Question about Kenwood Tk270g Tk-270g Vhf 150-174
Can receive at close range
Receive short range and transmit loss
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 116 Answers
Check the antenna connection
Posted on Apr 28, 2017
Both phones are displaying out of range please advise
Walkie talkies talk to each other. Try transmitting (talk to each other) so they receive a signal first. Do it in the same room. The try for range. It is not much. Even for a GMRS radio, these are low power and short range. Under 2 miles, must be able to "see" each other.
Mar 07, 2016 | Binatone 100 Latitude Walkie Talkie twin...
My Midland walkie talkie quits transmitting about 3 seconds after I start transmitting
It is more likely a power issue. PTT switches do not normally cause a short circuit. Check the batteries, swap the batteries and see if that helps. Radios take a great deal more power to transmit than turn on or receive. If not the battery, try a low voltage battery, such as a cordless phone battery. If it still occurs, check your warrany and send it back to the factory.
Nov 10, 2013 | Midland Radio Midland X-tra Talk Frs/grms...
Flashing red light on radio where it thinks its recieving. Transmits fine but does not recieve.
Three things come to mind:
1) The radio is receiving, hence the light, but you may have a different PL code than the other radio and it is muting the transmission. Check your programming to be certain both radios are programmed alike. The red light indicates activity on your frequency.
2) Your radio may have a problem with the receive side of the radio or a bad speaker.
3) The transmitting radio may have a problem with transmit. This can be a sign of a bad battery. Swap batteries and see if the problem moves to the other radio. If so, replace the battery. (It takes more energy to transmit than to receive, so loss of transmit is common with a bad battery.)
Best regards.
Apr 15, 2013 | Motorola CP200 Two Way Radio
Only side band receiver no am on 148GTL
Radio works on SSB but not AM?
Question here is it loss of transmit only on AM Receive?
If receive is good but no transmit on AM---I can tell you what transistor is bad
SD TECH
Sep 28, 2010 | Televison & Video
I can receive, but not broadcast from my CB radio.
Hi mfdogman,
This problem is usually one of two things. Check the antenna coaxial cable and connections first, to be assured there are no shorts. That's one of the symptoms of receive and no transmit. The other would more than likely be a defective RF Transmitter stage in the final amplifier circuit. That could be a defective (blown or shorted) Power Transistor or IC (Integrated Circuit) Module.
After checking the antenna and coax, key the Radio up and look for any meter or indicator sign of TX (Transmitted power). If you have a power meter, use that for power and SWR (Standing Wave Ratio which should be close to 1:1 ratio) checks of the radio and antenna system. If there is no power, then you will need Technical help from a Professional at a repair facility, unless you are familar with this work. The antenna problem, if it exists...you should be able to fix.
Let me know when you get this fixed, and contact me again for more help. Thanks.
Regards, Bill
Sep 18, 2010 | Midland 77-285AXL 5-Channels Base CB Radio
Will not get good recepiton.
Hi stormnorm157,
Much of the time this is caused by problems in the antenna system. Make sure there are no shorted or open connections in the coax or PL-259 connectors. Use your radio's meter or better still, a Power/SWR meter to check the SWR of the antenna. Try to get that as close as possible to a 1:1 ratio on the meter. A shorted or open antenna can keep the audio receive on your radio at very low levels. Plus, this will harm your transmitter if you continue keying the mike.
Another problem can be in the radio itself. This will be noticed if you can transmit, but have no "Modulation". Modulation can be described as the voice heard above the "Carrier" (your transmitted signal). Every CBer knows about the term, Modulation. The Truckers will definitely inform you about your modulation quality...lol. This problem can be due to a defective AMC (Automatic Modulation Control) stage in the receiver circuit. And, there will be no modulation upon transmit.
One other thing could be causing this lack of receive. Defective wiring or switching in the microphone can result in no audio. Or, in many radios, a missing mike will not allow receive, because the mike connection completes the RX (Receive) circuit.
Solutions:
1. Check the antenna system, and rule that out or fix.
2. Check mike, or substitute another one.
3. Using meter, and or another radio for listening on same channel, check power and receive.
4. You can probably fix 1 and 2 yourself, or with a friend.
5. AMC problem in radio (as described above) will require professional service.
Let me know how this turns out, and inform me if I can offer any more help. Thanks.
Regards, Bill
Sep 18, 2010 | Midland 1001Z 40-Channels Base CB Radio
My cb radio has good reception but only for a short distance, why ?
Make sure your squelch is not on, keep it all the way to the left and the RF Gain must be all the way to the right...
May 21, 2010 | Cobra 29 LTD CB Radio
PPT works in the lower bands (under 148 Mhz) but not 156 range
Your radio has not been modified to transmit outside of the amateur bands.
Jun 07, 2009 | Yaesu NABC NABC LMR NICD BATTERY FNB-29...
Kenwood Tk270g Tk-270g Vhf 150-174 Logo
48 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
