Question about Dell Latitude C800 Notebook
Works with power adapter but battery wont charge and tried new battery same problem?
  • wadeb05 Jun 16, 2009
    as in reformat? what will that do? thank you!
    Sergeant:
  • 322 Answers
Try formatting your laptop
Posted on Jun 15, 2009
Toshiba satellite c55t wont power on, just blinks once every 4 seconds
check power cord is fully inserted into laptop
if no joy
try also forcing a power down by holding in the power button for 30 seconds and then try power button again to power it up .
might be in hibernate mode !
Dec 04, 2017 | Toshiba Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
I have a dell inspirion 1545 the power light is flashing white and orange and the battery wont charge
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Oct 07, 2010 | Dell Computers & Internet
We just bought this acer aspire 5315 lap top brand new charger but battery still wont hold charge even plugged into the wall can anyone help please its for my kids to play?????????????? i have a gateway...
Oct 07, 2010 | Acer Aspire 5315 Notebook
Wont Charge, Message critical battery voltage. when I try to switch on Travelmate 4670
Sep 18, 2010 | Acer TravelMate 4672WLMi Notebook
Advent 9117 battery not holding charge, wont charge up with charger
Sep 12, 2010 | Computers & Internet
My computer wont turn on but the low battery keeps blinking (one of the symbol things under the keyboard) and when I try to charge it it wont charge.
First, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
Sep 06, 2010 | Toshiba Computers & Internet
My acer net book wont charge. It worked on my battery power but i dont want it to run out because when i plug in the charger, nothing happens. The orange light doesnt come on or anything. I have only had...
Aug 25, 2010 | Acer Aspire One PC Notebook
My dell studio battery wont charged. is it the battery, the charger or the plug in
Aug 21, 2010 | Dell Studio 17 Laptop
Try to charge but wont. and wont turn on even pluged in
Aug 21, 2010 | Compaq Presario M2000 Notebook
Dell Latitude C800 Notebook Logo
77 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
