Question about Scunci Vacuums
How to open clip
Three clip system
Broken contact clip
No you have to replace the hose.
Jan 27, 2014 | Broan-NuTone Vacuums
How do you change the power cord on the Hoover u5475-900 Wind Tunnel 6200? Thanks for your help.
This procedure worked for replacing the cord on my Hoover U6425-900. At a minimum, you will need a number 2 Phillips screwdriver, wire cutter, and two electrical wire nuts and electrical tape. Remove the accessory tools from the storage compartment. Remove two screws, these are recessed. Remove the cover from the bag compartment, remove two screws located at top corners of bag compartment. You may have to open the side filter door but the accessory tool storage compartment should be free at this point and can be removed. You should see the power cord and related wiring. If you have a digital camera you could take a photo at this point in case you need a point of reference. Make note of the power cord strain relief routing and length of wire. Too much wire will make reattaching the storage compartment difficult and the routing prevents the cord from being pulled out.
On my model the wiring colors were purple, orange and white. My replacement cord had black and white wires. The orange wire will not be involved in cord replacement. Using the wire cutters clip the purple wire about three inches back from the existing terminal. If present, clip the two nylon wire ties and discard. The white wire will have a crimped on wire connector. Clip the white wire about three inches back from the existing wire connector. The old power cord can be removed by pulling it out from the rear, it should just slide out of the rubber insulating boot. If not use a set of pliers and crimp the boot from the wiring side and push it outside the vacuum housing. If you have to do this make sure you slip the boot over the replacement cord before you insert the new cord back into the vacuum housing. Remove about a half inch of insulation from the purple and white wires and from your replacement cord unless it was supplied with insulation already removed. Use new wire nuts and connect the white wires. Use the other wire nut and connect the purple wire to the remaining new power cord wire. Use some electrical tape and wrap the nuts to the wires a couple of times so they won't loosen. Make sure you route the power cord around the posts as this is the strain relief and prevents the cord from being pulled out. Reassemble and test.
Feb 03, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Rainbow series E vacuum suddenly started to make a loud clacking noise. still had suction. Turned off the motor. Checked the hepa filter just because didn't know what else to check. A clip was laying...
You are correct. They get rusted, and pop off sometimes. Clean your water separator regularly, with a Rainbow separator cleaning brush, or a toothbrush is just like it, and will work perfectly for your water separator cleaning brush, also. Your fan blades may be dirty and imbalanced also. Sometimes, the bearing housings crack.
It is probably just a popped off clip. Put it back on if you can. If not, I would just get it out of there, and do not worry about it. As long as it has atleast the other three still on there.
Let me know if you need any more help.
Ralph
Dec 04, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Where is the filter
Dyson put filters in three locations. 1) Remove the canister, there should be a release clip in the front above the handle, this allows the top to tip backwards. 2) On the left side, at the main unit is a round cover with thumb release, this pulls straight out. These are cleanable filters, RINSE ONLY no soap!!
3) Under the canister is a filter, the cover has 3 clips which need to be pried gently to open the cover. This is a hepa filter and cannot be cleaned, it must be replaced.
Nov 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a worn clip - the open close clip to secure the adjustable handle in place. I have the new part but, not sure how to fit it. Can you help?
Yes. Remove the handle and cable, then remove the bag compartment cover. At the back of the bag compartment, towards the top, you will see four screws. Ignore the one furthest to the left, and unscrew the other three. That will release the cover at the rear, and expose the clip you want to get at. The clip is held in place by a metal C-clip, which can be levered off with a screwdriver, but be careful not to damage it because you will need it to secure your new clip. when you've got the new clip in place, re-position the cover (not that it clips in at the top first), replace the three screws and the job's done.
I value your feedback, so please remember to rate this response.  Good luck!
Jul 22, 2009 | Sebo X4 Bagged Upright Vacuum
How to pull apart the cyclone barrel on my Dyson DC11
To Pull Apart the DC11 Cyclone section there are three more screws
but to get to them you need to remove the button (the one that unlocks the flap to empty the dust out) There is a small rectangular hole on the other side of the button, pushing a small screwdriver (3-4 mm jewellers ) will release the button this will reveal one of the three remaining screws , removal of the plastic section retained by this screw will reveal the remaining two
Mar 26, 2009 | Dyson DC11 All Floors Bagless Canister...
I have LG V-3310 Vacuum cleaner of 1400 W. I want to know where will be the dust collected and how can i clean the vacuum cleaner.
between the top of the carry handle and the body there should be a clip undo the clip open like a car boot take out and replace R.Carpenter
Sep 24, 2008 | LG Vacuums
Change cord on electrolux EL5020
In order to get to the cord that is disconnected you need to remove the screws that hold on the frame(the red shell). You will need to remove the "fenders" that are near the wheels. In order to remove the fenders get a flat tip screwdriver and pry up on the front part of the fender, there are three clips holding the left one on and two holding the fender near the cord. You will need to remove the left wheel (the wheel farthest from the cord). After you remove all the exterior screws and the four screws under the brissels the shell should be able to be removed. Next you will need to pull the cord all the way out and there will be a clear clip, use a flat tip screwdriver and release the clip in order to remove the clear piece that holds the power cord electrical ends. Reattach the clips of the power cord and be sure when you put the clear piece back in that the two contacts are not bending. You will need to use a screwdriver to guide the electrical clips back into place. I didn't count the screws there is a lot of them. I hope this helps you
Sep 20, 2008 | Electrolux EL5020 Vacuum
Vacuums Logo
11 people viewed this question
Top Scunci Vacuums Experts
JoeVacs
Tom Chichester
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
