Question about Kenmore CB-1 / 5285 Vacuum Cleaner Belt - Generic
Belt kenmore cb 3
Model 116 59319800
Is the sears kenmore model 116.59319211 beltless
No, the head unit takes a CB-3 belt
Jul 27, 2015 | Kenmore Vacuums
How do I change the belt on the 116 model?
To properly fix a belt on a Kenmore vacuum, you will first need to indicate whether this is an upright or a canister vacuum. The model given, 116, is only the first part of the model number, and all Kenmore vacuums, upright and canister style, start with 116. There is a period first, then a whole string of numbers, 116.255553 etc.
Kenmore vacuums are mainly made by Panasonic for Sears, and most will use a Panasonic belt. If the belt is an upright, this makes it simple, and will be a Panasonic "UB" belt.
For a canister vacuum, most models use what's referred to as a cogged belt. This type of belt has little teeth on the inside of the belt, and is Panasonic CB-5 belt.
Instructions on How to Replace the Belt for an Upright;
There will usually be to plastic screws on the top of the agitator housing on the base of the vacuum, that will say belt access. Simply take a flat head screw driver, and turn the screws so that the screw is pointing up and down on both sides. Then pull the plastic agitator housing, or the top of the base of the vacuum off. Inside you will see a the roller brush, and the belt (or broken belt). Simply take the new belt and wrap it around the silver pulley located in the back of the machine, opposite the roller brush, and wrap the other end of the belt through the roller brush. Stretch the roller brush back into the housing of the machine, and replace the top of the base of the vacuum back on the machine. You should give the belt a tug, to ensure that the brush is spinning when the belt is being pulled..
Aug 02, 2012 | Kenmore Vacuums
I cannot open and replace belt on Kenmore Model 116 (594299900) BELT ( 20-5285
The manual is here and there are diagrams on page 17 and 18 showing how to access and replace the belt.
http://www.hammerwall.com/Manuals/Kenmore/Description/116.20612003/Kenmore%20Canister%20Vacuum%20Cleaner%20Manual/L0705059/
I hope that helps
Jan 26, 2011 | Kenmore 25512/ 25513 Progressive Canister...
Is there an easy way to see if a drive belt may be broken? It's so difficult to push my Kenmore upright vacuum!
Well there is only turning the vacuum over and see if the brush is rotating.
If it is not moving then you need to replace the belt.
If you need to know how to remove the bottom plate to replace the belt, please post the model number, the numbers you posted above are not the kenmore model numbers, the model numbers will look like this
316135912,FPF311PHSB, FGF316WGSK
Feb 15, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Belt is broken
there is no belt on your model there is a reset button on the side by the brush
Dec 13, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore cannister style. Cannot remove the
It depends on the model you have. Do you know the model number? If you need a replacement belt you can get one here:
http://www.vacbelts.com/kenmore.htm
Oct 25, 2009 | Kenmore Vacuums
Kenmore Vacuum cleaner #175.3866180 bags and belt
I logged into the Kenmore website, entered the vacuum model no. and found that the bag has been superceeded by 20-50004, which appears to be available only from Kenmore. The belt required is #5270.
Aug 01, 2009 | Kenmore Bagless Upright VacuumVacuum
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Belt broken a a Kenmore model 116 canister vacuum
Greetings from GoVacuum.com,
Feel free to email me if you have any further questions, I'd be happy to walk you through it, or even shoot an instructional video to show you how you to replace it. My email is chris.jones at govacuum . com.
Chris Jones
GoVacuum.com
chris.jones@govacuum.com
Sep 29, 2008 | Vacuums
Kenmore CB-1 / 5285 Vacuum Cleaner Belt - Generic Logo
11 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
