Question about Dewalt Dw739 230V Bandsaw - Var Speed
Dw739 pulley drive belt
Belt replace instructions
The accessory drive belt is a serpentine type belt that is driven by the crankshaft pulley
The belt drives the A/C compressor , alternator , power steering pump and water pump . Belt tension is maintained by an automatic belt tensioner .
Removal:
1. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be removed from pulleys .
2. Remove accessory drive belt .
Installation:
NOTE: When installing drive belt on the pulleys, make sure that belt is properly routed and all V-grooves make proper contact with pulley grooves.
1. Install the accessory drive belt around all the pulleys except for the alternator pulley.
2. Using a wrench, rotate accessory drive belt tensioner counterclockwise until accessory drive belt can be installed on the alternator pulley .Release spring tension onto accessory drive belt .
Jul 23, 2014 | COMPASS 2008 AUTOMATIC REMOTE ONE WAY...
How do I get a diagram to show me how to put a serpentine belt on a 1998 Ford Escort Station Wagon?
you ask here. Please rate highly
SECTION 303-05: Accessory Drive 1998 Escort/Tracer Workshop Manual
REMOVAL AND INSTALLATION Belt -2.0L SPI Removal
  1. Relieve the drive belt (8620) tension.
    • Use a (A) ratchet or breaker bar inserted in the square hole in the drive belt tensioner flange.
    • Rotate the (B) drive belt tensioner (6B209) in a clockwise motion to release belt tension.
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the engine splash shield.
  1. Remove the drive belt from the accessory drive belt routing pulley (6C348) and then the remaining accessory pulleys.
Installation
  1. Position the drive belt over the accessory pulleys. Raise and support the vehicle if necessary; refer to Section 100-02 .
  1. Install the engine splash shield.
  1. Rotate the drive belt tensioner in a clockwise motion.
  1. Slip the drive belt under the belt idler pulley (8678) and release the tool. Remove the tool from the drive belt tensioner.
  1. Accessory Drive-With A/C
  1. Accessory Drive-Without A/C
Belt -2.0L Zetec Removal
  1. Raise the vehicle on a hoist; refer to Section 100-02 .
  1. Use a 13 mm wrench to rotate the drive belt tensioner (6B209) in a clockwise motion.
  1. Remove the drive belt (8620).
Installation
  1. Position the drive belt on all the pulleys and the drive belt tensioner.
Item Part Number Description 1 10300 Generator 2 19A216 Drive Belt Idler Pulley 3 3D673 Power Steering Pump Pulley 4 8509 Water Pump Pulley 5 6B209 Drive Belt Tensioner 6 19703 A/C Compressor 7 6316 Crankshaft 8 19A216 Drive Belt Idler Pulley 9 8620 Accessory Drive Belt
  1. Install the drive belt and gently release the drive belt tensioner.
    • Run the engine for several minutes to seat the belt into the pulley grooves.
Jul 09, 2011 | Ford Escort Cars & Trucks
I need a serpentine belt diagram for a 1999 ford escort
SECTION 303-05: Accessory Drive 1999 Escort/Tracer Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 06/06/1998 Accessory Drive Component Locations -2.0L SPI with A/Ca27194a.gif
Item Part Number Description 1 6B209 Belt tensioner 2 10344 Generator pulley 3 8620 Belt 4 3A733 Power steering pump pulley 5 8678 Belt idler pulley 6 2E884 A/C clutch pulley 7 6316 Crankshaft damper
Component Locations -2.0L SPI without A/Ca27193a.gif
Item Part Number Description 1 6B209 Belt tensioner 2 10344 Generator pulley 3 8620 Belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft damper
Item Part Number Description 1 10300 Generator pulley 2 19A216 Belt idler pulley 3 3D673 Power steering pump pulley 4 8509 Water pump pulley 5 6B209 Belt tensioner 6 19703 A/C clutch pulley 7 6B320 Crankshaft pulley damper 8 19A216 Belt idler pulley 9 8620 Drive belt NOTE: Drive belts (8620) with automatic drive belt tensioners (6B209) do not require adjustment.
NOTE: When a new drive belt is installed or a drive belt is re-installed after a service procedure, the drive belt does not fully seat into the pulley grooves until engine has run for several minutes.
This vehicle is equipped with:
  • a V-ribbed serpentine accessory drive belt.
  • an automatic drive belt tensioner.
