Question about Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Where is the on button
Can not locate the on button can not locate the on button
Dirt cup release button is stuck and not operating even after pressing very hard. i am worried it will brake. Please guide.
Hello there! The dirt cup bottom door should swing open quite easily when the release button is pressed. If you are concerned that you may break the dirt cup we recommend you take your vacuum to a Hoover authorized service center for assistance. The UH70015 comes with a 60 month limited warranty. Follow the link below to locate the nearest service center to you. Service Center Locator
Hope this helps!
Sep 17, 2014 | Hoover UH70015 Bagless Upright Cyclonic...
Dyson DC14 reset button location
go to http://content.dyson.com/support/?basketTotal=0.00&basketQty=0&logged=false
proceed with your models, and see videos or troubleshooting or video for to se the reset button.
God bless you
Aug 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
Model 6970 will not start have checked all hoses tried to locate reset button by sticker on back of machine; where is it?
The reset button is the little white button (approx. 1/16" inch wide) by the sticker.
Mar 24, 2011 | Simplicity Vacuums
Where is the on / off switch located on a dc11 please?
the button is located on the top left on the rear of the machine. It's a Yellow circular button with a circle and a vertical line in middle of it.
Here's a copy of the Owner's Manual for the DC11
Hope this helps
Apr 13, 2010 | Dyson DC11 All Floors Bagless Canister...
Where is the reset button on the Riccar 8995
The reset button on the Riccar 8955 is located on the back of the vacuum cleaner, at the very bottom, right above the rear wheels. You can push the reset button with a ball point pen or something similar.
Feb 15, 2010 | Riccar 8955 Upright Vacuum
My riccar will not work
Reset button is located in rear near left wheel. A white button, push in with paper clip to reset
Dec 13, 2009 | Riccar R100 Vacuum
Restart button
Usually there is a red reset button to push on top of the power head, but some are on the back edge of the powerhead.
May 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Brushes won't turn remain motionless as if cleaning hard floors even though button depressed could it be a problem with the brushes or button still under guarantee
There is a re-set button located on the brush head on the left side as viewed if you are standing directly behind the vacuum cleaner. It is black in color and is recessed slightly into the cover of the brush cover. It is round and about the size of the head of a country match and sticks up about 1/2 inch. Just press it to reset. Also, don't forget to press the grey on-off brush switch located beside the red on-off which is located near the top of the handle. Hope this information solves your problem. jawebb3@suddenlink.net
Mar 06, 2008 | Dyson DC18 all floors Bagless Upright...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum Logo
16 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
