Question about GE Refrigerators
GE fridge not cold.
Defrosted it and it worked for about a week. Problem cropped up again. Compressor works. Thermostat or defrost timer problem?
    Novelist:
    Scholar:
  • 166 Answers
If the coil (in the freezer) is icing up then it's not being properly defrosted on a regular basis, ie. 2 - 3 times a day. On older models it's usually just a simple matter of replacing the defrost timer. On newer models, the defrost timer is integral with the 'motherboard', so the whole (expensive Chinese made) motherboard must be replaced because they're not serviceable.
Less likely (but possible) are the defrost heating element and/or temperature sending unit found on or near the coil itself. Least likely is a low refrigerant level, which would indicate a leak.
Posted on May 26, 2014
Master_Tech
  • 770 Answers
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Posted on Feb 22, 2008
SOURCE: Fridge fan noise
Du musst den Abtausensor erneuern, ((Gelbes Kabel ))
Posted on Jul 24, 2008
  • 66 Answers
SOURCE: My Haier Mini Fridge comes
This could be a bad defrost timer. See if the compressor is working. If it isn`t or only works sometimes. The defrost timer could be bad. When the frig goes into the defrost cycle, turns off the compressor. It may failing to turn the compressor back on after the defrost cycle. Since it stopped defrosting at one point and started again, the defrost timer may be bad. Let me know if this was any help or if I can help any farther.
Posted on Nov 12, 2008
  • 111 Answers
SOURCE: GE side by side fridge TFX22JR not staying cold
You need to unplug the unit and check continuity with a meter across the defrost heater/s. If they are open, that's your problem. The defrost termination thermostat HAS to be below 20 degrees (varies model to model) to close. If at room temp it will read open. Doubtful it is your defrost timer.
Posted on Dec 16, 2008
  • 115 Answers
SOURCE: fridge and freezer not staying cold but lights and fan working
the problem is going to more then likely in the main control board which is on the back of the refrigerator in a little compartment this board is bad about going out if you have power surges or outages
Posted on Jan 03, 2009
Ge refrigerator model gss22kgmc
check defrost element, if good check defrost thermostat, if good change defrot timer/control board depending on your specific model you can look at this link provided its a diff model but none the less quite similar
am searching for Main PBA for fridge freezer model no SRL 629EV The number...
Sep 02, 2014 | GE GSS22KGMBB / GSS22KGMWW / GSS22KGMCC...
Have a GE tfx28ppdabb and the frig side gets hot, defrosted the freezer but the problem comes back after a week
Is it an automatic self defrosting unit? If so, defrosting the freezer will cure your problem temporarily. When the defrost timer fails to defrost automatically, ice builds up again and plugs the chute between the freezer and the fridge and the fridge gets hot.....If this action is repeatable,(meaning you can manually defrost but it only lasts a few days) then for some reason, the automatic defrost timer is not working. It's either the timer itself or one of the fuses.....there is always the chance that the thermostat, which tells the timer when to turn on and off, is also defective, but most of the time, the defrost timer is the culprit. Check the fuses first, then the defrost timer.
Jun 20, 2011 | GE Refrigerators
My freezer N308 F&P makes a little noise but motor not going. It is slowly starting to defrost and water coming out...I turned it off and on but same.
The compressor could be gone, the niose you hear will be the internal fan unit running , this circulates the cold air arount the inside of the unit. If this unit has a timer, it will be a located in the compressor housing well in the lower rear of the , it will be separate from the compressor and will have 5 wires plugged into it, on that unit, locate a small round knob and turn it clockwise, it should start, if it does, replace the timer, if not, check the thermostat. This may need a tech to do safely as you are working with a live curcuit.
Hope that helps but without being there it quite hard to explain.
Dont forget to vote and goodluck, need more help contact me wgheaven@yahoo.com.au and if you are in Perth Australia, I can have a look at it.
Mar 22, 2011 | Freezers
Oklahoma Freezer cold fridge warm fan gets Ice build up !
You should not have to manually defrost. Your auto defrost system is not working. Check the timer usuall in the frig compartment near the thermostat ( a small hole, use a screwdrive flat tip 1/4" to rotate the timer till it clicks starting the defrost cycle) check freezer in 10-15 min should be defrosted if not you will need to check the heater and thermostat located behind the rear or bottom panel of the freezer.
The defrost timer could be under the box in the front behind kick panel or in the rear by the compressor.
Sep 22, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Ge freezer works fine but the fridge wont cool.you
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Refrigerators
Repeated ice over the coil
The defrost cycle is either failing to start (problem with defrost timer) or is not heating the defrost coil (most often defective defrost thermostat.)
When you defrosted did you remove the panel at the back of the freezer to defrost the drain hole for the defrosted water to drain out?
Sep 08, 2009 | Jenn-Air JCD2389G Side by Side...
GE Model # DSS25PFMD WW, lights and fan are working not cooling
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Freezer wont defrost and fridge not cold
Better solution is to replace the defrost element,defrost timer,or defrost thermostat,one of these are not working and when replaced will fix the problem.
Aug 01, 2009 | Whirlpool GS6SHEXNL Side by Side...
My Haier Mini Fridge comes on but keeps nothing cold. I defrosted in August and it worked for awhile and now it defrosted on its own and no longer gets cold.
Nov 12, 2008 | Haier Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
