Question about Rival 8605-M 6 Quart Ice Cream Maker
I hear clicking noise not my condenser unit kicking in
Taylor ice cream machine model 754-27 Mix compartments are not cooling. I replaced Logic Board on left side, also replaced ribbon cable
Have your electrical panel on the bottom open. While listening to the left hand power board, turn the left hand logic board mix potentiometer all the way clockwise. If not right away, within 10-15 seconds, you should hear a click and the mix refrigeration condenser fan should come on. If there's no click and the fan never comes on, check your hopper probe. If it is attached to other wires on the logic board, it should be separated for testing. Using an ohm meter, you should read between10K ohms (about 77 degrees) and 30Kohms (35 degrees) it should be in that range depending on whether you have anything in it or not. If its in this range and the potentiometer is turned all the way clock wise, then your powerboard is bad. If its a lot higher than 32K ohms, then most likey your probe is bad and the machine thinks its at temperature.
If the fan does come on then you will have to put refrigeration gauges on the mix refrigeration system. You should be reading 20PSI at the EPR valve and 1-10 PSI at the compressor. if you have those pressures, your compressor is working. if the pressures are equalized at anything above lets say 30PSI and theres no sign of change after a few minutes, then some component of the compressor has failed. it could be the relay, start capacitor, or the compressor itself. Of course if theres no pressure, you have a leak. Even with the proper pressures, you could be low on refrigerant. Check the whole system for leaks.
www.softserveparts.com
Sep 19, 2017 | Taylor Ice Cream Makers
Looking at a H84-27 how can you tell if its air cooled or if its water cooled?
Air cooled units will have refrigeration condensers, ie: the fins for air to pass over. Water cooled units have water hook ups and black coils inside.
Nov 02, 2012 | Taylor H84 Soft Serve Frozen Yogurt Ice...
Refrigerator light goes on, but compressor does not go on or the compressor fan.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | Ice Cream Makers
One of the prongs that holds the motor on to freezer broke off, other than that have no problems
heatman101
Aug 30, 2011 | Rival 8605-M 6 Quart Ice Cream Maker
I plug it in and nothing happens with the motor, no hum no nothing on ice cream maker 8550 been sitting for a year and not abused. is there a switch ? the thing will turn by hand , or is there a safety...
heatman101
Aug 23, 2011 | Rival 8550-X 5 Quart Ice Cream Maker
Plastic dasher broken need a replacement
heatman101
Aug 17, 2011 | Rival 8550-X 5 Quart Ice Cream Maker
My Taylor 754 makes ice cream. You make a draw on either side and that side times out about 15 minutes before you can make another draw.
First, be sure you have good scraper blades. All too often the importance of the scraper blades is overlooked. After you know these are good (you should put some new ones in just in case), be sure the refrigeration condensers are clean. Also, check the air discharge to verify it is not clogged. Hi pressure air or CO2 is best for cleaning condensers. They are located on the sides of the machine (if your machine is water cooled, be sure you have adequate water supply.). You will have to remove the sides of the machine to access the condensers appropriately. Clean the hopper condenser as well while you are inside the machine. It is the small condenser located in the middle of the machine toward the front. If all of the above are done and your problem continues, you will need to call for service as you likely have a low refrigerant level.
Mar 16, 2011 | Taylor 632-27 Ice Cream Maker
Not churning corectly
This sounds like a low on charge condition which you probably won't be able to repair yourself unless you are a refrigeration technician. There is a possibility that the cooling fan is not operational or the condenser is dirty. Two things that are very easy to check. First check the temperature of the tubing going to and from the compressor. Both will be hot if this is your problem. Blow out the condenser with compressed air. If it is greasy, use a cleaner. If the fan motor is not running, check for voltage at the motor. If there is no voltage check the switch and wiring. If there is replace the motor. If everything is clean and running the tubing from the compressor to the condenser should be hot to warm and the outlet around room temp. Run your fingers down the side of the condenser from the inlet. If it is cool after the first tubing bend, it is low on charge most likely and is probably not worth repairing.
Nov 12, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
The bowl doesn't freeze in my freezer.
The noise you hear from you machine is provably just the mixer but not the compressor the bowl and the mixer has different cooling systems to check the you got to see your contractor kicking in when you activate the dispenser handle. reply to Art after check that
Apr 08, 2009 | Salton Ice Cream Makers
Rival 8605-M 6 Quart Ice Cream Maker Logo
Top Rival Ice Cream Makers Experts
Dan Webster
Dan Webster
Stan Skaggs
Stan Skaggs
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Rival Ice Cream Maker Expert? Answer questions, earn points and help others
