Question about Peg Perego My First Craftsman Tractor Ride-on
Shear pin for model 944.528241
Need a shear pin for a craftsman snowblower model 944.528241
I just replaced a shear pin on my craftsman snowblower and now the auger will no turn when handle is engaged
maybe there ias damage to the gears in the center piece. is the fan that blows the snow out turning?
Feb 07, 2015 | Craftsman Garden
Looking to see what shear pin the sno trac snowblower model 310-680502
Go to www.doityouself.com Look under who makes sno trac snow blowers. The article tell you what to do.
Mar 19, 2014 | Craftsman 16" High Garden Tractor Snow and...
How to change shear pin
With the motor OFF, the shaft shouldn't rotate, so you should be able to rotate the auger by hand until the holes line up.
Mar 01, 2014 | Craftsman Sears Snow Thrower Manual Model...
Broke a shear bolt on my craftsman 5.5 hp snowblower 24 inch/ the original unbroken side is a bolt with a nut. the storage bolts in a sealed pack are a copperlike bpolt or pin with a copperlike curved...
Is there a hole thru the shaft of your replacement shear pin ?
If so the curved wire is a retention clip. Pull the clip out of the pin. insert into the proper location. The straight part goes thru the hole and the curved part automatically clips over the shaft to hold the shear pin in place.
Oct 13, 2017 | Garden
Auger on craftsman snowblower is very slow.how do i adjust idle
Not sure how long you have owned this machine but the auger does not turn fast. It 's job is to chop up the snow and push it back to the impeller. The impeller is the round plate in back of the augers that actually throws the snow out the chute. That turns fast. Check to be sure the shear pins are not broken. Shut the machine off. Wait for the augers to stop spinning and then try to turn the augers by hand. If they spin on the shaft then the shear pins are broken-replace them by using original equipment shear pins.
Dec 22, 2012 | Garden
Swisher 27" snowblower front impellers turn free
Hi Craig,
Most snowblowers incorporate "shear pins" between the motor and auger. A shear pin looks similar to a nut and bolt or pin that couples the drive to the auger - but it designed to break or shear off to prevent damage to the auger or motor in the event of a jam or overload. They look like these:
Only the shear pin recommended for your particular brand and model snowblower should be used. Under no circumstances should a regular bolt or other steel pin be used instead of a shear pin. Check your manual or consult with Swisher to determine the correct shear pin for your snow blower.
I hope this helps & good luck!
Dec 21, 2012 | Garden
I have a Craftsman 9hp snowblower and it is not blowing snow. Both shear pins are intact but the 2nd stage auger does not seem to be spinning to throw the snow through the chute.\r\nIs there a belt or...
It is belt driven, the belt is located between the chute and the engine behind the inspection cover some have it on the top and some on the bottom.That model may have to be split in half to get the belt past the shaft.But regardless it can at least be inspected by taking the cover off.Please let me know if this helps
Jan 19, 2011 | Craftsman 16" High Garden Tractor Snow and...
HALF OF AUGER NOT WORKING
When you got something caught in the auger, the shear-pin probably did it s job and broke, to save the gear box. Remove the old shear pin and install a new one
Mar 02, 2009 | Craftsman 16" High Garden Tractor Snow and...
Peg Perego My First Craftsman Tractor Ride-on Logo
55 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
