Question about American Range AF-45 45lb Commercial Deep Fat Gas Fryer
Leaking oil tank
Oil leaking at the bottom
I have a 1995 Toyota corolla and I recently noticed I had a gas leak I sealed the hole with JBL epoxy to hold me over until my new tank arrives but it looks as if there is oil mixed in with the gas .
Keep checking the oil level and the transmission fluid level to make sure they stay full, but there should be no oil in the gas tank.
There may be water, however, and it may be brown like oil.
Water will sit in the bottom of the tank and make rust underneath the gasoline, since gasoline floats on water.
Dec 29, 2016 | 1995 Toyota Corolla
Leaking oil when not in use
There's an o ring on the bar mount. It seals the oil passage from the tank to the bar. It will leak there. The tank itself may have developed a crack that will leak. The rubber lines from the tank to the pump can leak if they are cracked ir gummy.
Jun 29, 2015 | Stihl MS171 12" Chainsaw
Oil leak
If the hose comes out the top of the transmission, this is the transmission vent line.
Make sure the line doesn't "dip" anywhere alone it's run, causing a low area where residual oil would "pool", then blow out under pressure.
Also, make sure transmission fluid isn't over-filled.
Mar 20, 2014 | Harley Davidson XL Sportster 883 Hugger...
2005 fat boy oil change
Stand the bike upright. Remove the dipstick from the oil tank. Remove the drain plug on the bottom right side of the frame. While the oil is draining, replace the oring on the drain plug. Remove and replace the oil filter, after filling the new filter half full of oil. Replace the drain plug. Put 3 quarts of oil in the oil tank. Replace the dipstick. Start the bike and check for leaks. No leaks, you're done! I use HD Syn 3 synthetic oil in my '04 Fatboy, but you can also use a conventional 20w50, as long as it's made for use in and air cooled motorcycle. Don't use car oil!
Nov 04, 2012 | 2003 Harley Davidson FLSTF Fat boy
Oil leaking from breather tube on my 1991 harley davison heritage soft tail on first start after four year storage
The engine "sumped", meaning the oil in the oil tank leaked past the check ball in the oil pump and is now in the bottom of the crankcase. Place a pan under the breather tube and run the bike until no more oil comes from the breather. keep an eye on the level in the oil tank. You don't want to run it dry. If you added oil, chances are the dipstick will fly out due to too much oil pressure. When you're done, either change the oil and filter, or add oil to the tank.
Jun 25, 2012 | Motorcycles
When running, oil is spewing out all over, covering the saw and my clothes. Is there any way to stem or regulate the flow?
Make sure your oil cap is tight & not cross treaded. If loose, any airpressure will force oil out the bottom, even sitting still without running. Sitting over night with an air leak will force all the oil out of your tank and all over . Something like putting a straw in a glass of water, putting your finger over the end and taking the straw out of the water, the water will stay in the straw untill you take your finger off. To oil your chain, push down on the cap to depress the thin plastic oil tank, when your done oiling, the tank will return to its shape, and draw air in from the bottom or where the oil went out, ready for another oiling.
Jun 22, 2011 | Poulan 14" Electric Chainsaw
OIL LEAK ON FRAME BUT NOT FRON ENGINE
You didn't give me much information. If it's not from the engine, the only other thing on the bike that has oil in it is either an oil line or the oil tank. Sportsters are notorious for developing a leak on the backside of the oil tank, If you take the battery out and look at the bracket that comes from the oil tank to the battery tray, you may find your leak.
If the oil tank is leaking, purchase a new tank. I saw one guy try to stop the leak by coating the tank with "Creme" fuel tank coating. It did stop the leak but after a while the heat from the oil turned the coating brittle and it chipped off and stopped up his oil pump.
Good Luck
Steve
Apr 22, 2011 | 1993 Harley Davidson XLH Sportster 883
Oil change xl 1200
Warm engine up to operating temp. Remove plug in bottom of oil tank. Be ready the oil comes out fast and is difficult to catch. Allow to drip into catch container while you remove
oil filter and install new one. Reinstall tank drain plug and fill with oil. Start but do not tach up allow oil pressure to come up. Shut it down and check oil again.
Good Luck and Ride Safe O yes do check for leaks
Feb 04, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
I have a 2000 Electra Glide that leaks oil where the cases are joined. Anyone else have this issue? Worth repairing?
Hi Goulets, if it's leaking from the case seams aside from splitting the cases and resealing them is to check the torque on the case bolts 1/4" bolts/nuts 10 ft lbs. 5/16" bolts/nuts 20 ft lbs. for all other leaks the usual suspects are:
1. Loose parts.
2. Imperfect seal at gaskets, push rod covers, washers ect.
3. Restricted oil return line to oil tank/pan.
4. Restricted breather hose to air cleaner.
5. Restricted oil filter.
6. Oil tank/pan overfilled.
7. Bottom rocker housing gasket installed upside down.
Good luck and have nice day.
Jul 11, 2010 | 2000 Harley Davidson FLHTCUI Electra Glide...
American Range AF-45 45lb Commercial Deep Fat Gas Fryer Logo
Top American Range Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
starztruck4u
Dan Webster
Dan Webster
Are you an American Range Kitchen Appliances - Other Expert? Answer questions, earn points and help others
