Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Whirlpool microwave model mh7140xf fuse replacement
How to locate fuse
Whirlpool mivrowave W10292071A MH7140XF Microwave Oven
My whirlpool microwave hasn't worked sice powers outage. Is there usually a reset button or fuse, somewhere
Jan 03, 2013 | Whirlpool MH7140XF Microwave Oven
Own Whirlpool microwave model MH7100XY, everything works on it, however it does not heat anything, heard a small pop and after that it does not warm or cook anything?????
The pop sound is an indicator the magnetron is gone that heats the food. It is cheaper to replace the microwave oven than have it repaired.
Mar 19, 2011 | Whirlpool MH7140XF Microwave Oven
Microwave died
your microwaves internal ceramic safety fuse is blown most hdwg stores carry them they're a 15 or 20 amp fuse,dont replace w/any other type of fuse,but first find out why oven blew the fuse
Aug 13, 2009 | Whirlpool MH7140XF Microwave Oven
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
Outlet works but the microwave is dead, no power at all.
I had a similar problem with my Whirlpool microwave. I replaced a fuse (after reading posts in this forum) and it's working again.  I'm not sure how similar your model is, but in my case it was an in-line fuse in a wire leading down from the main fuse in the upper right corner behind the control panel.
Apr 04, 2009 | Whirlpool MH7140XF Microwave Oven
No power on microwave
Buy a new one. Microwaves have enough stored voltage/amperage to boil your blood. You should not be taking off the cover.
Mar 07, 2009 | Whirlpool MH7140XF Microwave Oven
I need User Manual for my microwave
Just click below;
Whirlpool Microwave/Hood Combination manuals, user manuals, owners ...
Whirlpool Microwave Hood Combination MH7140XF, YMH7140XF User Guide Get This Manual .... Please help find the manual for this Black & Decker Convection Oven ...
Hope this may help you; DON'T FORGET TO RATE:
Sep 06, 2008 | Whirlpool MH7140XF Microwave Oven
No Power Whirlpool MH7140XF
does it not light up at all? A microwave has a fuse on it. Probably accessible from the back panel. if not you would need to disassemble it. Most likely cause of this is slamming the door broke one of the safety switches the door has so the microwave knows when the door is open. And it shorted against something when it broke. It might have simply blew the fuse but then again you might have fried it.
Oct 01, 2007 | Whirlpool MH7140XF Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
44 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
