Question about Kitchen Appliances - Others
Rational Oven
Why combi oven error code 32
If it is a Rational CM or CMP gas oven, then there is a problem with the ignition module.
Feb 03, 2017 | Combi Ovens
I have a rational combi oven electric 3 phase model number cd61 can anyone help that when should the oven fan motor start after the oven is on and how to test the motor
The motor should start as soon as the door is closed.
to check the motor, I need to know the s/n. Some motors use contractors, others use electronic motor control.
Apr 20, 2016 | Combi Ovens
RATIONAL CPC GAS
Hi, does the oven work okay on hot air? Steam function uses the steam burner and hot air burner so there is alot of possible causes.
Mar 21, 2014 | Combi Ovens
Rational combi oven
Any wires out the back that are loose?
Jul 04, 2013 | Kitchen Appliances - Others
Rational combi oven service manual
Alarm beeping control board not working
Apr 28, 2010 | Ovens
RATIONAL COMBI OVEN ELEMENT GLOWING RED -IS THIS NORMAL?
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
Feb 05, 2010 | Ovens
Kitchen Appliances - Others Logo
43 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