New drive belts must be of the same type as originally installed.
Check the drive belt condition at 96,000 km (60,000 miles) then after every 24,140 km (15,000 miles).
Mar 06, 2011 | 1999 Ford Escort
Serpentine belt routing for 2001 ford taurus
what engine? Please rate if this helps. Took a lot of time to dig out.
here's 2002 3.0L 2 valve
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
4 valve
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
water pump 4 valve
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8509 Water pump pulley 4 8W508 Drive belt tensioner pulley
Dec 20, 2010 | Ford Taurus Cars & Trucks
Belt diagram
Accessory Drive adobe.gif Printable View (62 KB) Component Locations 3.0L (2V)a0007698.gif
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 19D784 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6A312 Crankshaft pulley 8 8A528 Coolant pump pulley
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 19D784 A/C clutch pulley 4 6A312 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8A528 Coolant pump pulley 4 8W508 Drive belt tensioner pulley
Nov 28, 2010 | 2004 Ford Taurus
Serpentine belt diagrm
Not sure if you have the 3.0L 2V or the 3L 4V so heres both. Hope it helps.. Cobra,, :-)
Item Part Number Description 1 3A733 Power steering pump pulley 2 8509 Water pump pulley 3 2E884 A/C clutch pulley 4 8620 Drive belt 5 6312 Crankshaft pulley 6 6B209 Drive belt tensioner pulley 7 10346 Generator pulley
Jun 05, 2010 | 2000 Ford Taurus
Serpentine belt diagram 2002 ford escape picture of serpentine belt pattern
CLICK on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2002/make/ford/model/escape/2002_ford_escape_drive_belt_routing_diagram.htm
Feb 27, 2010 | 2002 Ford Escape
The 2001 Windstar we have here only has 7 pulleys and the diagram dosnt match any ides.
here you go. please rate, thanks
Item Part Number Description 1 8620 Drive Belt 2 10300 Generator Pulley 3 6C348 Idler Pulley 4 6B209 Drive Belt Tensioner 5 3D673 Power Steering Pump Pulley 6 2E884 A/C Clutch Pulley 7 6A312 Crankshaft Vibration Damper Pulley 8 8A528 Water Pump Pulley
s1w~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The drive belt tensioner has no provision for adjustment and will be damaged if forced to travel beyond its operating range. Automatic tensioners are calibrated at the factory to provide the correct amount of tension to the belt. There is no need to check tensioners for proper tension.
NOTE: Drive belts (8620) with automatic drive belt tensioner (6B209) do not require adjustment.
NOTE: When a drive belt is installed new or reinstalled after a service procedure, the drive belt does not fully seat into pulley grooves until engine has run for several minutes.
  • automatic drive belt tensioners.
New drive belts should be of the same type as originally installed.
Drive belt chirp is a regularly occurring chirping noise that occurs due to:
  • pulley misalignment.
  • excessive pulley runout.
It can be a result of a damaged pulley or an incorrectly replaced pulley that was not correctly aligned.
To correct drive belt chirp:
  • determine the area where the noise comes from.
  • check each of the pulleys in that area with a straightedge to the crankshaft pulley (6312) for front accessory drive and the water pump drive pulley to the water pump.
  • look for the accessory pulley to be out of position in the fore/aft direction or at an angle to the straightedge.
Drive belt squeal is an intermittent noise that occurs when the drive belt slips on a pulley during certain conditions such as:
  • engine start-up.
  • rapid engine acceleration.
  • A/C clutch engagement.
Drive belt squeal can occur under the following conditions:
  • The A/C discharge pressure goes above specifications:
    • The A/C system is overcharged.
    • The A/C condenser airflow is blocked.
Feb 27, 2010 | 2001 Ford Windstar
Belt diagram
2 valve
Item Part Number Description 1 8679 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Water pump pulley 7 2E884 A/C clutch pulley 8 6B209 Drive belt tensioner pulley
4 valve
Item Part Number Description 1 19A216 Belt idler pulley 2 10300 Generator clutch pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft pulley 6 8A528 Water pump pulley 7 19D692 A/C clutch pulley 8 6B209 Drive belt tensioner pulley 9 19A216 Belt idler pulley
Oct 26, 2009 | 2003 Mercury Grand Marquis
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
Dewalt Dw739 230V Bandsaw - Var Speed Logo
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
