Question about Panasonic KX-FP155 Plain Paper Thermal transfer Fax
Faxing I can not sent a fax...
  • 193 Answers
Re: faxing
Check weather the phone cord is connected in teh line jack on teh fax not in the extension>and set resolution-standard>and auto answer mode-o>and error correction mode-off>or u have over seas mode-it should be on>u have either any one of this>and baud rate-9600> check with band width on the pc>and reboot it>and check rate me solved if its help full
Posted on Oct 31, 2007
3 Suggested Answers
  • 2120 Answers
SOURCE: time date stamp on fax machine
The time it was sent, if they have the time set correctly on the sending fax machine
Posted on Mar 05, 2009
  • 1959 Answers
SOURCE: Sent faxes not printing clear
Per Brother's User manual,
Clean the machine’s interior and the primary
corona wire of the toner cartridge This is a common cause for your printing/copying problem. This should solve your issue. Best of luck.
Posted on May 20, 2009
  • 1126 Answers
SOURCE: How do I get a confirmation page of a sent fax on Canon SuperG3?
Tx (confirmation) Report needs to be enabled before sending the fax. Super G3 is an industry standard, not a model number. What model of Canon facsimile do you have? I have most User Guides I should be able to provide directions on enabling Tx Report. Let me know.
Posted on Aug 17, 2009
0 characters
3 Points
Are you able to print out a fax that was sent out approximately 6 months ago
No. Not from a fax machine. Some faxes have the ability to store sent faxes but this feature caused more problems with memory filling up than it solved. So, the machine usually deleted the job after a short period and it is extremely unlikely that your sent document is anywhere near your fax now. Not a stupid question though.
Jul 09, 2009 | Lexmark Fax Machines
White space in middle of faxes sent or received
Printing irregularites on sent faxes are due to spots or a dirty scanner.
Spaces on received faxes are due to a dirty drum, corona wire, or a failing or improperly installed toner cartridge. A new cartridge should be gently shaken back and forth sideways prior to installation.
Jun 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Need to confirm details of when and what number a fax was sent approx 15 days ago.
The only way to check old transfer info for faxes is by printing out the journal. The way to do this varies from fax to fax, but most often is either with it's own button "reports" (and then "fax journal"), or by choosing "print reports" in the regular menu. The journal is emptied during power outs, so if you have had a power failure since, you cannot get the information. Additionally, the only info you will get from this is to where/from where the fax was sent, and if it was successful. Any information on the actual fax content is unavailable.
Jun 03, 2009 | Brother Fax Machines
Need to retrieve record of fax sent in june 2008
You don't. In fact, you can't really retrieve a record for a fax you sent yesterday - other than the fax #'s you sent to, and the number of pages - And that record only goes back a few days.
May 06, 2009 | Canon FAX-L350 Plain Paper Laser
Time date stamp on fax machine
Mar 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon i-sensys fax-L100
The machine keeps in memory only reports of faxes sent or received until the page is full.When the report page is full, the earliest fax is removed to make way for the most recent. Therefore if you sent enough faxes after 4 Apr 08 to fill a page, there will be no record.
Aug 18, 2008 | Canon FAX-L1000 Plain Paper Laser
Not sure if faxes have been sent successfully how can i tell?
I am not technically qualified for faxes but most fax machines i have used have a setting that allows you to have a receipt that prints off after you have sent one, this is something that can be turned off if not wanted, look in the manual and it will tell you how to reset it, i think it was called "polling" after a fax has been sent it prints off this little bit that says what time it was sent how many copies and time received, fax number it was sent to and sometimes company name etc some machines i have seen and used have a poll button after you have sent your fax, try just pressing it, it may print out a conformation receipt of the last ten faxes sent hope i have helped, if so rate me please
Oct 04, 2007 | Canon FAX-JX200
Finding a fax confirmation in memory
you can get a prinout of last certain faxes received or sent(appx 20), if the number is among them, it's your luck happy faxing omnipresent
Sep 20, 2007 | Brother MFC-8220 Fax
Problem with sent faxes
Sep 17, 2007 | Brother IntelliFAX 770 Plain Paper Thermal...
Panasonic KX-FP155 Plain Paper Thermal transfer Fax Logo
79 people viewed this question
Top Panasonic Fax Machines Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Michel Smith
Are you a Panasonic Fax Machine Expert? Answer questions, earn points and help others
