Question about Polaroid FLM-323B Television
Sound distorted, just hiss, on analogue tv.RF2 input from sky
Tv ok sometimes
Hi all please help, I have an LG 32ld450 with no remote so I'm using my sky+hd remote. The problem I have is that I've tried to set up a magic eye in my room but I can't get off DTV to get the right...
Your TV has menu buttons on the side. When you go in to the menus then the normal thing is for the Volume and channel keys to act as Up/Down and Left/Right. I can't tell you which will do what function; you'll have to try it, but they should work. The TV also has an OK/Select/Enter button on it so you can activate a sub menu as you navigate through.
From the side menu it should be possible to access the tuning menu. Once in there you can set up the TV's analogue tuner to receive the Sky box RF2 out signal.
As for how you change between the analogue and DTV tuners, that could be a tougher nut to crack. There's a little trick with a Sky remote that allows one to program the Help key to bring up a TV's input menu:
On your Sky remote, press TV
Now hold down Green and Select together until the red LED flashes twice.
Now press the help key
Now press Select
Now, when you press TV and then the Help button the TV should display its input menu. Pressing help repeatedly will cycle through the inputs.
Of course,m the above only really helps if the TV lists the analogue and DTV tuners individually. If it doesn't, and there's now way of accessing it through the TV's menu navigation, then you might have to just bite the bullet and go to a supermarket and buy a cheap universal remote. Check it has the TV/Radio or TV/DTV function before you buy.
Sep 17, 2014 | Televison & Video
How do I tune sky tv into my new Toshiba television
If the TV set is on the same stand as the Sky box then you don't tune at all. Connect with either a HDMI cable or a SCART. Use the AV input on the TV.
If you mean you have a bedroom set, and Sky is piped around the house on RF, then that's something different.
Make sure your TV has an analogue tuner as well as the digital one used for Freeview. (check the remote for a TV/DTV button). Go in the the TV tuning menu, and do an Auto tune for both analogue and digital.
Sep 13, 2014 | Televison & Video
How do I get my Sky channel back on analogue after re-tuning freeview
Go in to analogue tuning. Tune just the analogue side of the TV.
Sep 05, 2014 | Televison & Video
Can you watch the same sky channel on 2 tvs
Yes if you use the rf2 out on the box, cable it to the aerial input of the tv in the other room using uhf coax cable (aerial cable), and tune the tv in analogue mode (not freeview but the old analogue) to the sky box. It's usually on CH68 but if you do an autotune it should find it. Of course you will only be watching in SD not HD on the second set.
Jun 19, 2014 | Computers & Internet
I have a sky hd+ box in my lounge and wish to make the sky work in my bedroom, I am happy to only watch what is on the lounge tv in the bedroom (not have multi room) thanks Nigel
Run a coax cable from the sky hd+ box at the rear from the RF2 coax port, and into tv in bedroom.
If you want to change channels, buy a magic eye from eBay for a couple pounds, enter sky settings, and turn power on to the RF2 output. this will supply your coax to bedroom with 9v which will power your magic rye
Oct 23, 2013 | Neet Cooler Trunk Organizer
Just installed a sky magic eye to my digital tv upstairs, works perfect. however I have now lost all my digital channels!!
Hi
If you have installed a sky magic eye, i am assuming you have taken a sky feed from the RF outlet of the back of the sky box to view sky in another room, if this is the case, this is an analogue feed which you would have to tune in manually to the second tv, this would suggest that you havent lost the digital signal you just have you second tv selected on analogue. On the assumption your system is connected like the following;
Sky box connections
Main aerial input
sky sat input
rf out to second tv
Reagrds
TechSupp12
Dec 12, 2010 | Televison & Video
Sky
You do not say which breed of sky you have.. old analogue, digital, sky + or sky HD if you have old analogue then you may have to connect through aerial connection, digital will have a scart socket to connect to your tv, sky + will have the same and finally the cream of the crop sky HD will have hdmi in addition to scarts.
The very least you need to do for a digital picture (not to be confused with hi-def which it isn't) is connect through scart lead then unless it auto-switches to scart input upon switching on sky use your tv remote to select the ext input 1, 2 or 3 etc (some remotes have a button called source for this some call it input etc) select each ext input until you find the one your sky is connected to
Oct 12, 2008 | Televison & Video
RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Sep 27, 2007 | Televison & Video
Polaroid FLM-323B Television Logo
42 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
