Question about Garden
How do the straps work on the saxon back pack sprayer
How does one adjust the straps on the saxon back pack sprayer
Where can I find the straps and harness for a ground work back pack sprayer?
If ur handy enough with material, you can get them from a fabric store
Jul 02, 2016 | Cars & Trucks
When I use my Saxon sprayer,water drips from the bottom of the pump,and down my jeans.Why?
probably be a failed pump shaft seal
or if the container pressurized , it could be a crack in the container
Oct 30, 2015 | Dishwashers
How to repack the sprayer
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
Aug 25, 2014 | Titan Paint Sprayer. Advantage 200 Airless...
Sector 130 watch strap
Hey! Just go to this website and tell you how to adjust a rubber band watch and how to replace it!
www.watchbandsonline.com/qanda.asp
Hope it helped! ^-^
Sep 17, 2012 | Sector Expander 130 Chronograph Alarm Mens...
Need to buy parts for gilmour backpack bp4. Where can I get them?
Got the same sprayer, can't get parts. Toss it in the trash like I did, don't buy anymore Gilmour products.
Aug 01, 2011 | Gilmour Bp4 4.5 Gallon Back Pack Sprayer
I am having trouble adjusting shoulder straps
Funny, I was just putting this seat back together after taking it apart to wash it. It is a very difficult process, simply because you have to remember which order to loop the buckles through the stap.
First, I assume you want to switch from the lower holes for the shoulder, to the upper. (If not, then there is no adjustment needed. Unless the strap is caught in the back which will make the straps uneven when you go to tighten them. This has happened to me).
So, first you need to remove the straps. Once the seat is removed from the car, look at the back of the seat and you will see a metal bracket that is holding three straps. The bottom strap is not removable from that bracket. The top two strap are attached to the bracket with loops. Remove the straps by sliding them out (edge of the strap has to come out the hole first, then the rest will slide out very easily), Once out, from the front of the seat, pull the strap through the holes
At this point you must decide whether you simply want to adjust the seat, or wash it too. I highly suggest washing it if you haven't done so recently. If you gone this far, go all the way. But since you only asked to adjust it, and the method for removing the cover is much more complicated, we''ll move on to adjusting
Now that you have the straps pulled through, be sure that the straps are not twisted, and simply push them through the desired holes - upper or lower - and reconnect to the loops brace (remember, edge in first).
If you are having problems with the straps not being even when tightened (one side tight on shoulder, other side loose), remove the seat and look to see if the strap is caught on something.
I'm retiring my seat today after six years and two kids. I could use it up to 80lbs, but it makes it difficult to get to the third row of seats in my car. So now we have two no-back boosters.
Oct 13, 2009 | Eddie Bauer Deluxe High Back Booster...
I have two 428 solo back pack sprayers both of the pumps have crackes in them where do I get parts. Help!!!
i have 428 with a broken pump handle. the solo co. has some parts.their ph. no. is 757-245-4228,i talked to a young man @ ext.352,name is shawnatin.if you can't get the parts,i would like to offer you $5.00 a peice for the handles & shipping cost.just snapped today while working in my yard.
May 02, 2009 | Solo Backpack Sprayer 5 Gallon, Model# 428
Belt straps continually loosen
you could put on a triglide buckle onto the strap to help lock it in place
May 01, 2009 | Camelbak Flashflo
Kitchen faucet Installation
Many new faucets require some assembly before mounting to the sink; if that is the case, follow the manufacturer's directions. With most pullout sprayer faucets, the sprayer needs to be threaded through the faucet body first. Insert the rubber gasket between the base plate of the faucet and the sink top to create a watertight seal. If no gasket is provided, pack the cavity of the faucet with plumber's putty, then insert the faucet body through the holes in the sink top. Thread the mounting nuts provided onto the faucet shafts, then center the threaded shafts in the sink's holes and tighten the nuts firmly. Many manufacturers include a special long socket specifically to aid in tightening the mounting nuts. A hole in the socket accepts the shank of a screwdriver, guiding it as you tighten the nuts. If you're mounting the faucet on an installed sink, use this method. If you're installing a pullout sprayer faucet--or a faucet with a separate sprayer--now is the time to connect the sprayer to the faucet body. Check the manufacturer's directions to see if using pipe-wrap tape for this connection is recommended. Use an adjustable wrench to tighten the connection. Most pullout sprayer faucets and faucets with separate sprayers come with a counterweight that attaches to the sprayer hose. This weight helps retract the hose back in to the sink cabinet after you've used the sprayer. Follow the manufacturer's directions on where to secure the weight, and take care not to crimp the hose as you attach the weight. Hook up the faucet's hot and cold supply lines to the water supply shutoff valves under the sink. If necessary, gently bend the copper tubes coming out of the faucet for better access and connect flexible supply tubes to them. Simply wrap a couple of turns of pipe-wrap tape around the threaded nipples on the valves and connect the tubes. Tighten the nuts with an adjustable wrench.
Aug 27, 2008 | Danze D316440RBT Fairmont Two Handle Wall...
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
