Question about Rockford Fosgate T2d215 2400w Max 15" Dual 2-ohms Car Audio Component Subwoofer
My amp seems to be burnt out
My amp won't start for a good while it would but would turn off a lot i never ran anything it couldn't handle
Engine won't start
No it doesn't seem like anything
You have to test something to confirm
that statement
You either have spark & injector pulse or you don't
You have fuel pressure & volume at the motor or you don't
You have even compression in all cylinders & equal contribution
or you don't
Share your test results if you need help
Mar 06, 2013 | 1999 Ford Taurus
Dying 1996 Jeep Grand Cherokee Limited
I wouldn't think catalytic converter, without it giving some indication that it was going bad, but without testing it is hard to say.
When it cranks and won't start, check for battery voltage to the coil on the dark green wire, with key ON. If you have power at the coil, it might be a bad coil. If no power to the coil, it could be a Crank Position Sensor or the Cam Position Sensor inside the distributor. If one of those is bad, it can stop the computer from sending power to the coil.
Good luck.
Jul 06, 2012 | Jeep Grand Cherokee Cars & Trucks
2000 Mazda MPV Starts & runs won't go out of Park Shifter handle moves won't change gears??
I had this issue in the past. All I did was to replace the brake switch. This part is located behind the brake pedal. Btw, if you this run into this issue again in the future, you can always push this switch with your finger and it's located on top of your steering wheel enclosure, this will disengage the shifter.there is a small rectangle shape cover that you need to remove first.
Aug 08, 2017 | 2000 Mazda MPV
I have had a Nokia 6060 or 6061 (I can't find a # on it for about ten years. I have only recently started to text a lot more. I'm very unfamiliar with things like capitalizing etc. But...
First of all try to press for 5 seconds to # button still if there is no answer again press # repeatedly unless ABC/abc will appear without underline.I think this may help you.Good luck
Aug 26, 2011 | Nokia 6060 Cellular Phone
'04 Kymco Venox won't start. Bought it a few months ago from someone w. about 20,000 miles on it. Always runs good/never had a problem w. it 'til yesterday. Ran outta gas on the road...put more...
Hi Mrcherry99, for this situation I would call my local dealer or reputable shop's service department and inquire about any possible quick fix. If necessary transport your vehicle to the dealer or shop and have a professional technician take it for a test drive, if possible, and give you a written estimate of repairs and answer any specific questions you may have about your issue. Good luck and have a nice day.
May 18, 2011 | 2005 Kymco Venox 250
Starts good 1996 f150 4.9 stick shift..runs for no. of miles.or all day....than just dies...won"t start for 15 minutes...than starts and runs like a champ..had at dealer twice....but always started and ran...
CHECK ALL THE IGNITION ELECTRICAL WIRES ON THE IGNITION SYSTEM.CHECK MAKE SURE FUSES ARE IN TIGHT.IF YOU BATTERY IS OLD.I SEEN A BAD BATTERY KILL THE ENGINE.IT HAS A PLATE SHORTING ON INSIDE.IT WILL KILL THE ENGINE.LIKE YOU TURN OFF YOUR SELF.
Aug 02, 2009 | Ford F-150 Cars & Trucks
Cannot complete uninstall of adobe acrobat 9 pro.
here is a link from adobe's website, this will help you completely remove the product.
http://kb.adobe.com/selfservice/viewContent.do?externalId=kb400654&sliceId=2
Apr 12, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Rockford Fosgate T2d215 2400w Max 15" Dual 2-ohms Car Audio Component Subwoofer Logo
29 people viewed this question
Top Rockford Fosgate Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Rockford Fosgate Audio Player and Recorder Expert? Answer questions, earn points and help others
