Question about Tview T1508IR 15 Inch Roof Mount Flip Down LCD TFT Swivel Monitor
The dome lights/ir transmitter don/t work on one side
The rigth side dome light don/t work
Front dome light and overhead driver and passenger lights don't work
Hopefully this is what you're looking for...good luck! :) http://wiki.answers.com/Q/Where_can_you_find_a_fuse_box_diagram
Aug 27, 2012 | 2005 Hyundai Sonata
REMOTE IS NOT WORKING
first check the battery or replace with new one. if the batteries are ok try to check the transmitter of your remote ( IR led) . you can check it by focusing camera or cellphone camera into the IR led of your remote then press any button on the remote if bright light shows your remote is working good. if no light you had to replace the IR led.marmeto12_0.jpgmarmeto12.jpg
Aug 20, 2011 | Televison & Video
The lights inside the car, the panel, overhead light and radio, don't work. Could that be a fuse and if yes, where is the fuse box so that I can change it.
make sure the dome light is not turned off by the switch headlight of switch at the dome light.the fuse panel should be under the driver`s side to the left of the steering colume and use a test light to test the fuses.
Jun 29, 2011 | 1998 Mercury Mystique
2000 sienna first power door and dome lights don't
Chances are its a door switch or the wiring close to it. the wires bend every time you open and close the door. Check for that but if your dead set on a relay. look under the hood you should find a relay panel on the left(drivers side) finder well. On the cover of the panel box will be a listing and placement for all the relays
May 14, 2011 | 2000 Toyota Sienna
Goes off only at night with NO warning cleaned & changed batt. 4 times so far !!!!
These types of smoke detectors are PHOTOELECTRIC, the way it works, there is a IR transmitter and a IR receiver placed in a dark chamber aligned at a 45degree angle, when smoke enters the chamber IR light bounces of the smoke and than generating an alarm, so in conclusion if there is a lot of DUST in the chamber it reflects the IR light just like smoke, than can generate an alarm, try blowing air in the smoke detector (gentely) if it does not work replace the smoke detector...
Feb 04, 2011 | System Sensor 2100rfadt Wireless Smoke...
Remote does not work for samsung ht-c550 Lights work when the button is pressed but the device is not receiving the signal.
The batteries may be to low to operate the IR transmitter, but still turn the lights on when you press a button.
If you have a cell phone with a camera, turn the camera on and look IR transmitter end of the remote. It may have a dark red lens. Press some buttons on the remote, and you should be able to see the IR signal in the cell phone. If not, try new batteries in the remote. If that does not work, it could have a problem with the code for the TV. Try to reprogram the TV button.
Nov 11, 2010 | Samsung TV Remote Control
Cortesy light don%27t work when opening door
There is a dome override switch on it. I have a 04 Avalanche that the dome light didnt work when I bought it and replaced the bulb and itstill didnt work. ABout a month late I noticed a dome override button below the air vent on the drivers side ov he vehicle and pushed it. When I got home the light came on. Not sure what purpose this button serves, but look for a dome override button.
Jun 23, 2009 | 2004 Chevrolet Venture Passanger
Jensen - Wireless Infrared Remote Control Extender - JDSC-IR100A
I have also purchased one of these over ebay without a manual. I have gotten it to work as an extender from my basement satellite receiver to the upstairs living room theater TV. I use a channel converter to remote the RF audio and video and this Jensen IR remote to allow control from the living room.
There should be five items in this set. Two dome shaped items, two power supplies and a hockey puck looking IR emitter.
First locate the dome that says transmitter on it. This you want to put at the remote location. This is the dome that you point your remote control at to do your bidding. Make sure its little antenna is extended and the power supply is plugged in. You should be looking at the dome with the antenna tail behind it. The range that you can operate this seems to be somewhat limited. More on this later.
Second, locate the receiver dome. It says receiver on it and has two plug jacks, one for the power supply and one for the IR emitter. Don't worry about that yet, you don't need to plug it in. Raise its antenna, connect its power and set this in front of the devise that is being controlled remotely. You do not need the hockey puck for this to relay your IR beam. Make sure it faces the device being controlled. The antenna tail should face away from the device being controlled.
You should now be able to relay the IR signal. Start by being close to the transmitter. Try a simple on off to verify you have a connection. You can then work at moving away a bit to get an idea on the range capability. I have read several reviews that say this range is very limited, maybe only 5 feet ! I am not sure if this is true in all cases, but be aware of it. Secondly experiment with the receiver placement to get reliable relay to controlled device.
The hockey puck can be used to put the signal in a closed in spot like behind a door in a cabinet etc. In this case, plug it into the receiver and stick it over the IR led on the item being controlled. By the way, I have not gotten this to work on the unit I have. Not sure why. I am also clueless on the visible red LED in the receiver. It seems to glow when I pass my hand around the antenna and does flash when a signal is relayed. It would be nice to know what this is intended to do.
I hope this helps.
If anyone has the manual, I would be interested as well.
Sep 29, 2008 | Televison & Video
Tview T1508IR 15 Inch Roof Mount Flip Down LCD TFT Swivel Monitor Logo
35 people viewed this question
Top Tview Computers & Internet Experts
David Payne
David Payne
Are you a Tview Computer and Internet Expert? Answer questions, earn points and help others
