Question about Genuine OEM 2000-2007 Ford Focus Wagon Tailgate Lift Gate Latch New OEM
Headlights not working
Both the Daylight running lights and the low beam are not operating
Headlights not working on 2003 alero/all other lights working/checked fuse and changed relay
Here is how they are suppose to work .
Headlamps
The headlamps may be turned on two different ways. First, when the driver places the headlamp switch in the HEADLAMP position, for normal operation. Second, with the headlamp switch placed in the OFF position, for automatic lamp control (ALC). During ALC, the headlamps will be in day time running lamp (DRL) operation in daylight conditions, or low beam operation in low light conditions. The LH HDLPand RH HDLP fuses, supply battery positive voltage from the underhood junction block to the left and right headlamps. The circuit continues through both low and high beam lamps, then back to the underhood junction block. The low beam and high beam circuits continue to the headlamp switch. The low beam and high beam circuits also provide the body control module (BCM) with both low and high beam inputs. The headlamp switch includes the dimmer switch and the flash-to-pass switch. When the headlamp switch is placed in the HEADLAMP position a path to ground is provided. Ground is provided at G201. Depending on the position of the high/low beam switch, either the low or high beam circuit will now have power and ground.
The LH HDLP fuse in the underhood junction block, supplies battery positive voltage to the automatic lamp control (ALC) headlamp relay coil circuit. The ALC relay switch circuit is connected to the low beam circuit at the headlamp switch. When the headlamp switch is placed in the OFF position, the BCM will automatically turn on the low beams in low light conditions. The BCM energizes the ALC relay, closing the switch contacts and grounding the low beam circuit. Ground is provided at G201. With the headlights in the low beam position, the high beams may be momentarily turned on or flashed with the dimmer switch handle. The flash-to-pass feature is accomplished by pulling the dimmer switch handle toward the driver. The headlights may be switched to high beam with the opposite movement of the dimmer switch lever. When the headlamp dimmer switch handle is pulled toward the driver, the flash-to-pass switch closes grounding the high beam circuit. Ground is provided at G201. Both high beams will remain on until the driver releases the switch handle.
If the driver places the headlight switch in the HEADLAMP position , the headlights will remain on until turned off or the battery runs dead.
Finding a wiring diagram to use along with a DMM - digital multi-meter (voltmeter ) To test the electrical circuits for the headlamps B+ power & ground side of the circuit is the way to find a fix .
Watching a few basic electrical testing video's on youtube may help you .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
The Trainer 18 Electrical Testing Tips
Can take years to learn how to trouble shoot automotive electrical systems properly .
Nov 21, 2017 | Cars & Trucks
I need clarification on 2003 Chev Malibu DRL problems:
That piece you think is a ceramic DRL module is a resistor , When in DRL mode voltage to the low beam headlamps circuit goes through that resistor dimming the headlamps from low beam to daytime running lamps . It sounds to me like you need a new resistor ,but without doing some electrical testing it could be a lot of things . The DRL relay in the under hood fuse box could have a problem , could be the BCM - body control module , the ambient light sensor etc... Here is how daytime running lamps work .
Daytime Running Lamps (DRL)
The ambient light sensor is a light sensitive transistor that varies its voltage signal to the body control module (BCM) in response to changes to the outside (ambient) light level. When the BCM receives this signal it will either turn on the daytime running lights (DRL) or the headlights. Any function or condition that turns on the headlights will cancel the daytime running lamps operation. With the headlight switch in the OFF position, the headlights will either be turned ON or OFF, after an approximate 30 second delay depending on whether daylight or low light conditions are sensed. The HTR A/C IGN fuse in the underhood junction block supplies ignition positive voltage to the daytime running lamp (DRL) relay coil circuit. The DRL relay switch contacts are connected to the low beam circuit. When the headlamp switch is placed in the OFF position, the BCM will either turn on or off the daytime running lamps, depending on whether daylight or low light conditions are sensed. The BCM energizes the DRL relay, closing the switch contacts and grounding the low beam circuit. Ground is provided at G101. The DRL illuminate the low beam headlights at a reduced intensity. The DRL will operate when the ignition switch is in the ON position, the gear selector is not in the PARK position and the parking brake is released. When these conditions have been met and the ambient light sensor indicates daytime conditions, the DRL will illuminate.
Feb 25, 2016 | Cars & Trucks
Auto headlights don't come on 2008 Chevy Trailblazer LT. What's the problem?
Maybe bad sensor as seen on the following video
And see how he troubleshoot it
Apr 15, 2015 | Cars & Trucks
My 04 buick rainier has the auto headlight system. When you first start the car the headlights come on. after about 10 min. driving all of a sudden the low beams turn off by them selves daylight or dark. ...
The problem with the headlights is a common one and it is in the low beam relay.; In the under hood fuse panel, locate the HDM relay, swap this relay with the FAN relay next to it. If the lights stay on, replace the relay. This is a solid state relay, so make sure to get the same part number.
Feb 04, 2018 | 2004 Ford F150
Connecting daylight running lights
Use a normally closed relay as in sketch. When ignition is turned on ththe DTRL's will switch on. When you switch on the head lights the rlay will open the DTRL circuit and turn them off.
Jul 30, 2012 | 2008 Ford Focus
Daylight Running Lights
The Module for the DRL is most likely bad, the DRL Module is squarish in shape and Black in color and would be located in the fuse area or in the engine compartment. Just pull it straight out and purchase another one and re-install. Buying new low-beam lights will not solve the problem, because if your low-beams work when you turn on your headlights than it is not your bulbs. The DRL Module uses your low beam lights, but at a lower intensity than when it is normally on, so if your low beams work when you turn on the headlight switch than your DRL Module is bad.
Jul 17, 2010 | 2006 Suzuki Forenza
Low beam headlights go out while driving.
check the headlight grounds
also check the daylight running light module
Jan 23, 2010 | 2005 Buick LeSabre
Low beam not working but high beam is-Pontiac Vibe 2005
I have heard it could be the Daylight Running Light module located under the dash above the brake pedal. The module controls both the daytime running lights and the low beam lights. The high beams are independent of this module.
I have the same problem. I am trying to buy a new module.
Jan 15, 2010 | 2006 Pontiac Vibe
Head lights not working
Check your operators manual. When the daylight running lights are on you can't turn on your high beams. The car has two circuits. Remember to turn your main headlights on at dusk because your taillights are not on with your day running lights and someone can rear end you. You have to fully turn on your headlights in order to get access to your highbeams. Good luck!
Feb 20, 2009 | 1997 Chevrolet Monte Carlo
Genuine OEM 2000-2007 Ford Focus Wagon Tailgate Lift Gate Latch New OEM Logo
69 people viewed this question
Top Genuine OEM Home Fencing Experts
crkuc
R Daniel Wolfe
 Russ Hill
Russ Hill
Are you a Genuine OEM Home Fencing Expert? Answer questions, earn points and help others
