My Betamax stops play, rewind or f/forward after approx five seconds
The VCR was working perfectly when it was put in store some years ago, but it no longer functions,:i.e. will not play, rewind or f/forward for much more than five seconds before stopping.
Kimi
  • 277 Answers
SOURCE: The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Posted on Nov 22, 2005
techman
  • 3130 Answers
SOURCE: Video tape gets eaten on rewind
Or the braking/tension mechanism is defective. Or the rewind clutch is defective.
Posted on Sep 01, 2006
dodgecharger
  • 254 Answers
SOURCE: VCR eats tape when rewinding
A couple of possibilities: 1. Braking problems: When VCR goes from FFWD, REW, Play to stop, there are a pair of "brake pads" engaged to stop the reels, and prevent tape spillage out into the machine. These pads, often rubber like, are on levers which contact one side of each reel. If you take the cover off the VCR, and look down where the tape is loaded, you will like see these brake assemblies. If the rubber pad is missing, or lever pivot points gummied up, then this is your issue. 2. Take up reel isn't being engaged to take up the tape on tape eject. When a tape is loaded into the machine, tape is pulled from the cartridge and threaded into play ready position. When eject mode is engaged, the tape must be pulled back into the cartridge, or you will have tape hanging out the front end of the cartridge, and may get caught on the VCR internals, or at least be mangled by the cartridge door. The often issue here is likely the idler assembly pivot point is sticky. This idler pivots, moving from the take-up reel (right reel) to the supply reel reel (left one), depending on what mode is selected. FFWD & play to the right, left for REW. If this idler is gummed up at it's pivot point, movement will be sluggish at best, and might not be engaging the right reel quickly enough to pull tape in before tape eject. This idler is sitting right between the reels down where the tape sits. A little light oil on the pivot point may be enough to loosen it up. Otherwise it might need to be removed and the old grease removed, and a drop or two of light oil applied.
Posted on Jul 10, 2007
Shuttle83
  • 1139 Answers
SOURCE: Sony DVD/vcr combo stops
This is an indication that the tape sensors may be dirty or going bad. It could also be due to tape tension (the lack of). Do you have the service documents for this device?
Posted on Sep 22, 2007
Danmart
  • 291 Answers
SOURCE: VCR won't rewind
Soution #1 get nice but cheep VHS " rewind " macine.
2nd. Some machines have a special rubber wheel in the center,between the left [ take up or rewind ] & right [ play\record ] assemble. VERY diffiult to repair if u don't know what u are doing.
3rd. Find & REplace EVERY rubber band that u find in the machine.
Posted on May 30, 2008
Why does my vcr play, fastforward and rewind for 4 seconds then stops for no reason?
When the mechanism is damaged the VCR will attempt to play and then shut itself down to prevent any further damage. If you remove the top cover and look around inside you will probably find the cause of the failure.
Aug 10, 2014 | Panasonic Televison & Video
Denon DRM 740 tape does not play
hmmm...sounds like the transport motor/foot are stuck..open it up, and inspect around those items(where the tape actually clamps down) and see if you can see anything in there. Might even be a bug, no fooling..
as to repairs..you are most likely talking some major money, and a long time in the repair depot, which I believe is in Rio..I'll check that for you while you do this part.
Mar 16, 2008 | Denon DRM-740 Single Dual Cassette Deck
My vcr PSVR 73 starts and than stops. I will pay the $35.00 if this is fixed. If not I do not want to pay
My Panasonic pv-4661 does not rewind, play nor forward a tape, it says it is locked. Any suggestions? I have tried pressing the stop button for 10 second, also tried pressing the power button for five seconds. No solution... Any suggestions will be appreciated.
Jan 13, 2013 | Proscan PSVR73 VHS VCR
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
The VCR shuts off after just a few seconds of playing or rewinding or fast forwarding. The tape goes in, and when you push play (or any direction), the unit will try and play it and then it will shut the...
There is a part that is called an idler wheel assembly that is critical for play, rewind, and fast forward, and may have stopped working. The second possibility is that the drive belt that runs the idler assembly has broken or come off.
Jan 01, 2011 | Philips DVDR3435V/37 DVD Recorder/VCR
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
VCR won't rewind HS-U447
A VCR is still useful and it is still the best method of archiving something you want to keep due to the fact it is possible to edit or repair the tape when something goes wrong but that is quite impossible with digital discs and other digital archiving methods.
I don't know much about how they work because so far I have only needed to clean the heads periodically to keep them working. They do contain a number of belts, rubber wheels and clutches andit is possible something made of rubber has deteriorated and stopped doing what it is supposed to do.
You will probably find loads of useful video content on youtube about that.
I have many VCRs due to the fact when the fashion passed folk were giving them away, putting them out for the garbade or simply leaving them in the street - that was just after I had bought a new one because it was much cheaper than getting an estimate from a repair shop.
I suggest you ask on the neighbourhood grapevine if anyone that still has a VCR would pass it on to you or enquire on freecycle, preloved or gumtree. Check at your local recycling centre or even haunt the discount stores until you find a new one - it will be cheaper than a repair unless you want to try and repair it yourself.
Apr 01, 2017 | Mitsubishi HS-U447 VHS VCR
Sony VCR rewind and counter problem
The belts are slipping. Every 5 years is about right for replacing them all.
Jan 24, 2008 | Televison & Video
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
