Question about Fujitsu Siemens AMILO Pro V2010 Notebook
Display very faint and dark in the background and unviewable
My Amilo V2010 LCD panel has failed. The laptop works well when connected to an external monitor. I traced the problem to a failure in the high voltage supply to the screen. This is a printed circuit strip located at the bottom of the LCD panel. Can anyone tall me where I can get this replacement unit, or a complete working panel (used of course), and how much it can cost?
    Genius:
  • 1,341 Answers
Look on ebay..much cheaper than anywhere else
Posted on Jun 15, 2009
  • 3 Answers
I have the same problem, just bought a new inverter but that did not cure it, so now I have a spare inverter PCB. Has any one got any more ideas on this problem?
Posted on Jul 06, 2009
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Hp pavilionn dv6700 screen goes black after a while
If you shine a flashlight on your black screen and look real hard for the icons on the desktop. If you can faintly see them that means your LCD Inverter is bad. You'll have to disassemble the LCD Screen to get to it. In the mean time you can attach another monitor (LCD Flat Screen or the Old style fat CRT) with a VGA cable to the vga port on you laptop. Once you have it connected hit the FN (Function Key) + (F1 thru F12) key that that corresponds to the external display. Hold the FN Key while you hit the Function Key that is for the external display. The key might have the words LCD/CRT on it or it might show a display symbol. That's the key you want to hit while holding down the FN key. This will cause the desktop to display on the external monitor and verify that there is no problem with your Video Card inside the laptop.
Mar 15, 2012 | Computers & Internet
Hi, i have a HP Laptop DV5000 series. when i switch on my System, it shows a Blank screen. the Laptop infact run properly in the background. if i connect the laptop to an external monitor then i can see...
Hi
3 possible causes:
Failed of failing LCD Panel Power Inverter
Failed or failing Cold Cathode LCD Panel backlight.
Failed or failing LCD Panel.
Take you laptop to an experienced and reliable laptop repair technician nto test these 3 things while you wait, to identify the faulty part and replace it.
Hope this helps.
Aug 24, 2011 | Computers & Internet
Where i can buy, power socket for my amilo pro v2010?
Just one example,
http://www.laptopjacks.com/view_part/For-Fujitsu-Amilo-Pro-V2010-DC-Power-Jack-FJ41420.html
The power socket in the laptop that the AC adapter (Charger) plugs into is a DC Power Jack.
Type Amilio Pro V2010 DC Power Jack in your browser search bar, press the Enter key.
To add:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 07, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Does the fujitsu Siemens Amilo pro V2010 have a backlight I cant find it
Backlight is connected to the lcd so that the display become brighter and readable.
why do you want to take it out?
Mar 24, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Dim screen dell precision m70 too dark screen
try this press and hold Fn then tap on arrow up key check if the display will become bright. if fails try connecting an external monitor to your laptop check if display is fine. if not then uninstall video driver then install a latest one. if fails replace the video card drive or motherboard if video is built-in. if display is fine from the external monitor then reseat the LCD cable if fails then replace the LCD panel with the LCD cable.
Oct 24, 2009 | Dell Precision M70 Notebook
Dell Inspiron E1705 does not show any picture
First of all, check that the laptop is set to output video to the LCD. There should be a function key which will determine whether it is outputting video to the built-in LCD, the external monitor, or both. That should be holding down your "FN" key and hitting "F8." If it is on CRT ONLY, it should switch within 1-2 keypresses.
Secondly, take a good bright flashlight and shine it directly at the LCD panel from about 1-2 inches away. If you can actually see the graphics on the screen faintly in the background, your backlight is not turning on. The backlight is literally a bulb which lights up the screen, and they can burn out. It is repairable, and shouldn't cost more than $150.00 from a reputable repair shop.
Sep 01, 2009 | Dell Inspiron E1705 Notebook
Wifi connectivity
Yes it is. Ensure the Wireless Lan switch is on (button at top right above keyboard) which will light an indicator on the light panel).
Got this info by downloading the manual from here:
http://uk.ts.fujitsu.com/support/manuals.html
May 15, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Device drivers
Your unit uses a Realtek ALC655 chipset.
The drivers are available from here (at the Fujitsu site). Enter your model number (I entered Amilo Pro v2010) and OS for the exact drivers for your machine...
Apr 28, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens lap top AMILO l1310G
Try reconnecting the LCD cable on the back of the screen. You have to open the screen in order to access the lcd cable.
If this won't work, the cable is most likely not working correctly.
Oct 29, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens AMILO Pro V2010 Notebook Logo
324 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
