Question about Hankscraft Gerber Model 240 Cool Mist Vaporizer Humidifier Air Moisturizer Euc
Where to find a replacement motor
Looking to find a replacement motor for both the 240 and 241
I NEED A REPLACEMENT FAN MOTOR. ANY INFO ON SPECIFIC CONTACTS TO PURCHASE MOTOR/
In the model number... I'm not sure of the fx and ms, but the 80 and 25 is a standard 80mm case fan that is 25mm thick. I tried a standard .2amp case fan that I had on hand and the circuit board did not like that..it got hot. I got on ebay and looked at dozens of 12v 80mm fans until I found one that was 0.09amps. That was as close as I was able to find without much more looking. The fan works very well although not quite as much airflow as the new crane humidifier that I put next to it but it doesn't overheat and does the job for about 7 bucks.
Mar 06, 2012 | Crane Frog EE-3191 1 Gallon Humidifier
Motor runs fine--but drum "skips" and does not
Hello, if you mean the motor runs fine without the drum in place then it could be that the drum is not properly seated on the small motor shaft, also alot of times i see that the motor runs fine but once the drum is in place it skips and does not move due to the gear and shaft inside the motor being slightly craked or broken. If the drum is seated properly than the motor must be replaced.
Feb 11, 2011 | Honeywell HE120 Humidifier
Can i fix the fan on my dimplex dac 9005 portable
1. Disconnect the dimplex aircon from the power source.
2. Dismount the motor driving the fan from its mounting.
3. Mark the motor lead wires accordingly.
4. Disassemble the motor, and replace the bearings.
(Take note of the bearing number located at sides)
5. After replacing the bearings, assemble the motor,
and have it remounted in place.
6. Reconnect the wires and palce an electrical tape
at the bare joints.
7. Conduct a test run of the unit..
Hpoe this helps.
Jan 05, 2010 | Humidifiers
MOTOR IS NOISE
Sounds like your motor bearings are going bad. If at all possible lubricate the motor bearings using a few drops of a NON detergent oil. If the motor has sealed bearings with no oil ports then you should replace the blower motor.
Good luck
Mar 29, 2009 | Essick Air 447 302 Console Whole House...
NEED MOTOR, EATON 416 025 20 FOR SEARS FURNACE HUMIDIFIER
It`s pretty expensive but Appliance Factory Parts has the same motor except at 24 volt and you have to use the gear from your old unit and a step down transformer..as yours is 115 volt..
Around $80 as they will combine the shipping if you call them..
Local electric motor shop repaired my 1994 motor for $35 after I explained to them I could not find a replacement..
I talked to Sears repair service man, he said our units are too expensive to produce today but are better than these new high flow models they use allot of water that just goes down your drain..
Mar 17, 2009 | Humidifiers
Honeywell 6013i new machine will light up...
Unplug the machine and take both the water jugs off. Take the motor unit off and flip it over. Plug it into an outlet and press down the small silver contact at the bottom of the motor. When you press this down, a connection is made and the motor should turn on (Don't worry about being electrocuted, this is perfectly safe). If the motor turns on and runs at various fan speeds, you know it's not an issue with the main unit.
When looking at the base, on the left side you'll notice a plastic piece sticking up that's held down with a plastic shroud and 2 screws. This is you water level sensor. When the water level raises up, this also rises and hits the silver contact on the bottom of the motor. Make sure this isn't binding up(I suggest you clean it) I had the same issue with my HMC-6012i, lights were on at the indicated humidity level but the motor would never run. Take the unit apart, clean it out and follow my instructions. It should fire up (Mine is running right now :) )
Dec 22, 2008 | Honeywell QuietCare HCM-6013i Humidifier
Need to find a new water tank
Mine also cracked along the seam several years ago. I sealed the crack using two-part waterproof plastic epoxy (found at any hardware store.) Not really pretty to look at, but it hasn't leaked since!
Dec 01, 2008 | Holmes Products Cool Mist HM3500...
Motor replacement
probably a fractional horsepower open frame motor - go to grainger dot com and see if you can find a replacement
Jan 20, 2008 | Bemis 4D7-800 Humidifier
Hankscraft Gerber Model 240 Cool Mist Vaporizer Humidifier Air Moisturizer Euc Logo
70 people viewed this question
Top Hankscraft Humidifiers Experts
Paul Carew
Dennis
Are you a Hankscraft Humidifier Expert? Answer questions, earn points and help others
