Question about Cisco 7940 IP Phone
Pc gone out of network after installing cisco
  • 48 Answers
Chances are that your Cisco IP phone itself is the culprit. The ethernet jack for PC Connectivity isn't secured properly. If your phone gets dropped, or even if it was just pulled the wrong way the jack will disconnect from the traces. It's a fairly simple repair, but generally not something that everyone would want to do. If you call IdacomUSA they can repair the jack for you and make sure that you'll always be able to connect a PC in-line with your Cisco IP Phone.
IdacomUSA
1-800-903-9190
Posted on Jun 17, 2009
Need cisco network magic pro key pls
Try www.wanetelecoms.com
I get nearly all my software on request from there.
Jan 22, 2014 | Cisco NM300 Network Magic Pro 5.5
Tip
Cisco 1841 Router, Hot Sales Product Cisco 1800 Business Router
The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
on Jul 07, 2011 | Computers & Internet
Can't install WRT400N cisco router need setup software or manual
Connect ISP modem to wireless router and then PC with cable. If that is fine you have a network. The easiest way now is to activate WPS on both devices. If this is not an option check web interface for network. Type 192.168.1.1 in web browser.
Aug 28, 2012 | Cisco Computers & Internet
Reinstalling cisco m20 0n vista
Is it re-installation of complete network or you are just trying to add Vista computer to the network?
Is it a complete re-installation then you can reset the router to factory default settings and then try to reconfigure it.
You can run Cisco connect software on the main computer or you can also reinstall it manually,
Read how to reconfigure router manually,
If you trying to connect Wireless Vista computer to the network then you can simply search for the WiFi and then join the wireless network on Windows Vista computer
Jun 05, 2012 | Linksys by Cisco Cisco Valet Plus Wireless...
Where do you get cisco connect
Cisco connect is the software that comes with the router.
You might have installed the Cisco connect software while installing your router for the first time.
Once you open the Cisco connect software for E1000, you will find the password to access the wireless network.
If you have not installed Cisco connect then you can open the setup page of the router and check the wireless settings.
Dec 17, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
How to export log from CISCOASA?like other cisco device logging 1.1.1.1 i want similar kind command in CISCO ASA
ASA's log is usualy stored localy on ASA itself, so easiest way to export that log is to go with telnet/ssh/console on it, do a command : show logging and copy/paste output into a new file.
but beware - this log is really short and as soon as ASA is rebooted - it's gone.
you could set asa to log to a syslog server (free on linux/freebsd or for windows use KIWI app).
that way all ASA log output is stored on pc/server running your syslog server.
Jan 03, 2011 | Cisco ASA 5510 Firewall
Cannot see my network printers after installing ASA 5505
1. Please check your printer's IP address and port number is permited in your cisco firwall or not.
Mar 25, 2010 | Cisco ASA 5505 Firewall
The ping response time is very bad on Cisco 6506.
It should be Layer 1 Issue (Physical connection). Your cable, PC's Ethernet card or the Interface in your Cisco it self.
P.S.: If this information was helpful, please rate this solution. aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
Feb 24, 2009 | Cisco Catalyst 6506 chassis Networking...
Wireless router through Cisco ASA 5505 series
put the one cable to wan which come from internet and you have to connect the pc or any other connection then you connect in the lan
Dec 30, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Open Questions:
See all Cisco 7940 IP Phone Questions
Cisco 7940 IP Phone Logo
142 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
