your hearing aids.
Aug 04, 2014 | Health & Beauty
Lumbar pain especially at night. Seems to be worse at night. I had the lumbar fused in March, 2008.
Sorry to hear that . If you sleep with a pillow between your legs that will help . Least amount of pressure on your back the better. I would ask your doctor for a muscle relaxer and possibly a pain pill for nighttime . But only take them as needed . They could be very addicting . Good luck .
Sep 11, 2013 | Health & Beauty
How to clean the domes on hearing aids
Take the domes off, wash them out or use a pipe cleaner to poke out the wax. If you have washed them, make sure they are thoroughly dry before you put them back on. When you put them back on make sure they are firmly on the receiver tip or you will be taking a trip to A&E to get it removed from your ear canal.
Jul 20, 2011 | RTO 1 Siemens Pure 500 Open Fit Hearing...
How to remove the drum from a kitchen aid washing machine
hello. Unplug the washer and use a vacuum cleaner to remove the little balls. J.
please rate my answer as very helpful. Thanks.
Mar 28, 2010 | KitchenAid KAWS700L Top Load Washer
My hearing aids always seem muffled. I am unable
Using a magnifying glass or eye loop, check for wax build up in the output (hole in hearing aid that is closest to eardrum). I have in-channel type hearing aids. The hearing aid audiologist gave me "wax gaurds" to prevent wax buildup in the output hole. If you have any wax in the hole, try to remove it by using a small wire loop - (a shape like a square "u") and scoop the wax out. If that doesn't help, the hearing aid may need to be professionally cleaned. Lastly, as my mom would say, "clean out your ears"
Oct 23, 2009 | Sonic Health & Beauty
Health & Beauty Logo
35 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
