Question about APS787 Prestige Remote Start and Security System w/Keyless Entry
After battery failure remote start wont work
Remote starer
How do I reprogram a viper 5101 remote starer
on remote press the middle button for 15 sec. after three flashes on remote, put key in ignition and turn ignition on but dont start it. press button on antenna, release and then hold until horn honks or led flashes on antenna. lastly press lock within 5 sec
Jul 30, 2014 | 5101 LE 1 Way Car Remote Starter System
Immobilizer fault on a Picasso hdi 2001 car starts
Take to dealer to reset the key code on the ignition key.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/stephen_171aeeebef53a898
Oct 08, 2013 | Magnum Remusshield Finger Touch...
2003 cavalier remote start wont work most of the time
Not to sound smart, but when was the remote battery changed last. My wifes remote battery was low and she couldn't start her car yesterday. New battery, no problem.
Dec 26, 2012 | Prestige Remote Start
2002 buick Lesabre (Limited) - When operating the AC I have warm air coming out of the on driver's side vents and cold air on coming out the passanger side vents.
check battery,battery cables,starter,starer solenoid, check if your battery have any power left, by turning lights on, if light is strong then on the starter motor,remove the remote wire, the thin wire connected to the starter from the ign. switch, instead of the remote cable, try to by pass it, with battery voltage, with ign switch on on pasition, if your starter works the starter is good if not change the estater, if starter works then check the remote wire, could be damage, could be the starter switch, fuse , or the starter relay. when working on car always make sure if the engine starts there is rotsting components. Thanks
Oct 15, 2011 | 2002 Buick LeSabre
MY DODGE RAM HAS A FACTORY INSTALLED REMOTE START BUT THE REMOTE STOPED WORKING I CHANGED THE BATTERY BUT STILL DOES NOT WORK ANY DEAS WHY
Oreilly Automotive stores have a little device the picks up a signal from a remote. Maybe your local parts store will have one. This will verify that your key F.O.B. is working. After that....fuses or possibly a frequency switch in the key FOB got bumped when you changed batteries. Otherwise, catastrophic failure....sorry.
May 09, 2010 | 2007 Dodge Ram 2500 Mega Cab Laramie
My remote stopped working with my television. all I need is a manual that I cannot find. for CL007 remote
Remotes are pretty simple things to fix. a few problems, tests and fixes.
1) test remote closer to device - if it works then replace batteries.
2) If some buttons fail to work that used to work - disassemble and clean muck off board and rubber contact pad.
3) remote will not work at all at any distance - use camera on phone to see IR led operation when pushing buttons on remote - could be batteries, IR led failure or ceramic resonator failure - you need test equipment to faultfind.
The only parts that tend to fail on a remote are batteries, IR LED, Ceramic resonator, and dirty/wet board/rubber contact pads
Mar 19, 2010 | Zenith ZN620 Remote Control
Why does the car start by itself after I installed the remote starter?
i could be to things, if the remote start has a remote timer, that you can program the remote start to start every hour for like 5 minutes, or there is an activation wire on the remote start that is getting grouned somehow and allowing the car to start. What i would do is look in your manual and see how to bring the remote start back to all its original factory settings, and make sure all loose wires are taped up and not touching anything. If you need help on manuals or anything let me know and i can walk you through it.
Feb 27, 2009 | Avital Vehicle Parts & Accessories
Battery Died, now remote start wont work at all
there is a reset button stuffed under the dash ( drivers side ) , it has two wires from it to the alarm box ( not the switch )
Jan 11, 2009 | Viper Security and Remote Start System...
When you turn the key, get a clicking noise and no engine cranking, the clicking noise is normally the solenoid. The solenoid is a heavy duty relay that applies 12 volts to the starter. In most cases the solenoid is mounted physically on the starter. If you got a remote starter at the auto parts store you can
hook it up to the solenoid directly and push a button on the remote starer , (which takes the place of the ignition switch) and see if the engine cranks
Hope this helps Good Luck Loringh
Oct 25, 2008 | 1997 Ford Taurus
APS787 Prestige Remote Start and Security System w/Keyless Entry Logo
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
