Question about Saws
How to replace return spring on c10fsb hitachi
Where do u put spring?
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
I have a hitachi c10fsb that started making a
unplug it and make sure the ground is secure
Oct 17, 2014 | Cars & Trucks
I have the old model c10fsb mitre saw but need to replace the two parts of the handle & the trigger,where would i get them ?
You can go to www.toolpartsdirect.com and search by brand name than tool description by model number then view a schematic to get part numbers. You can also call direct at 1-866-597-3850.I hope this helps you. Good luck and thank you.
Mar 14, 2011 | Hitachi C10FSB 10" Sliding Dual Compound...
Replaced the lamp on my Hitachi 50v500A but it does not work. I put the olf one back in and it still works.
It sounds that new lamp is bad, return it and get replacement.
This can happens with new lamp.
Sep 23, 2010 | Hitachi 50V720 Television
Compressor runs great but pops off at 125 then bleeds down to 80 then tries to restart.i have changed high presure pop off.
It souds like a sticky "non return valve". See the fix below.
The non return valve is the chrome part with a hex cap adjacent to the upper tank. Remove the cap and make sure the piston moves freely. Slight resistance is ok, but if it sticks your compressor willl continually blow off air.
The check valve or "non return valve", as listed in the Hitachi parts manual is definitely the culprit here, but there is an alternative solution to replacing the entire valve that was actually suggested to me by a Hitachi Tech when I stopped by my local service center to pick up a new non return valve. Obviously, the rubber piston swells and sticks to the point that the spring under the piston can't over come the friction. I removed the piston and carefully reduced its diameter, by hand, with varying grades of wet or dry paper and it now operates perfectly. If one is uncomfortable with such a repair, at least keep it in mind for a quick jobsite fix. I have now been running my repaired compressor for several months without issue.
Aug 20, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I borrowed a chop saw and it is in lock position, how do i release it
on the back of the saw where the arm goes up and down there is a pin that pushes in it will only stick out about a 1/2 inch.
Feb 23, 2010 | Hitachi C10FSB 10" Sliding Dual Compound...
Bostitch roofing nailer wont return driving pin but moves freely
If the driver moves on it's own then it's o-ring is shot,replace it. Pop the feeder cap and clean all the roof crud that's built up underneath it.Now you can see the feeder spring,check to see if broke or old and replace.The feeder plunger is air assisted so hook the air up and depress it, it should depress hard and pop right back up. If not it needs to be cleaned and new o-rings. If this doesn't work then it's a new feeder plate you need. good luck.
5run7
Sep 15, 2009 | Hitachi NV45AB2 Roofing Coil Nailer
Need wiring diagram for the box on the outside of the motor.
white from cord to B. grey from stator to A. blue from brush holder and red from switch to C!
Mar 25, 2009 | Hitachi C10FSB 10" Sliding Dual Compound...
Saws Logo
43 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
