Question about AT&T ATT1739 Digital Answering Machine
0 and C flashing after power uotage
0 and C flashing after power failure
Fisher &Paykal oven is off
try resetting the clock .
Aug 28, 2015 | Fisher Ovens
Please help! It turns on, command light is flashing green, no turn off, doesnt move if i dont put water in manually
Failures, which occurred during the program will store and indicate for customer by flashing start LED (light-emitting diode). Appliances which have no program sequence or no 7-segment display can't exatcly show the failure. On these appliances the failure can only be found by starting the test program.
The passive test program shows the stored failure. If there is no failure the passive test program runs normal.
1. Switch off the appliance
2. Push start button and hold it
3. Choose position 1 of the "turning knob" turning right side (program 1).
4. Finish pushing the start button when the start LED flashes.
5. Failure indication
6. Repair the failure
7. Solve the failure by pushing the start button for longer than 3 sec.
8. Start the passive test program again. If there is no failure detected, test all LED's and after that choose program 1.
9. Finish the passive test program by pushing the start button for shorter than 3 sec.
Thank's to your description of failure I will check all hydroulic inlet water circuit and electrical component in "inlet water" phase (electrical valve, flow meter (if exist), OWI, VWI, wiring, CB...etc)
Dado
May 30, 2015 | Whirlpool Dishwashers
The time is at 0:00 and flashing
It needs to be reset perhaps due to a power failure. I can't tell you how because I would need the model number and make. If you haven't got a user manual many makers have them free on their website so check it out. If you can't get it to reset or it keeps going to 0:00 then post again saying you have a fault, but included the make an model number.
Feb 22, 2011 | Televison & Video
What command do i run to show IpSec tunnel status on ASA 5520
show ipsec stats
this command was introduced in code 7.0
it will show the active tunnels, the previous tunnels and several other stats of inbound and outbound packets.....
for example:- IPsec Global Statistics ----------------------- Active tunnels: 2 Previous tunnels: 9 Inbound Bytes: 4933013 Decompressed bytes: 4933013 Packets: 80348 Dropped packets: 0 Replay failures: 0 Authentications: 80348 Authentication failures: 0 Decryptions: 80348 Decryption failures: 0 Decapsulated fragments needing reassembly: 0 Outbound Bytes: 4441740 Uncompressed bytes: 4441740 Packets: 74029 Dropped packets: 0 Authentications: 74029 Authentication failures: 0 Encryptions: 74029 Encryption failures: 0 Fragmentation successes: 3 Pre-fragmentation successes:2 Post-fragmentation successes: 1 Fragmentation failures: 2 Pre-fragmentation failures:1 Post-fragmentation failures: 1 Fragments created: 10 PMTUs sent: 1 PMTUs recvd: 2 Protocol failures: 0 Missing SA failures: 0 System capacity failures: 0
Dec 11, 2010 | Cisco ASA 5520 Firewall
When i plugged my cooker in the numbers started flashing all zeros and now none of the buttons will change the screen except the cancel button. When that's pressed the screen goes blank for a second it...
I am having the same problem. Here is what the Tiger people say. I haven't tried it yet though.
* If an external power failure has occurred, but only for a short time, then there's a possibility that when the electricity has returned, all functions may work normally and the clock is working correctly.
* When a power failure lasts for a long time, and the indicator is flashing 0:00...
--> Please set the time correctly by following the instruction manual.
If the electricity has returned as in these situations below:
(If it's already past the set time, after a lengthy power failure, cooking starts immediately.)
* While cooking rice (or reheating rice).
--> Continue to do the cooking (or reheating).
* Keeping warm (or Low temp Keeping warm).
--> Continue to keep warm (or low temp Keeping warm).
Aug 25, 2010 | Tiger JAE-A10U 5..5-Cup Rice Cooker
Keyboard failure and diskette drive 0 seek failure
How old is the computer, could it still have warranty? USB ports are often protected with fuses. Some latest stuff has resetable fuses, but many are one-time that do not heal. Did you try the keyboard in the front USB's The thing of biggest concern though is that this happened in coincidence, meaning you may have a motherboard hardware failure. (the reason I mentioned warranty)
May 20, 2009 | Dell Dimension C521 PC Desktop
Powers up does not boot
Sounds like a bad harddrive! If possible try replacing the harddrive!
Ill bet that would solve the problems you are having!
Dec 27, 2008 | Sony VAIO PCG-K35 Notebook
Washer full and then stops and gives a beep while flashing F 51
On Kenmore F51 means Motor RPS Failure, the motor is not spinning or the motor sensor detects a fault.First unplug the power cord for one hour or so to check if it is a jammed sensor, and see if reset.
Dec 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
AT&T ATT1739 Digital Answering Machine Logo
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
